查看: 12699|回复: 40
[【风之影】] [源码]VLISP之有道词典
发表于 2017-8-27 11:10:12 | 显示全部楼层 |阅读模式
由于明经前一段时间服务中断,恢复后有几篇帖子看不到了,所以从晓东网站上搬一个回家。
利用正则表达式和XMLHTTP,从有道词典网站取得翻译后的内容。
使用如下:
  1. (translate "风之影");;;返回"The shadow of wind"
  2. (translate "The shadow of wind");;;返回"风的影子"
也可在命令行键入TRS后,选取单行文本、多行文本、块中文字、块属性、属性定义。点击后直接翻译。
下面是函数源码:
  1. (defun GetXML (url / XML http)
  2.   (setq http (vlax-create-object "Microsoft.XMLHTTP"))
  3.   (vlax-invoke-method http "open" "GET" url 0)
  4.   (vlax-invoke-method http "send")
  5.   (setq XML (vlax-get-property http "responseText"))
  6.   (vlax-release-object http)
  7.   XML
  8. )
  9. (defun Translate (word / RegEx str)
  10.   (setq RegEx (vlax-create-object "VBScript.RegExp"))
  11.   (vlax-put-property RegEx "Global" 1)
  12.   (setq str (GetXML (strcat "http://fanyi.youdao.com/translate?&i=" word "&doctype=xml&version")))
  13.   (vlax-put-property RegEx "Pattern" "^(.|\n)*<translation>(.|\n)*?<![\[]CDATA[\[]")
  14.   (setq str (vlax-invoke-method regex "Replace" str ""))
  15.   (vlax-put-property RegEx "Pattern" "[\]]{2}>(.|\n)*<\/translation>(.|\n)*$")
  16.   (setq str (vlax-invoke-method regex "Replace" str ""))
  17.   (vlax-release-object RegEx)
  18.   str
  19. )
  20. (defun c:TRS(/ msg e dt d id new ss name)
  21.   (defun apperr (msg)
  22.     (command "undo" "e")
  23.     (setq *error* syserr)
  24.     (princ)
  25.   )
  26.   (setq syserr *error* *error* apperr)
  27.   (gc)
  28.   (setvar "cmdecho" 0)
  29.   (command "undo" "be")
  30.   (setq e (nentsel "\nSelect text"))
  31.   (setq dt (entget (car e)))
  32.   (cond
  33.     (
  34.       (and (> (length e) 2)(= (cdr (assoc 0 (entget (car (last e))))) "INSERT"))
  35.       (setq new (Translate (cdr (assoc 1 dt))))
  36.     )
  37.     (
  38.       (and (= (length e) 2)(= (cdr (assoc 0 (entget (car e)))) "TEXT"))
  39.       (setq new (Translate (cdr (assoc 1 dt))))
  40.     )
  41.     (
  42.       (and (= (length e) 2)(= (cdr (assoc 0 (entget (car e)))) "MTEXT"))
  43.       (setq new (Translate (cdr (assoc 1 dt))))
  44.     )
  45.     (
  46.       (and (= (length e) 2)(= (cdr (assoc 0 (entget (car e)))) "ATTRIB"))
  47.       (setq new (Translate (cdr (assoc 1 dt))))
  48.     )
  49.     (
  50.       (and (= (length e) 2)(= (cdr (assoc 0 (entget (car e)))) "ATTDEF"))
  51.       (setq new (Translate (cdr (assoc 2 dt))))
  52.     )
  53.   )
  54.   (if (= (cdr (assoc 0 (entget (car e)))) "ATTDEF")
  55.     (setq dt (subst (cons 2 new) (assoc 2 dt) dt))
  56.     (setq dt (subst (cons 1 new) (assoc 1 dt) dt))
  57.   )
  58.   (entmod dt)
  59.   (if (and (> (length e) 2)(= (cdr (assoc 0 (entget (car (last e))))) "INSERT"))
  60.     (progn
  61.       (setq name (cdr (assoc 2 (entget (car (last e))))))
  62.       (setq ss (ssget "x" '((0 . "insert"))) n 0)
  63.       (repeat (sslength ss)
  64.       (setq e (ssname ss n) n (1+ n))
  65.       (if (= (cdr (assoc 2 (entget e))) name)(entupd e))
  66.     )
  67.   )
  68.   (entupd (car e))
  69.   )
  70.   (apperr)
  71.   (princ)
  72. )
参与人数 5明经币 +8 金钱 +30 收起 理由
xyp1964 + 3 很给力!
LPACMQ + 1 神马都是浮云
669423907 + 1 很给力!
头大无恼 + 1 不是一般的牛
highflybird + 2 + 30 很给力!
发表于 2023-12-2 23:57:03 | 显示全部楼层
是,我的也不能用了,出现下面的提示文字
<!doctype html><html lang="en"><head><title>HTTP Status 400 – Bad Request</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 400 – Bad Request</h1></body></html>
发表于 2023-9-5 11:43:18 | 显示全部楼层
pzweng 发表于 2023-9-5 11:21
大师出手折腾一下
以前用VBA网抓过,这次试了一下,我也抓不了了。问了一下zxcad,他说他的DBO.vlx就能办到,但我不知道怎么用。
发表于 2017-8-31 15:41:01 | 显示全部楼层
非常有用。但有个问题,多行文字如果带有格式的,翻译后,格式符出一起显示出来了。好像G版有个去除格式的函数,我找找看。
发表于 2017-8-28 07:55:03 | 显示全部楼层
非常感谢大师分享程序
发表于 2017-8-28 08:18:16 | 显示全部楼层
牛啊,佩服大师杰作!!!!!!!!!!
发表于 2017-8-28 09:12:53 | 显示全部楼层
学习学习,谢谢分享。
发表于 2017-8-28 18:03:41 | 显示全部楼层
非常感谢大师分享程序
发表于 2017-8-28 21:04:30 | 显示全部楼层
有创意,谢谢分享!
发表于 2017-8-29 08:27:28 | 显示全部楼层
这个不错,很有用。谢谢分享!
发表于 2017-8-29 09:09:17 | 显示全部楼层
太强大了,其实princ到命令行也不错呢。
发表于 2017-8-29 12:38:17 | 显示全部楼层
这个挺方便的!
GMT+8, 2025-5-1 08:05 , Processed in 0.162789 second(s), 29 queries , Gzip On.
