- 积分
- 8720
- 明经币
- 个
- 注册时间
- 2018-12-19
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2019-12-21 19:19:14
显示全部楼层
;;;页码任意修改
;1读取属性块标记tag所对应的值string
(defun xz-at (ent tag / liST0 liSTt1 blkref a)
(vl-load-com)
(if (= (vla-Get-ObjectName (setq blkref (vlax-Ename->vla-Object ent))) "AcDbBlockReference")
(if (vla-Get-HasAttributes blkref)
(progn (setq liST0 (vlax-safearray->list (vlax-variant-value (vla-GetAttributes blkref))))
(setq liSTt1 (mapcar 'vla-Get-TextString liST0))
); endif
); endif
(setq num (vl-position tag list1)) ;;返回tag在list1中的排位位置
(setq a (nth num llist1)) ;;返回list0中第num个元素,把string字符串赋给设定该图元
a
); enddefun
;2更改属性块标记tag所对应的值string
(defun xz-att (ent tag string / liST0 liST1 num blkref)
(vl-load-com) ;;加载扩展功能
(if (= (vla-Get-ObjectName (setq blkref (vlax-Ename->vla-Object ent))) "AcDbBlockReference") ;;将ent转为vla对象blref,取得名称,判断是否同后面一致
(if (vla-Get-HasAttributes blkref) ;;blkref块是否有属性
(progn (setq liST0 (vlax-safearray->list (vlax-variant-value (vla-GetAttributes blkref)))) ;;取得块属性,返回值,属性值列表list0
(setq liST1 (mapcar 'vla-Get-TagString liST0)) ;;取得list0每个标签字符串,赋给列表list1
(vla-put-TextString (nth num liST0) string) ;;返回list0中第num个元素,把string字符串赋给设定该图元
); endif
); endif
(prin1)
); enddefun
;3主程序
(defun c:qq1 (/ EP1 EG1 EG2 blktag EP1st blkname str GETK prefix sttr
index0 index sslist XZ_sortlist len0 len sslist-ptl index0)
(vl-load-com)
(if (progn
(setq EP1 (entsel"点取属性块中页码的位置:\n"))
(setq EG1 (cdr (assoc 0 (entget (car EP1)))))
(if (= EG1 "INSERT")
(progn (setq EG2 (car (nentselp (cadr EP1))))
(if (= (cdr (assoc 0 (entget EG2))) "ATTRIB")
(setq blktag (cdr (assoc 2 (entget EG2)))) ;标记
(setq EP1st (entget (car EP1)))
(setq blkname (assoc 2 EP1st))
(princ (strcat" 块名为-->" (cdr blkname) " 标记为-->" blktag "\n"))
(progn(princ " 必须选择属性块!")(exit))
;开始选择页码块并修改
(if (= str0 nil) (setq str0 1)) (initget 6)
(setq mstr (getint "\n总页数<100>:"))
(setq str (getint (strcat "请输入增值或序号起整数<" (rtos str0) ">:")))
(if (= str nil)(setq str str0))
(if (not mstr) (setq mstr 100))
(initget "H V S ")(setq GETK (getkword "排序方式:\n [横向优先(H)/竖向优先(V)/选择优先(S)]: <V> "))
(if (not GETK) (setq GETK "V"))
(princ ">>选择批量修改页码的对象...")
(setq ss (ssget (cons blkname slist)))
(setq index0 0 index (sslength ss) sslist '())
(repeat index
(setq sslist (cons (ssname ss index0) sslist))
(setq index0 (1+ index0))
;开始构建图元点位表
(setq index0 0 sslist-ptl '() tmp-pt '())
(repeat index
(setq tmp-pt (cons (nth index0 sslist) (cons (cdr(assoc 10 (entget (nth index0 sslist)))) tmp-pt)))
(setq sslist-ptl (cons tmp-pt sslist-ptl))
(setq tmp-pt '())
;开始排序
(cond
((= GETK nil)
;开始增值
(setq len0 0 len (length sslist-ptl))
(repeat len
(setq ent0 (car (nth len0 sslist-ptl))) ;;返回第len0个图元的名称
(setq old (xz-at ent0 blktag))
(princ "\n测试中。。。 ")
(setq num (atoi (cdr (assoc 1 old))))
(setq sttr (itoa (+ num str)))
(xz-att ent0 blktag sttr)
(princ (strcat "-->增值 <" (rtos str) "> "))
(setq len0 (1+ len0))
);repeat
;从左到右从上到下
((= GETK "H")
(setq XZ_sortlist (vl-sort
(vl-sort sslist-ptl '(lambda (s1 s2) (> (cadadr s1) (cadadr s2))))
'(lambda (s3 s4) (if(equal (cadadr s3) (cadadr s4) 0.6)(< (caadr s3) (caadr s4))))))
;从上到下从左到右
((= GETK "V")
(vl-sort sslist-ptl '(lambda (s1 s2) (< (caadr s1) (caadr s2))))
'(lambda (s3 s4) (if(equal (caadr s3) (caadr s4) 0.6)(> (cadadr s3) (cadadr s4))))))
;选择顺序
((= GETK "S")
(setq XZ_sortlist sslist-ptl))
);cond
;开始修改页码
(setq len0 0 len (length XZ_sortlist))
(repeat len
(if (setq ent0 (car (nth len0 XZ_sortlist))) ;;返回第len0个图元的名称
(cond
((/= prefix "")
(if (=(strlen (rtos str))1)
(setq sttr (strcat "共 " (itoa mstr) " 页/第 " (itoa str) " 页"))
((= prefix "")(setq sttr (rtos str)))
);cond
(princ (strcat "-->修码 <" (rtos str) "> "))
(setq len0 (1+ len0) str (1+ str))
(setq str0 str)
);repeat
(prin1)
