查看: 31404|回复: 137
[源码] 扩展属性查看编辑小工具
发表于 2017-9-20 13:54:15 | 显示全部楼层 |阅读模式
使用GET命令将选定对象的扩展数据导出为文本文件,手工编辑此文本文件后保存,再执行PUT命令可以把修改后的扩展数据存回选定的对象。
特性:
1、100% 纯LISP代码,无插件、扩展组件要求
2、3.5K 超小代码长度。
已知问题:
1、当数据文件中含 有多个1001段时,需要手动注册appid,否则写回XDATA操作会失败
2、浮点数在交换过程中可能损失精度
下面是源码:
  1. (defun op-ensure-object        (obj)
  2.   (if (= 'ename (type obj))
  3.     (vlax-ename->vla-object obj)
  4.     obj
  5.   )
  6. )
  7. (defun op-xdata-get (obj appname / xtypeout xdataout)
  8.   (setq obj (op-ensure-object obj))
  9.   (vla-getxdata obj appname 'xtypeout 'xdataout)
  10.   (if (null xtypeout)
  11.     nil
  12.     (mapcar '(lambda (a b) (cons a b))
  13.             (vlax-safearray->list xtypeout)
  14.             (mapcar '(lambda (e)
  15.                        (if (>= (vlax-variant-type e) 8192)
  16.                          (vlax-safearray->list (vlax-variant-value e))
  17.                          (vlax-variant-value e)
  18.                        )
  19.                      )
  20.                     (vlax-safearray->list xdataout)
  21.             )
  22.     )
  23.   )
  24. )
  25. ;; (op-xdata-get (vlax-ename->vla-object (car (entsel))) "")
  26. (defun op-xdata-set (obj xdata / datatype data)
  27.   (setq obj (op-ensure-object obj))
  28.   (setq        datatype (vlax-make-safearray
  29.                    vlax-vbinteger
  30.                    (cons 0 (1- (length xdata)))
  31.                  )
  32.         data         (vlax-make-safearray
  33.                    vlax-vbvariant
  34.                    (cons 0 (1- (length xdata)))
  35.                  )
  36.   )
  37.   (vlax-safearray-fill datatype (mapcar 'car xdata))
  38.   (vlax-safearray-fill
  39.     data
  40.     (mapcar '(lambda (e)
  41.                (if (listp e)
  42.                  (vlax-3d-point e)
  43.                  e
  44.                )
  45.              )
  46.             (mapcar 'cdr xdata)
  47.     )
  48.   )
  49.   (vla-setxdata obj datatype data)
  50. )
  51. ;; (op-xdata-set (vlax-ename->vla-object (car (entsel))) '((1001 . "1")))
  52. (defun op-xdata-remove (obj appname /)
  53.   (setq obj (op-ensure-object obj))
  54.   (op-xdata-set obj (list (cons 1001 appname)))
  55. )
  56. (defun op-string-tokenize (str delim / buff l2)
  57.   (setq        str   (vl-string->list str)
  58.         delim (ascii delim)
  59.   )
  60.   (while str
  61.     (if        (= (car str) delim)
  62.       (setq l2         (cons (vl-list->string (reverse buff)) l2)
  63.             buff nil
  64.       )
  65.       (setq buff (cons (car str) buff))
  66.     )
  67.     (setq str (cdr str))
  68.   )
  69.   (if buff
  70.     (setq l2 (cons (vl-list->string (reverse buff)) l2))
  71.   )
  72.   (reverse l2)
  73. )
  74. ;;;_$ (op-string-tokenize "AA,1500,800,150" ",")
  75. ;;;("AA" "1500" "800" "150")
  76. (defun op-read-csvfile (filename / file line table)
  77.   (if (setq file (open filename "r"))
  78.     (progn
  79.       (while (setq line (read-line file))
  80.         (setq line (vl-string-trim " \t\n," line))
  81.         (if (/= line "")
  82.           (setq        line  (op-string-tokenize line "\t")
  83.                 line  (mapcar '(lambda (e) (vl-string-trim " \"" e)) line)
  84.                 table (cons line table)
  85.           )
  86.         )
  87.       )
  88.       (close file)
  89.     )
  90.   )
  91.   (reverse table)
  92. )
  93. (defun c:put (/ DATA E GRC GRV)
  94.   (setq data (op-read-csvfile op-last-swapfilename))
  95.   (setq        data (mapcar '(lambda (e)
  96.                         (setq grc (atoi (car e))
  97.                               grv (cadr e)
  98.                         )
  99.                         (cond ((and (>= grc 1010)
  100.                                     (<= grc 1013)
