查看: 773|回复: 1
[提问] 求助:归层问题
发表于 2017-8-7 12:32:45 | 显示全部楼层 |阅读模式
功能描述:判断后图中是否已有所需图层  若无该图层则新建图层 (已存在则不新建) 指定到图元、 并将该图层置为当前图层
问题描述:如果图中没有所需图层、指定当前层、及图层指定到图元都有问题。
(defun cmdload (cmdlist / lst)
  (setq    lst (mapcar '(lambda (x)
                                             (strcat "(defun c:"(car x)"(/)(xjtc (list \""(car x) "\"\""(cadr x) "\""(itoa (caddr x)) "\""(cadddr x)"\""(itoa (nth 4 x))"\""(itoa (nth 5 x))"\"))(princ))")
                            cmdlist
  (eval (read (strcat "(progn" (apply 'strcat lst) ")")))
(defun xjtc (lst / ss la co lt lw S)
  (if (setq ss (ssget))
      (setq la (nth 1 lst)
                co (nth 2 lst)
                lt (nth 3 lst)
                lw (nth 4 lst)
                S (nth 5 lst)
      (if (= (tblsearch "layer" la) nil)
                (command "layer" "n" la "c" co la "l" lt la "lw" lw la "S" S LA "")
      (command "chprop" ss "" "c" "bylayer" "la" la "S" S "")
            (setvar "clayer" la)
(cmdload  '( ("1" "图层1" 1 "Continuous" 0 30)
                         ("2" "图层2" 2 "ACAD_ISO03W100" 0 10)
                         ("3" "图层3" 3 "ACAD_ISO03W100" 0 10)
 楼主| 发表于 2017-8-7 15:09:08 | 显示全部楼层
问题已解决:lol
GMT+8, 2025-10-26 04:06 , Processed in 0.124789 second(s), 26 queries , Gzip On.
