01. 02. 03. 04. 05. 06. 07. 08. 09. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. 24. 25.
;进度条
(defun EF-ProgressBar (iRate sMsg / Lst str J) (setq iRate (min 100 (max 0 iRate))) (if (= iRate 100) (grtext) (progn (setq LST '("" "▏" "▎" "▍" "▌" "▋" "▊" "▉" "█") sProgress "" iRate (fix iRate) iRate (* iRate 2) ) (repeat (/ iRate (length LST)) (setq sProgress (strcat sProgress (last LST))) ) (setq sProgress (strcat sProgress (nth (rem iRate (length LST)) LST))) (repeat (/ (- 44 (strlen sProgress)) 2) (setq sProgress (strcat sProgress " ")) ) (setq sProgress (strcat sProgress (rtos (/ iRate 2) 2 0) "%")) (grtext -1 sMsg) (grtext -2 sProgress) ) ) )
帆航 发表于 2017-8-16 08:29 安装好了opendcel后,再把.odcl文件打开,然后添加.lsp进来,再然后呢,真的不会了,麻烦了
elitefish 发表于 2017-9-30 12:16 纯Lisp的进度条iRate:当前进度百分比数值 (0~100) sMsg:进度条前显示的文字
zzyong00 发表于 2017-8-10 20:21 opendcl? 帮顶
本版积分规则 发表回复 回帖后跳转到最后一页
GMT+8, 2025-5-2 09:38 , Processed in 0.213359 second(s), 32 queries , Gzip On.
