查看: 4095|回复: 12
[提问] 有没有将图纸存为当前日期的lisp
发表于 2017-9-5 16:29:01 | 显示全部楼层 |阅读模式
例如,会根据当前日期讲drawing1.dwg命名为drawing1-0905.dwg这种的lisp?
发表于 2017-9-14 11:05:36 | 显示全部楼层
[EF_SaveToday]存为今天.LSP
序号
代码
01.
02.
03.
04.
05.
06.
07.
08.
09.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
(defun C:EF_TodaySave ( / name basename ext fullname bakname path time newname)
  (setq name (Vlax-Get (Vlax-Get (Vlax-Get-Acad-Object) 'ActiveDocument) 'Name))
  (setq fullname (Vlax-Get (Vlax-Get (Vlax-Get-Acad-Object) 'ActiveDocument) 'FullName))
  (setq path (vl-filename-directory  fullname))
  (setq ext (vl-filename-extension name))
  (setq basename (vl-filename-base name))
  (setq bakname (strcat path "\\" basename ".bak"))
  (setq time (menucmd "m=$(edtime,$(getvar,DATE),YYYY-MO-DD HH-MM-SS)"))
  (cond ((= fullname "")    ;从未存过盘
     (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object)) "SAVE ")
    ((wcmatch (strcase name)  "*`[####-##-## ##-##-##`].DWG")
     (setq newname (strcat path "\\" (substr basename 1 (- (strlen basename) 21)) "[" time "]" ext))
     (if (= (strcase fullname) (strcase newname))
         (vl-cmdf "SAVEAS" "" newname)
         (if (= (getvar 'ISAVEBAK) 1)    ;检测是否需要备份
           (vl-file-rename fullname (strcat path "\\" (vl-filename-base newname) ".bak"))
           (vl-file-delete fullname)
         (if (vl-file-size bakname) (vl-file-delete bakname))
    (T
     (setq newname (strcat path "\\" basename "[" time "]" ext))
springwillow + 1 信出手,代码就是好啊
发表于 2017-9-13 23:06:46 | 显示全部楼层
;one6363 2011-12-6 http://bbs.yxcax.com/thread-79329-4-1.html
;Andyhon 2016-7-20 http://bbs.mjtd.com/forum.php?mod=viewthread&tid=173164
(defun c:fw()
  (cond
    ((setq na (entsel "\n请选取图形名称:"))
     (setq na (cdr (assoc 1 (entget (car na)))))
    (T (setq na ""
;(getstring "\n请输入图形名称:")
  (princ "\n请选择输出对象: ")
  (setq        ss     (ssget ":s" '((0 . "~xline")(0 . "~ray")))
        date   (rtos (getvar "cdate") 2 6)
        年     (substr date 3 2)        ;1 4
        月     (substr date 5 2)
        日     (substr date 7 2)
        tim    (substr date 10)
        时     (substr tim 1 2)
        分     (substr tim 3 2)
        秒     (substr tim 5 2)
        datime (strcat "(" 年 "" 月 "" 日 "_" 时 "" 分 "" 秒 ")")
        desk   (strcat "E:/00/发外图纸/" na datime)
  (command "WBLOCK" desk "" '(0 0 0) ss "")
  ;; 把选择
  (command "oops")
(if (/= ss nil)(progn
  (vlax-invoke
    (vlax-create-object "wscript.shell")
    'run
    "E:\\00\\CAD外挂\\打开发外图纸.vbs"
(princ"\n选择的对象已完成输出")
发表于 2017-9-5 16:41:18 | 显示全部楼层
有呀,G版就发过,每隔一段时间就自动生成一个。
发表于 2017-9-5 20:49:33 | 显示全部楼层
记得好早就有了,好像叫“存为今天”
 楼主| 发表于 2017-9-6 08:58:07 | 显示全部楼层
G版的我看了是生成一个但是不能覆盖原有的,只是起个备份的作用
 楼主| 发表于 2017-9-6 08:58:21 | 显示全部楼层
liwen888888 发表于 2017-9-5 20:49
记得好早就有了,好像叫“存为今天”
存为今天不是lisp,是vlx
 楼主| 发表于 2017-9-18 10:18:31 | 显示全部楼层
信大神的程序真的很好,就是精确到秒太夸张了,而且实测好像也没有出现备份文件
 楼主| 发表于 2017-9-18 10:49:56 | 显示全部楼层
可不可以改成只精确到分钟的,我自己尝试修改,但是失败了
发表于 2018-6-16 20:05:55 | 显示全部楼层
你好,请问vlax-get是什么函数?为什么我在CAD2016帮助里面找不到这个函数?
GMT+8, 2025-5-19 14:03 , Processed in 0.442507 second(s), 28 queries , Gzip On.
