查看: 1137|回复: 2
[提问] 求 获得当前文档目录的上级目录
发表于 2017-8-27 20:23:04 | 显示全部楼层 |阅读模式
有高手在么?
能不能帮我处理个问题呢
经常修改图纸,想按时间建立文件夹,自己改的有点问题,只能建立在打开文件的同级目录里面,
想修改成建立在当前文档的上级目录中,请大神们不吝赐教。
比如
D:\tangent\TwtT20V3\sys18x64\下的dwg文件
运行程序后就能在
D:\tangent\TwtT20V3\ 下建立个时间文件夹
我的代码如下,欢迎修改
(defun c:xrq ( / path)
(setq path (getvar "dwgprefix"))
(setq date (menucmd "M=$(edtime,$(getvar,date),MO.DD)")) ;[YY年MO月DD日][HH-MM-SS]
(vl-mkdir (strcat path "\\"date))
(princ (strcat "\n  文件夹的路径是:"path))
发表于 2017-8-29 18:15:09 | 显示全部楼层
(setq DwgDir "D:\\tangent\\TwtT20V3\\sys18x64\\")
(split DwgDir "\\")
("D:" "tangent" "TwtT20V3" "sys18x64" "")
http://www.cadtutor.net/forum/sh ... -Based-on-Delimiter
  1. ;; Usage: (split (getenv "ACADPrefix") ";")
  2. (defun split (sExpression sDelimiter / len val sList)
  3.   ; Get the length of the first item from the expression based
  4.   ; on delimiter position
  5.   (setq len (vl-string-position (ascii sDelimiter) sExpression))
  6.   ; Loop until there are no more instances of the delimiter
  7.   ; in the expression
  8.   (while (numberp len)
  9.     ; Get the item from the expression
  10.     (setq val (substr sExpression 1 len))
  11.     ; Append the item to the list
  12.     (setq sList (cons val sList))
  13.     ; Get the remaining part of the expression
  14.     (setq sExpression (substr sExpression (+ 2 len)))
  15.     ; Get the length of the next item from the string based
  16.     ; on delimiter position
  17.     (setq len (vl-string-position (ascii sDelimiter) sExpression))
  18.   )
  19.   ; Add the last value to the list
  20.   (if (/= sExpression nil)
  21.     (setq sList (cons sExpression sList))
  22.   )
  23.   ; Reverses the elements in the list and return the list
  24.   (reverse sList)
  25. )
发表于 2024-8-22 09:28:59 | 显示全部楼层
(split DwgDir "\\")
谢谢!用上了
GMT+8, 2025-12-5 07:24 , Processed in 0.173237 second(s), 26 queries , Gzip On.
