查看: 1412|回复: 5
[提问] 将单行/多行文字合并
发表于 2016-10-17 09:34:07 | 显示全部楼层 |阅读模式
3明经币
在论坛中看见  荒野孤行 发布的帖子将多行文字合并http://bbs.mjtd.com/forum.php?mo ... 0%D0%D0%CE%C4%D7%D6   如何修改可以使合并后的多行文字还保留原来颜色
源码如下:
;;;*****文字合并 程序开始*****
(defun c:hb (/ lst)
  (setq oldaun (getvar "aunits"))
  (setvar "aunits" 3)
  (setvar "osmode" 15359)
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (princ "\n★功能:文字合并。\n制作者:吴丁运\n")
  (setq ss (ssget '((0 . "MTEXT,TEXT"))))
  (setvar "osmode" 0)
  (initget "E S A")
  (if (not (setq kword
                  (getkword
                    "\n在合并文字之间加:[换行(E)/空格(S)/直接合并(A)]<E>"
    (setq kword "E")
  (setvar "osmode" 0)
  (setq lst '())
  (while (> (sslength ss) 0)
    (setq entnam (ssname ss 0)
          entdat (entget entnam)
    (setq pt  (cdr (assoc 10 entdat))        ;读取文字的插入点坐标
          txt (cdr (assoc 1 entdat))        ;读取文字内容
          zg  (cdr (assoc 40 entdat))        ;读取文字的字高
          lst (cons (list pt txt zg) lst) ;将点坐标、内容、字高组成表
          ss  (ssdel entnam ss)                ;选择集中删除当前的文字对象
    (entdel entnam)                        ;删除文字对象
  (setq
    lst
     (vl-sort lst
(function
                (lambda        (e1 e2)
                  (if (equal (cadr (car e1)) (cadr (car e2)) 1e-4)
                    (> (car (car e1)) (car (car e2)))
                    (< (cadr (car e1)) (cadr (car e2)))
  (setq str "")
  (cond        ((= kword "S")
         (foreach e lst
           (setq str (strcat (cadr e) " " str))
        ((= kword "E")
         (foreach e lst
           (setq str (strcat (cadr e) "\n" str))
        ((= kword "A")
         (foreach e lst
           (setq str (strcat (cadr e) str))
  (command "MTEXT" pt "H" zg "W" 0 str "")
  (princ "\n★提示:文字合并完成.\n")
  (setvar "aunits" oldaun)
  (command "undo" "e")
;;;*****文字合并 程序结束*****
发表于 2016-10-17 22:10:41 | 显示全部楼层
  1. (defun c:hb (/ delim dxf ename height lst n ss str)
  2.   (if (and
  3.         (setq ss (ssget '((0 . "*TEXT"))))
  4.         ;;        (setq p (getpoint "指定合并后文字位置:"))
  5.       )
  6.     (progn
  7.       (setvar "cmdecho" 0)
  8.       (command "undo" "be")
  9.       (setq delim  ""
  10.             height (cdr (assoc 40 (entget (ssname ss 0))))
  11.       )
  12.       (repeat (setq n (sslength ss))
  13.         (setq ename (ssname ss (setq n (1- n)))
  14.               dxf   (entget ename)
  15.               lst   (cons (list        (cdr (assoc 10 dxf))
  16.                                 (cdr (assoc 1 dxf))
  17.                                 (cdr (assoc 62 dxf))
  18.                           )
  19.                           lst
  20.                     )
  21.         )
  22.         (entdel ename)
  23.       )
  24.       (setq
  25.         lst
  26.          (vl-sort lst
  27.                   (function
  28.                     (lambda (e1 e2)
  29.                       (< (car (car e1)) (car (car e2)))
  30.                     )
  31.                   )
  32.          )
  33.       )
  34.       (setq str "{")
  35.       (foreach e lst
  36.         (if (null (nth 2 e))
  37.           (setq str (strcat str (cadr e) delim))
  38.           (setq str (strcat str "\\C" (itoa (nth 2 e)) ";" (cadr e) delim))
  39.         )
  40.       )
  41.       (setq str (strcat str "}"))
  42.       (entmake (list '(0 . "MTEXT")
  43.                      '(100 . "AcDbEntity")
  44.                      '(100 . "AcDbMText")
  45.                      (cons 71 7)
  46.                      (cons 40 height)
  47.                      (cons 10 (caar lst))
  48.                      (cons 1 str)
  49.                )
  50.       )
  51.       (command "undo" "e")
  52.     )
  53.     (princ)
  54.   )
  55. )
 楼主| 发表于 2016-10-18 08:41:00 | 显示全部楼层
这个合并后多行文字颜色还都是随层呀  不是合并前文字的颜色
发表于 2016-10-18 08:49:12 | 显示全部楼层
这个 模板都有了 自己加两行就行了啊 比如你想要怎么决定多个对象中以谁的颜色或层图为准啦 什么的
代码更新了,增加了颜色设置
 楼主| 发表于 2016-10-18 09:24:08 | 显示全部楼层
代 ...
具体如图,要合并的多行文字有不同的颜色,怎样能在合并时候还保留他的原来颜色
发表于 2016-10-18 10:55:58 | 显示全部楼层
基本上针对楼主的场景重写了
GMT+8, 2025-5-20 05:08 , Processed in 0.155527 second(s), 23 queries , Gzip On.
