查看: 721|回复: 4
[讨论] 看看这个怎么弄
发表于 2017-9-13 16:09:24 | 显示全部楼层 |阅读模式
(defun c:t ()
(setvar "osmode" (+ 0))
(while (and (setq p (getpoint "\n插入点: "))
             (setq str (getstring t "\n请输入文字: "))
   (entmake (list '(0 . "TEXT") (cons 10 p)'(40 . 7)'(8 . "0")'(62 . 6)(cons 1 (strcat "BJX358" str))))
(setvar "osmode" 3)
(setq HH:Osmode (getvar "osmode"))
(defun HH:resetosmode (v1 v2)
  (if (/= (getvar "osmode") HH:Osmode)
    (setvar "osmode" HH:Osmode)
(vlr-editor-reactor
  nil
  '((:vlr-lispEnded . HH:ResetOsmode)
    (:vlr-lispCancelled . HH:ResetOsmode)
这是一个单线文字插件,现在有个问题看看哪位能不能给解决一下:就是输入的文字是在当前图层,我想把它改为:不官当前是哪个图层,输入的文件放在lasey8这个图层里。请问怎么加一语句?
发表于 2017-9-13 16:18:10 | 显示全部楼层
改8组码
 楼主| 发表于 2017-9-13 16:31:39 | 显示全部楼层
masterlong 发表于 2017-9-13 16:18
(entmake (list '(0 . "TEXT") (cons 10 p)'(40 . 7)'(8 . "0")'(62 . 6)(cons 1 (strcat "BJX358" str))) ...
是的,想把它放在图层8里
发表于 2017-9-13 22:08:55 | 显示全部楼层
(entmake (list '(0 . "TEXT") (cons 10 p)'(40 . 7)'(8 . "这里写你要放到的图层的名字")'(62 . 6)(cons 1 (strcat "BJX358" str))))
 楼主| 发表于 2017-9-16 11:32:48 | 显示全部楼层
669423907 发表于 2017-9-13 22:08
(entmake (list '(0 . "TEXT") (cons 10 p)'(40 . 7)'(8 . "这里写你要放到的图层的名字")'(62 . 6)(cons 1 ...
谢谢,修改好了
GMT+8, 2025-5-20 02:33 , Processed in 0.172508 second(s), 25 queries , Gzip On.
