- 积分
- 7609
- 明经币
- 个
- 注册时间
- 2008-3-21
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
网上搜的,不知作者是谁,如有侵权,敬请谅解
;关于AutoCAD中扩展数据的编辑和修改方法
(defun c:kz(/ code d data dcl_re dclname en ent f gr i ii iii iiii inf key keylst keylst2 kzsj loop lst1 lst2 lw n name nent oldent pd pt ptlst ss str str1 txlst w ww x y zuma);<扩展数据编辑>
(defun *error* (inf) ; 出错处理
(setq inf (strcase inf t))
(if (wcmatch inf "*break*,*cancel*,*exit*,*取消*,*中断*")
(deltx txlst)
(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
(defun jspt (pt w ww) ; pt相对坐标计算
(list (+ (car pt) w) (+ (cadr pt) ww))
(defun dxf (ent n) ; 取得图元内容
(if (= (type ent) 'ename)
(setq ent (entget ent))
(cdr (assoc n ent))
(defun emod (ent i n) ; 替换图元内容
(subst
(cons i n)
(assoc i ent)
ent
(defun deltx (txlst / en i x) ; 删除显示的txlst='(ename0 ename1 ...)
(foreach x txlst
(entdel x)
(setq w 0.0)
(if lw
(setq en (entget lw)
en (reent en (list '(0.0 0.0) '(0.0 0.0)))
(entmod (emod en 43 0.0))
(if oldent
(redraw oldent 4)
(defun wrxdata (name lst / lst1 x) ; 写入扩展数据1
(dedata name)
(setq lst2 '())
(foreach y lst
(setq lst1 '())
(foreach x y
(cond ((= 1000 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
((= 1001 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
((= 1002 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
((= 1003 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
((= 1004 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
((= 1005 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (get_tile x))))))
((= 1010 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1020 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1030 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1011 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1021 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1031 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1012 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1022 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1032 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1013 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1023 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1033 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (strtolst (get_tile x)))))))
((= 1040 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atof (get_tile x)))))))
((= 1041 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atof (get_tile x)))))))
((= 1042 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atof (get_tile x)))))))
((= 1070 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atoi (get_tile x)))))))
((= 1071 (setq zuma (atoi (get_attr x "label"))))(setq lst1 (append lst1 (list(cons zuma (atoi (get_tile x)))))))
((wcmatch (setq zuma (get_attr x "label")) "程序名:")(setq lst1 (cons (get_tile x) lst1)))
(setq lst2 (append lst2 (list lst1)))
;(regapp "data1")
(entmod (append
(entget name)
(list (cons -3 lst2)))
(defun dedata (name) ; 删除扩展数据
(entmod (list (cons -1 name) (cons -3 (mapcar
'list
(mapcar
'car
(cdr (assoc -3 (entget name '("*"))))
(defun lsttostr (lst / n str) ; 表转字符串
(setq str "")
(foreach n lst
(setq str (strcat str (if (= (type n) 'STR) n (rtos n 2 3)) " "))
str
(defun strtolst (str / i lst str1) ; 字符串转表
(setq lst '()
i 1
(while (/= str "")
(if (= (substr str i 1) " ")
(setq str1 (substr str 1 (1- i))
lst (cons (atof str1) lst)
str (substr str (1+ i))
i 1
(setq i (1+ i))
(reverse lst)
(defun reent (ent ptlst / i nent x) ; 按点表顺序更新多段线顶点,无须更换的顶点用nil代替。by:langjs
(setq i -1
nent '()
(foreach x ent
(setq nent (append
nent
(list (if (and
(= (car x) 10)
(/= (nth (setq i (1+ i))
ptlst
) nil
(cons 10 (nth i ptlst))
(setvar "cmdecho" 0) ; 关闭命令响应
(vl-load-com)
;(prompt "\n 鼠标移动查询信息,左键编辑,右键退出!")
