查看: 789|回复: 0
[提问] 如何改写VBS函数成vlis函数,或直接调用VBS函数?
发表于 2017-9-25 13:17:03 | 显示全部楼层 |阅读模式
为了存储、读取二进制文件,找了个vbs的函数,如何在vlsip中使用呢?能改写成lisp函数吗?
vbs函数如下:
Function ReadBinary(FileName)
    Const adTypeBinary = 1
    Dim stream, xmldom, node
    Set xmldom = CreateObject("Microsoft.XMLDOM")
    Set node = xmldom.CreateElement("binary")
    node.DataType = "bin.hex"
    Set stream = CreateObject("ADODB.Stream")
    stream.Type = adTypeBinary
    stream.Open
    stream.LoadFromFile FileName
    node.NodeTypedValue = stream.Read
    stream.Close
    Set stream = Nothing
    ReadBinary = node.Text
    Set node = Nothing
    Set xmldom = Nothing
End Function
Sub WriteBinary(FileName, Buf)
    Const adSaveCreateOverWrite = 2
    node.Text = Buf
    stream.Open
    stream.write node.NodeTypedValue
    stream.saveToFile FileName, adSaveCreateOverWrite
    stream.Close
    Set node = Nothing
End Sub
GMT+8, 2025-5-19 23:50 , Processed in 0.171511 second(s), 25 queries , Gzip On.
