查看: 1072|回复: 3
[提问] 帮忙看一下有关于时间差的程序,运行不了
发表于 2017-10-3 12:07:02 | 显示全部楼层 |阅读模式
10明经币
我想要 (if (< time 6) 为判断条件,但是 (setq time (- time2 time1)) 不知道为什么不行,麻烦大师们帮看一下,谢谢了
(defun timea()
(setq time1 (menucmd "M=$(edtime,$(getvar,date),YYMODDhhmmss)") ))
(defun timeb()
(setq time2 (menucmd "M=$(edtime,$(getvar,date),YYMODDhhmmss)"))
(setq time (- time2 time1)) )
(defun xgbzzg()(timeb)
(if (< time 6)(progn
(setq ss (ssadd))
(setq ss (ssadd (entlast) ss))
(command "Select" ss "")
(setq dim (ssget "p" '((0 . "dimension"))))
(if (/= dim nil)(progn (sssetfirst nil dim)(bzzg) ))
(if (= dim nil)(bz0) ))
(bz0) ) )
(defun bz0()(weizhi)
(command "dimlinear" o o o)
(setq dim (ssadd))
(setq dim (ssadd (entlast) dim))
最佳答案
查看完整内容
(defun timea( ) (setq time1 (menucmd "M=$(edtime,$(getvar,date),YYMODDhhmmss)") ) (setq time1 (atof time1)) ) (defun timeb( ) (setq time2 (menucmd "M=$(edtime,$(getvar,date),YYMODDhhmmss)")) (setq time2 (atof time2)) (setq time (- time2 time1)) )
发表于 2017-10-3 12:07:03 | 显示全部楼层
(defun timea( )
(defun timeb( )
 楼主| 发表于 2017-10-3 15:54:45 | 显示全部楼层
xiang19751218 发表于 2017-10-3 12:07
(defun timea( )
(setq time1 (ato ...
非常感谢你,方便解释一下 atof 吗?
 楼主| 发表于 2017-10-3 15:57:28 | 显示全部楼层
字窜符转实数
GMT+8, 2025-5-20 02:18 , Processed in 0.191661 second(s), 25 queries , Gzip On.