  101.                                )
  102.                                (if (null grv)
  103.                                  (setq grv '(0 0 0))
  104.                                  (setq grv (vl-string-trim " ()" grv)
  105.                                        grv (mapcar
  106.                                              'atof
  107.                                              (op-string-tokenize grv " ")
  108.                                            )
  109.                                  )
  110.                                )
  111.                               )
  112.                               ((= grc 1040)
  113.                                (if (null grv)
  114.                                  (setq grv 0.0)
  115.                                  (setq grv (atof grv))
  116.                                )
  117.                               )
  118.                               ((or (= grc 1070)
  119.                                    (= grc 1071)
  120.                                )
  121.                                (if (null grv)
  122.                                  (setq grv 0)
  123.                                  (setq grv (atoi grv))
  124.                                )
  125.                               )
  126.                               (t
  127.                                (if (null grv)
  128.                                  (setq grv "")
  129.                                )
  130.                               )
  131.                         )
  132.                         (cons grc grv)
  133.                       )
  134.                      data
  135.              )
  136.   )
  137.   (op-xdata-set op-last-object data)
  138.   (princ)
  139. )
  140. (defun c:get (/ data e grc grv)
  141.   (setq        op-last-object (vlax-ename->vla-object (car (entsel)))
  142.         data               (op-xdata-get op-last-object "")
  143.   )
  144.   (if (null op-last-swapfilename)
  145.     (setq op-last-swapfilename (vl-filename-mktemp "XDATA.txt"))
  146.   )
  147.   (setq f (open op-last-swapfilename "w"))
  148.   (foreach e data
  149.     (setq str (strcat (itoa (car e)) "\t" (vl-princ-to-string (cdr e))))
  150.     (write-line str f)
  151.   )
  152.   (close f)
  153.   (startapp "notepad" op-last-swapfilename)
  154.   (princ)
  155. )
数据交换文件示例:
1001        TH
1000        A
1000        B
1070        700
1010        (100.0 2300.0 0.0)
1001        TH2
1000        B
1000        B
1070        700
1040        3.12456
1010        (1000.0 2300.0 0.0)
1001        TH3
1000        B
1000        B
1070        700
1040        3.12456
格式要求:
1、组码与值之间用制表符分隔;
2、必须包含1001段
3、点、三维坐标值以英文括号包含,各数值之间用空格分隔
4、需要移除相应APPID的扩展数据时,仅保留1001段,其余数据删除即可
2017-9-24 更新:批量修改版本
参与人数 3明经币 +3 收起 理由
gufeng + 1 很给力!
USER2128 + 1
自贡黄明儒 + 1 很给力!
本帖被以下淘专辑推荐:
  • · excel|主题: 80, 订阅: 4
  • · 经典|主题: 27, 订阅: 3
发表于 2017-9-25 15:20:07 | 显示全部楼层
网上搜的:关于AUTOCAD中扩展数据的编辑和修改方法
(defun c:kz(/ code d data dcl_re dclname en ent f gr i ii iii iiii inf key keylst keylst2 kzsj loop lst1 lst2 lw n name nent oldent pd pt ptlst ss str str1 txlst w ww x y zuma);<扩展数据编辑>
(defun *error* (inf)              ; 出错处理
    (setq inf (strcase inf t))
    (if (wcmatch inf "*break*,*cancel*,*exit*,*取消*,*中断*")
      (deltx txlst)
    (vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
  (defun jspt (pt w ww)              ; pt相对坐标计算
    (list (+ (car pt) w) (+ (cadr pt) ww))
  (defun dxf (ent n)              ; 取得图元内容
    (if (= (type ent) 'ename)
      (setq ent (entget ent))
    (cdr (assoc n ent))
  (defun emod (ent i n)              ; 替换图元内容
    (subst
      (cons i n)
      (assoc i ent)
      ent
  (defun deltx (txlst / en i x)              ; 删除显示的txlst='(ename0 ename1 ...)
