查看: 846|回复: 3
[提问] 请问谁有捕捉设置成按钮
发表于 2017-10-13 14:19:14 | 显示全部楼层 |阅读模式
   由于有一程序常用 捕捉丢失 所为特来求教  设一按钮 捕捉为951  在此等候
 楼主| 发表于 2017-10-13 14:30:11 | 显示全部楼层
现在CAD2016
发表于 2017-10-13 14:54:18 | 显示全部楼层
(defun c:drawline ()                                        ;define function
        (setq temperr *error*)                                ;store *error*
        (setq *error* trap1)                                ;re-assign *error*
        (setq oldecho (getvar "cmdecho"))                ;store variables
        (setq oldlayer (getvar "clayer"))
        (setq oldsnap (getvar "osmode"))
        (setvar "cmdecho" 0)                                ;set variables
        (setvar "osmode" 32)
        (command "undo" "m")
(defun trap1 (errmsg)                                        ;define function
        (command "u" "b")                                ;undo back
        (setvar "osmode" oldsnap)                        ;restore variables
        ;; (setvar "osmode" 951)
        (setvar "clayer" oldlayer)
        (setvar "cmdecho" oldecho)
        (setq *error* temperr)                                ;restore *error*
        (prompt "\nResetting System Variables ")        ;inform user
ref: http://www.afralisp.net/autolisp/tutorials/error-trapping.php
发表于 2017-10-13 17:45:54 | 显示全部楼层
(setvar"osmode"951)
GMT+8, 2025-5-19 23:36 , Processed in 0.154865 second(s), 26 queries , Gzip On.