(setq loop t
i 0
txlst '()
(entmake (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 62 186) (cons 90 2) (cons 10 '(0.0 0.0))
(setq lw (entlast))
(command "DRAWORDER" lw "" "B")
(while loop
(setq gr (grread t 4 2)
code (car gr)
pt (cadr gr)
pd nil
(cond
((= code 3) ; 鼠标左击
;(deltx txlst)
(if ent
(if (setq kzsj (cdr (assoc -3 (entget ent '("*")))))
(setq dclname (vl-filename-mktemp "yx.dcl")
f (open dclname "w")
(write-line "yx1:dialog {" f)
(write-line "label = 扩展数据 ; " f)
(write-line ":row {"f)
(write-line ":column {"f)
(setq ii 0 iiii 0)
(foreach y kzsj
(foreach x y
(setq iiii (1+ iiii))
(if (> iiii 15)(progn (setq iii (1+ (/ iiii 15)))(setq iii (1+ (/ iiii iii))))(setq iii 15))
(setq keylst2 '())
(foreach y kzsj
(setq keylst '())
(foreach x y
(setq ii (1+ ii))
(cond ((listp x )
(cond ((= (car x) 1000) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1001) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1002) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1003) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1004) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1005) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(cdr x)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1010) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1020) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1030) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1011) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1021) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1031) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1012) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1022) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1032) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1013) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1023) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1033) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(lsttostr (cdr x))"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1040) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos (cdr x)2 3)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1041) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos (cdr x)2 3)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1042) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos (cdr x)2 3)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1070) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos(cdr x) 2 0)"\";}") f)(setq keylst (append keylst (list key))))
((= (car x) 1071) (write-line (strcat " :edit_box { label =\"" (rtos (car x) 2 0)"\"; key = \"" (setq key (strcat (rtos (car x) 2 0)(itoa ii)))"\" ;value=\""(rtos(cdr x) 2 0)"\";}") f)(setq keylst (append keylst (list key))))
((= (type x) 'STR) (write-line (strcat " :edit_box { label =\"程序名:\"" "; key = \"" (setq key (strcat "key"(itoa ii))) "\" ;value=\""x"\";}") f)(setq keylst (cons key keylst)))
(if (or (= ii iii)(= ii (* 2 iii))(= ii (* 3 iii))(= ii (* 4 iii))(= ii (* 5 iii))(= ii (* 6 iii))) (progn (write-line " }"f)(write-line ":column {"f)))
(setq keylst2 (append keylst2 (list keylst)))
(write-line " }"f)
(write-line " }"f)
(write-line " :row { :button { key = \"e01\" ; label = \"确认\" ; is_default = true ; }" f)
(write-line " :button { key = \"e02\" ; label = \"取消\" ; is_cancel = true ; } } }" f)
(close f)
(setq dcl_re (load_dialog dclname))
(new_dialog "yx1" dcl_re)
(setq i 0)
(action_tile "e01" "(wrxdata ent keylst2)(done_dialog 1)")
(start_dialog)
(unload_dialog dcl_re)
(vl-file-delete dclname)
(princ "\n没有扩展数据!")