   (foreach x txlst
     (entdel x)
    (setq w 0.0)
    (if lw
(setq en (entget lw)
     en (reent en (list '(0.0 0.0) '(0.0 0.0)))
(entmod (emod en 43 0.0))
    (if oldent
      (redraw oldent 4)
  (defun wrxdata (name lst / lst1 x)    ; 写入扩展数据1
    (dedata name)
    (setq lst2 '())
    (foreach y lst
      (setq lst1 '())
    (foreach x y
      (cond ((= 1000 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
   ((= 1001 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
   ((= 1002 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
   ((= 1003 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
   ((= 1004 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
   ((= 1005 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
   ((= 1010 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1020 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1030 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1011 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1021 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1031 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1012 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1022 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1032 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1013 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1023 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1033 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
   ((= 1040 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atof (get_tile x)))))))
   ((= 1041 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atof (get_tile x)))))))
   ((= 1042 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atof (get_tile x)))))))
   ((= 1070 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atoi (get_tile x)))))))
   ((= 1071 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atoi (get_tile x)))))))
   ((wcmatch (setq zuma (get_attr x "label")) "程序名:")(setq lst1 (cons (get_tile x) lst1)))
      (setq lst2 (append lst2  (list lst1)))
    ;(regapp "data1")
    (entmod (append
     (entget name)
     (list (cons -3 lst2)))
  (defun dedata (name)              ; 删除扩展数据
    (entmod (list (cons -1 name) (cons -3 (mapcar
   'list
   (mapcar
     'car
     (cdr (assoc -3 (entget name '("*"))))
  (defun lsttostr (lst / n str)              ; 表转字符串
    (setq str "")
    (foreach n lst
      (setq str (strcat str (if (= (type n) 'STR) n (rtos n 2 3)) " "))
    str
  (defun strtolst (str / i lst str1)   ; 字符串转表
    (setq lst '()
i 1
    (while (/= str "")
      (if (= (substr str i 1) " ")
(setq str1 (substr str 1 (1- i))
     lst (cons (atof str1) lst)
     str (substr str (1+ i))
     i 1
(setq i (1+ i))
    (reverse lst)
  (defun reent (ent ptlst / i nent x)  ; 按点表顺序更新多段线顶点,无须更换的顶点用nil代替。by:langjs
    (setq i -1
nent '()
    (foreach x ent
      (setq nent (append
  nent
  (list (if (and
      (= (car x) 10)
      (/= (nth (setq i (1+ i))
ptlst
  ) nil
  (cons 10 (nth i ptlst))
  (setvar "cmdecho" 0)              ; 关闭命令响应
  (vl-load-com)
  ;(prompt "\n    鼠标移动查询信息,左键编辑,右键退出!")
  (setq loop t
i 0
txlst '()
  (entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 62 186) (cons 90 2) (cons 10 '(0.0 0.0))
  (setq lw (entlast))
  (command "DRAWORDER" lw "" "B")
  (while loop
    (setq gr (grread t 4 2)
code (car gr)
pt (cadr gr)
pd nil
    (cond
      ((= code 3)              ; 鼠标左击
       ;(deltx txlst)
(if ent
   (if (setq kzsj (cdr (assoc -3 (entget ent '("*")))))
   (setq dclname (vl-filename-mktemp "yx.dcl")
f (open dclname "w")
   (write-line "yx1:dialog {" f)
   (write-line "label = 扩展数据 ; " f)
   (write-line ":row {"f)
   (write-line ":column {"f)
   (setq ii 0 iiii 0)
   (foreach y kzsj
     (foreach x y
(setq iiii (1+ iiii))
   (if (> iiii 15)(progn (setq iii  (1+ (/ iiii 15)))(setq iii (1+ (/ iiii iii))))(setq iii 15))
   (setq  keylst2 '())
   (foreach y kzsj
     (setq keylst '())
