查看: 1497|回复: 3
[提问] 简单的自定义面板函数-如何增加列数?谢谢!
发表于 2016-10-8 00:16:25 | 显示全部楼层 |阅读模式
http://bbs.mjtd.com/thread-84942-1-1.html
发现论坛这个最简单,可是还是不知道怎么增加列数。
如果要增加3列(N列),是否有前辈可以帮忙修改修改?谢谢!
以下szmaicy前辈修改的,两列。
;修改版,向飞诗学习
(defun c:xxx ()
  (mai_make_panel
    (list
      (list "梁"
            (list "画    梁" "circle") ;(list  按钮标签  运行的命令)
            (list "单线变梁" "mini_line_to_beam")
            (list "筏板梁倒角" "mini_foundation_beam")
            (list "修补梁柱" "mini_fix_beam")
            (list "修补双线" "mini_fix_dline")
            (list "框选修补线" "mini_fix_line")
      ) ;_ 结束list
      (list "柱"
            (list " + 型柱" "mini_c_column")
            (list " L 型柱" "mini_l_column")
            (list " T 型柱" "mini_t_column")
            (list " ○ 型柱" "mini_O_column")
            (list " □ 型柱" "mini_r_column")
            (list "轴线布柱" "mini_axis_column")
            (list "填 充 柱" "mini_fill_column")
            (list "墙体填充" "mini_fill_wall")
            (list "转PKPM GS柱" "mini_pline_to_beam")
            (list "多线变柱" "mini_pline_to_column")
      ) ;_ 结束list
    ) ;_ 结束list
  ) ;_ 结束mai_mak_panel
(defun mai_make_panel ( menulist / n num_nobut num_button nn nnn menuname val_lst add_dclrow tt order_lst in num_image)
  (defun add_dclrow ( dstr / ) (if dstr (setq val_lst (cons dstr val_lst))))
  (setq menuname (strcat (vl-filename-mktemp) "temp_pannel.dcl"))
  (add_dclrow "curbutton:button{width=10;vertical_margin=none;vertical_margin=none;}")
  (add_dclrow "curimage:image{width=10;height=0.2;vertical_margin=none;vertical_margin=none;}")
  (add_dclrow "curpanel:dialog{label=\"迷你自定义面板\";alignment=centered;vertical_margin=none;horizontal_margin=none;")
  (add_dclrow ":row{")
  (setq len (apply 'max (mapcar 'length menulist))
        order_lst (apply 'append (mapcar 'cdr menulist))
        num_button 0
        num_nobut 0
        in 0
        num_image 0
  (foreach nn menulist
        (setq in 0)
        (add_dclrow (strcat " : boxed_column{label=\"" (car nn) "\";vertical_margin=none; horizontal_margin=none;"))
        (foreach nnn (cdr nn)
           (setq num_button (1+ num_button)
                 in (1+ in)
                 num_image (1+ num_image)
                 tt (car nnn)
                 tt (if tt tt "")
           (add_dclrow (strcat ":curbutton{label=\"" tt "\";key=\"but" (itoa num_button) "\";}"))
           (if (= 4 in)
               (progn (add_dclrow (strcat ":curimage{key=\"ima" (itoa num_image) "\";color=18;}"))
                      (setq in 0)
        (repeat (- len (length nn))
           (setq num_nobut (1+ num_nobut)
                 in (1+ in)
           (add_dclrow (strcat " : curbutton{key=\"butno" (itoa num_nobut) "\";color=-2;}"))
           (if (= 4 in)
               (progn (add_dclrow (strcat ":curimage{key=\"ima" (itoa num_image) "\";}"))
                      (setq in 0)
        (add_dclrow "spacer;}")
   (add_dclrow "}:button{label=\"关闭\";key=\"cancel\";is_cancel=true;width=10;fixed_width=true;alignment=centered;}}")
   (vl-file-delete menuname)
   (setq nn (open menuname "w"))
   (foreach n (reverse val_lst) (write-line n nn))
   (close nn)
   (setq nnn (load_dialog menuname))
   (if (not (new_dialog "curpanel" nnn)) (exit))
   (setq n 0)
   (repeat num_nobut (mode_tile (strcat "butno" (itoa num_nobut)) 1) (setq num_nobut (1- num_nobut)))
           (setq n (1+ n)
                 tt (car nnn)
                 tt (if tt tt "")
           (if (= tt "")
               (mode_tile (strcat "but" (itoa n)) 1)
               (action_tile (strcat "but" (itoa n)) (strcat "\(done_dialog " (itoa n) "\)"))
   (setq nn (start_dialog))
   (unload_dialog nnn)
  (if (> nn 0)
       (progn (setq tt (cadr (nth (1- nn) order_lst)))
              (princ "\n")
              (if (= (eval (read (strcat "(type c:" tt ")"))) 'SUBR)
                  (eval (read (strcat "(c:" tt ")")))
                  (vl-cmdf tt)
发表于 2016-10-8 10:54:58 | 显示全部楼层
加多一个 (list "梁"
      ) ;_ 结束list
 楼主| 发表于 2016-10-8 23:03:02 | 显示全部楼层
spp_wall 发表于 2016-10-8 10:54
加多一个 (list "梁"
感谢您的回复,不知为啥那天我加了却又不管用。现在又行了
GMT+8, 2025-5-20 06:58 , Processed in 0.156599 second(s), 27 queries , Gzip On.