((= code 5) ; 鼠标移动
(redraw)
(if (and
(setq d (* (/ (getvar "viewsize") (cadr (getvar "screensize"))) (getvar "pickbox")))
(setq ent (nentselp pt)
ent (if (and ent (= (type (last (last ent))) 'ename))
(last (last ent))
(car ent)
(setq kzsj (cdr (assoc -3 (entget ent '("*"))))))
(setq ii 0 iiii 0)
(setq keylst2 '())
(foreach y kzsj
(setq keylst '())
(foreach x y
(setq ii (1+ ii))
(cond ((listp x )
(cond ((= (car x) 1000) (setq key (strcat(rtos (car x) 2 0)" " (cdr x)))(setq keylst (cons key keylst)))
((= (car x) 1001) (setq key (strcat(rtos (car x) 2 0)" " (cdr x)))(setq keylst (cons key keylst)))
((= (car x) 1002) (setq key (strcat(rtos (car x) 2 0)" " (cdr x)))(setq keylst (cons key keylst)))
((= (car x) 1003) (setq key (strcat(rtos (car x) 2 0)" " (cdr x)))(setq keylst (cons key keylst)))
((= (car x) 1004) (setq key (strcat(rtos (car x) 2 0)" " (cdr x)))(setq keylst (cons key keylst)))
((= (car x) 1005) (setq key (strcat(rtos (car x) 2 0)" " (cdr x)))(setq keylst (cons key keylst)))
((= (car x) 1010) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1020) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1030) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1011) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1021) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1031) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1012) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1022) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1032) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1013) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1023) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1033) (setq key (strcat(rtos (car x) 2 0)" " (lsttostr (cdr x))))(setq keylst (cons key keylst)))
((= (car x) 1040) (setq key (strcat(rtos (car x) 2 0)" " (rtos(cdr x) 2 3)))(setq keylst (cons key keylst)))
((= (car x) 1041) (setq key (strcat(rtos (car x) 2 0)" " (rtos(cdr x) 2 3)))(setq keylst (cons key keylst)))
((= (car x) 1042) (setq key (strcat(rtos (car x) 2 0)" " (rtos(cdr x) 2 3)))(setq keylst (cons key keylst)))
((= (car x) 1070) (setq key (strcat(rtos (car x) 2 0)" " (rtos(cdr x) 2 0)))(setq keylst (cons key keylst)))
((= (car x) 1071) (setq key (strcat(rtos (car x) 2 0)" " (rtos(cdr x) 2 0)))(setq keylst (cons key keylst)))
((= (type x) 'STR) (setq keylst (cons x keylst)))
;(if (or (= ii iii)(= ii (* 2 iii))(= ii (* 3 iii))(= ii (* 4 iii))(= ii (* 5 iii))(= ii (* 6 iii))) (progn (write-line " }"f)(write-line ":column {"f)))
(setq keylst2 (cons (reverse keylst) keylst2))
(setq i 0)
(setq pt (jspt pt d (* -2 d))
i 0
w 0.0
(redraw)
(redraw ent 3)
(if (or (and ent (not oldent))(not (equal oldent ent)))
(if oldent
(redraw oldent 4)
(if txlst
(while (< 0 (length txlst))
(entdel (car txlst))
(setq txlst (cdr txlst))
(setq oldent nil)
(if lw
(foreach y (reverse keylst2)
(foreach x y
(entmake (list '(0 . "TEXT")
(cons 10 (jspt pt 0 (* -1.5 d i)))
(cons 62 6)
(cons 40 d)
(cons 1 x)
'(41 . 0.9)
(setq en (entlast))
;(command "DRAWORDER" en "" "F")
(setq txlst (cons en txlst))
(if (> (car (cadr (textbox (entget en)))) w)
(setq w (car (cadr (textbox (entget en)))))
(setq i (1+ i))
(if txlst
(foreach tx (reverse txlst)
(setq en (entget tx)
en (emod en 10 (jspt pt 0 (* -1.5 d i)))
en (emod en 40 d)
(entmod en)
(if (> (car (cadr (textbox en))) w)
(setq w (car (cadr (textbox en))))
(setq i (1+ i))
(setq oldent ent)
(redraw oldent 4)
(setq h (* -0.75 d (length txlst))
en (entget lw)
en (reent en (list (jspt pt 0 (+ h (* 1.5 d))) (jspt pt (+ (* 0.3 d) w) (+ h (* 1.5 d)))))
en (emod en 43 (+ (* -2 h) (* 0.65 d)))
(entmod en)
(redraw)
(if txlst
(setq oldent nil)
(if lw
((or ; 鼠标右击
(= code 11)
(= code 25)
(deltx txlst)
(setq loop nil)
(t
