查看: 2656|回复: 5
请帮忙查错!!!!
发表于 2002-8-12 09:36:00 | 显示全部楼层 |阅读模式
请帮忙查错!!!!
如下一统计所选区域一个块的数量的程序:
(defun c:tjB (/ num pt1 pt2 pt3 SS1)
  (setq pt1 (getpoint "方框第一点: "))
  (setq pt2 (getpoint "方框第二点: "))
(setq ss1 (ssget "w" pt1 pt2 '((0 . "block") (2 . "路标))))
        (setq num (sslength ss1))
        (setq pt3 (getpoint "\n标注位置: "))
        (command ".text" pt3 "" "" (rtos num 2 0) "")
      (setq SS1 nil)
加载时出现如下错误,
; error: extra cdrs in dotted pair on input
用(GETVAR "ERRNO")检查错误时,显示错误代码为“0”,即没有错误,
请高手帮忙检查一下错误,谢谢!!!!!!!!
发表于 2002-8-12 10:23:00 | 显示全部楼层
(2 . "路标) 少了右引号
 楼主| 发表于 2002-8-12 10:29:00 | 显示全部楼层
还有错误
还有错误
发表于 2002-8-12 10:41:00 | 显示全部楼层
(setq ss1 (ssget "w" pt1 pt2 '((0 .&nbs
(setq ss1 (ssget "w" pt1 pt2 '((0 . "block")(2 . "路标") )))有误[br](setq ss1 (ssget "w" pt1 pt2 '((0 . "block")(2 . "路标") )))有误
好象是"block"命名不对,我试过,但不知道用什么名称,"blockref"和 "blockreference"都不对,不过,去掉(0,"block"),即下面的语句可通过而且不会出错:
(setq ss1 (ssget "w" pt1 pt2 '((2 . "路标") )))
你试试。
 楼主| 发表于 2002-8-12 10:59:00 | 显示全部楼层
谢谢了!!!!!!!!
现在可以了,谢谢了!!!!!!!!!!
发表于 2002-8-13 21:48:00 | 显示全部楼层
应该是(0 . "INSERT")
GMT+8, 2025-8-10 04:18 , Processed in 0.188881 second(s), 25 queries , Gzip On.
