查看: 1668|回复: 7
[提问] 同时更改颜色和线宽的代码出现错误,求帮助!!!
发表于 2017-8-21 17:20:22 | 显示全部楼层 |阅读模式
根据网上的代码改写的,只能单独更改颜色或线宽,不能同时更改,求大神指教!!!
(defun c:tes ( / #k1 &kw1 &ob1)
(if (null vlax-dump-object) (vl-load-com) )
(if (and
  (setq &kw1 (ssget))
  (setq #k1 (getint "\n请输入0~256之间的颜色代码"))
  (>= #k1 0)
  (<= #k1 256)
  (princ "\n请选择对象")
   (while (setq &ob1 (ssname &kw1 0))
    (setq &kw1 (ssdel &ob1 &kw1))
    (setq &ob1 (vlax-ename->vla-object &ob1))
    (vla-put-color &ob1 #k1);改变颜色
  (if (and
  (setq xk (getdist "\n请输入线宽单位毫米"))
  (setq xk (* xk 100))
   (while
    (vla-put-Lineweight &ob1 xk)
发表于 2017-8-22 08:55:45 | 显示全部楼层
xxxkkk331 发表于 2017-8-22 08:30
我显示错误: 参数类型错误: lentityp nil
(setq s1 (ssname ss (setq i (1+ i))));;    s1改成ob 最 前面加(vl-load-com)
 楼主| 发表于 2017-8-21 19:47:25 | 显示全部楼层
自顶求帮助
发表于 2017-8-21 20:06:18 | 显示全部楼层
(defun c:tt ()
  (setq co (getint "\n请输入0~256之间的颜色代码: "))
  (setq xk (getdist "\n请输入线宽: "))
  (princ "\n请选择对象: ")
  (while (and (setq ss (ssget)) (> co 0) (< co 256))
    (setq i -1)
    (while (setq s1 (ssname ss (setq i (1+ i))))
      (setq ob (vlax-ename->vla-object ob))
      (vla-put-color ob co)
      (vla-put-Lineweight ob xk)
    (princ "\n请选择对象: ")
 楼主| 发表于 2017-8-22 08:30:35 | 显示全部楼层
xyp1964 发表于 2017-8-21 20:06
(defun c:tt ()
  (setq xk (getdist "\n请输入 ...
 楼主| 发表于 2017-8-22 10:39:07 | 显示全部楼层
谢谢解决了
GMT+8, 2025-10-25 03:45 , Processed in 0.179192 second(s), 30 queries , Gzip On.