     (foreach x y
(setq ii (1+ ii))
(cond ((listp x )
      (cond ((= (car x) 1000) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1001) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1002) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1003) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1004) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1005) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1010) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1020) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1030) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1011) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1021) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1031) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1012) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1022) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1032) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1013) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1023) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1033) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1040) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos (cdr x)2 3)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1041) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos (cdr x)2 3)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1042) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos (cdr x)2 3)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1070) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos(cdr x) 2 0)"\";}") f)(setq keylst (append keylst (list  key))))
    ((= (car x) 1071) (write-line (strcat "    :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos(cdr x) 2 0)"\";}") f)(setq keylst (append keylst (list  key))))
      ((= (type x) 'STR) (write-line (strcat "    :edit_box { label =\"程序名:\"" "; key = \"" (setq key (strcat "key"(itoa ii))) "\" ;value=\""x"\";}") f)(setq keylst (cons key keylst)))
      (if (or (= ii iii)(= ii (* 2 iii))(= ii (* 3 iii))(= ii (* 4 iii))(= ii (* 5 iii))(= ii (* 6 iii))) (progn (write-line " }"f)(write-line ":column {"f)))
     (setq keylst2 (append keylst2 (list keylst)))
   (write-line " }"f)
   (write-line " }"f)
   (write-line "    :row { :button { key = \"e01\" ; label = \"确认\" ;  is_default = true ;   }" f)
   (write-line "           :button { key = \"e02\" ; label = \"取消\" ; is_cancel = true ; } } }" f)
   (close f)
   (setq dcl_re (load_dialog dclname))
   (new_dialog "yx1" dcl_re)
   (setq i 0)
   (action_tile "e01" "(wrxdata ent  keylst2)(done_dialog 1)")
   (start_dialog)
   (unload_dialog dcl_re)
   (vl-file-delete dclname)
   (princ "\n没有扩展数据!")
      ((= code 5)              ; 鼠标移动
(redraw)
(if (and
     (setq d (* (/ (getvar "viewsize") (cadr (getvar "screensize"))) (getvar "pickbox")))
     (setq ent (nentselp pt)
   ent (if (and ent (= (type (last (last ent))) 'ename))
(last (last ent))
(car ent)
     (setq kzsj (cdr (assoc -3 (entget ent '("*"))))))
(setq ii 0 iiii 0)
   (setq  keylst2 '())
   (foreach y kzsj
     (setq keylst '())
     (foreach x y
(setq ii (1+ ii))
(cond ((listp x )
      (cond ((= (car x) 1000) (setq key (strcat(rtos (car x) 2 0)"      " (cdr x)))(setq keylst (cons key keylst)))
    ((= (car x) 1001) (setq key (strcat(rtos (car x) 2 0)"      " (cdr x)))(setq keylst (cons key keylst)))
    ((= (car x) 1002) (setq key (strcat(rtos (car x) 2 0)"      " (cdr x)))(setq keylst (cons key keylst)))
    ((= (car x) 1003) (setq key (strcat(rtos (car x) 2 0)"      " (cdr x)))(setq keylst (cons key keylst)))
    ((= (car x) 1004) (setq key (strcat(rtos (car x) 2 0)"      " (cdr x)))(setq keylst (cons key keylst)))
    ((= (car x) 1005) (setq key (strcat(rtos (car x) 2 0)"      " (cdr x)))(setq keylst (cons key keylst)))
