查看: 665|回复: 1
[提问] MTEXT 抓取問題
发表于 2017-8-24 12:03:15 | 显示全部楼层 |阅读模式
(defun c:tyy ()
  (setq
SS (ssget
  '((0 . "REGION,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC,INSERT"))
  (setq ent (car (entsel "\n图号:")))
  (setq dxf (entget ent))
  (setq str0 "")
  (setq txt (cdr (assoc 1 dxf)))
  (setq txt (vl-string-subst "" "{" txt))
  (setq txt (vl-string-subst "" "}" txt))
  (while (setq n (vl-string-search ";" txt))
    (if (= (setq str (substr txt 1 1)) "\\")
      (setq txt (substr txt (+ n 2)))
(setq str0 (strcat str0 (substr txt 1 1)))
(setq txt (substr txt 2))
  (setq str0 (strcat str0 txt))
  (setq w2 (print  str0))
  (if(findfile (SETQ w3 (STRCAT "d:/N/" w2 ".dxf" )) )
    (alert(strcat w3"已存在"))
  (command "filedia" "0")
(command "dxfout" w3 "O" SS "" "v" "R12" "")
(command "filedia" "1")))
上面代码只能抓取一般MTEXT
但是遇到整体的内容 没办法指定
例如:
     客户 : AAAA
     图号 : P12345
     比例: 1:1
我只想抓取  图号: 后面的代号
可是一直不成功
想请各位高手前辈帮忙
 楼主| 发表于 2017-8-24 16:18:43 | 显示全部楼层
問題已解決
GMT+8, 2025-10-26 04:04 , Processed in 0.103833 second(s), 25 queries , Gzip On.
