查看: 750|回复: 4
[提问] 求:若不存在,则插入图块,若存在则忽略代码
发表于 2017-8-11 16:43:24 | 显示全部楼层 |阅读模式
如题,若图纸中存在,XYZ图块的话,则忽略,若还没有,则插入他。
求段代码。。。。
发表于 2017-8-11 17:14:35 | 显示全部楼层
tblsearch
发表于 2017-8-11 17:17:39 | 显示全部楼层
使用tblobjname或tbjsearch检索块是否存在。
 楼主| 发表于 2017-8-11 18:53:47 | 显示全部楼层
我这么作成功了,
(if (null (ssget "x" (list (cons 0 "insert")(cons 2 "dimblk"))))
        (setq pt1 (nth 1(grread 5)))
        (command "insert" "dm-blk" pt1 "" "" "")
        (command "erase" "l" "")
        (command "dim" "dimblk" "dimblk" "exit"))
发表于 2017-8-11 22:09:04 | 显示全部楼层
(while (setq d (tblnext "block" (null d)))
  (setq lst (cons (cdr (assoc 2 d)) lst))
(if (and (not (member "XYZ" lst)) (setq a (findfile "xyz.dwg")))
  (command "insert" a '(0 0) "" "" "")
GMT+8, 2025-5-20 02:15 , Processed in 0.145602 second(s), 25 queries , Gzip On.