    ((= (car x) 1010) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1020) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1030) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1011) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1021) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1031) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1012) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1022) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1032) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1013) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1023) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1033) (setq key (strcat(rtos (car x) 2 0)"      " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
    ((= (car x) 1040) (setq key (strcat(rtos (car x) 2 0)"      " (rtos(cdr x) 2 3)))(setq keylst (cons key keylst)))
    ((= (car x) 1041) (setq key (strcat(rtos (car x) 2 0)"      " (rtos(cdr x) 2 3)))(setq keylst (cons key keylst)))
    ((= (car x) 1042) (setq key (strcat(rtos (car x) 2 0)"      " (rtos(cdr x) 2 3)))(setq keylst (cons key keylst)))
    ((= (car x) 1070) (setq key (strcat(rtos (car x) 2 0)"      " (rtos(cdr x) 2 0)))(setq keylst (cons key keylst)))
    ((= (car x) 1071) (setq key (strcat(rtos (car x) 2 0)"      " (rtos(cdr x) 2 0)))(setq keylst (cons key keylst)))
      ((= (type x) 'STR) (setq keylst (cons x keylst)))
      ;(if (or (= ii iii)(= ii (* 2 iii))(= ii (* 3 iii))(= ii (* 4 iii))(= ii (* 5 iii))(= ii (* 6 iii))) (progn (write-line " }"f)(write-line ":column {"f)))
     (setq keylst2 (cons (reverse keylst) keylst2))
     (setq i 0)
   (setq pt (jspt pt d (* -2 d))
i 0
w 0.0
   (redraw)
   (redraw ent 3)
  (if (or (and ent (not oldent))(not (equal oldent ent)))
    (if oldent
      (redraw oldent 4)
(if txlst
    (while (< 0 (length txlst))
      (entdel (car txlst))
      (setq txlst (cdr txlst))
    (setq oldent nil)
    (if        lw
      (foreach y (reverse keylst2)
(foreach x y
(entmake (list '(0 . "TEXT")
(cons 10 (jspt pt 0 (* -1.5 d i)))
(cons 62 6)
(cons 40 d)
(cons 1 x)
'(41 . 0.9)
(setq en (entlast))
;(command "DRAWORDER" en "" "F")
(setq txlst (cons en txlst))
(if (> (car (cadr (textbox (entget en)))) w)
   (setq w (car (cadr (textbox (entget en)))))
(setq i (1+ i))
    (if txlst
(foreach tx (reverse txlst)
      (setq en (entget tx)
   en (emod en 10 (jspt pt 0 (* -1.5 d i)))
   en (emod en 40 d)
      (entmod en)
      (if (> (car (cadr (textbox en))) w)
(setq w (car (cadr (textbox en))))
      (setq i (1+ i))
   (setq oldent ent)
   (redraw oldent 4)
   (setq h (* -0.75 d (length txlst))
en (entget lw)
en (reent en (list (jspt pt 0 (+ h (* 1.5 d))) (jspt pt (+ (* 0.3 d) w) (+ h (* 1.5 d)))))
en (emod en 43 (+ (* -2 h) (* 0.65 d)))
   (entmod en)
   (redraw)
(if txlst
    (setq oldent nil)
    (if        lw
      ((or              ; 鼠标右击
(= code 11)
(= code 25)
(deltx txlst)
(setq loop nil)
      (t
发表于 2023-1-2 00:22:27 | 显示全部楼层
谢谢楼主分享,
顺便提个小建议,可以将两个命令整合起来。
  1. (and
  2.     (setq ss (ssget '((-3 ("*")))))
  3.     (setq xdataFile (xdata->file ss))
  4.     (setq WSshell (vlax-create-object "WScript.Shell"))
  5.     (vl-catch-all-apply 'vlax-invoke (list WSshell 'run (strcat "notepad.exe " xdataFile) 8 :vlax-true))
  6.     (vl-catch-all-apply 'vlax-release-object (list WSshell))
  7.     (fileXdata->objs ss xdataFile)
  8.     (vl-file-delete xdataFile)
  9. )
发表于 2017-9-25 09:12:26 | 显示全部楼层
vectra 发表于 2017-9-24 22:40
终于有人提到批量修改问题了,不考虑批量修改,不考虑可以弄进EXCEL或其它工具里辅助编辑,当初为啥要选 ...
批量改全部的吗?? (所有的属性全一样)            put 还是用不了………………
发表于 2017-9-20 15:00:09 | 显示全部楼层
谢谢楼主提供!
发表于 2017-9-20 15:03:54 | 显示全部楼层
感谢分享,回覆学习!!!!!
发表于 2017-9-20 15:15:10 | 显示全部楼层
谢谢楼主分享!
发表于 2017-9-20 16:05:33 | 显示全部楼层
谢谢分享
发表于 2017-9-20 20:03:46 | 显示全部楼层
回复支持一下
发表于 2017-9-20 20:28:26 | 显示全部楼层
回复学习,学习分享
发表于 2017-9-20 21:02:37 | 显示全部楼层
看起来不错,收了
发表于 2017-9-20 21:26:41 | 显示全部楼层
谢谢楼主分享
发表于 2017-9-20 22:00:41 来自手机 | 显示全部楼层
谢谢分享,呵呵
GMT+8, 2025-11-13 04:41 , Processed in 0.179749 second(s), 31 queries , Gzip On.
