查看: 3909|回复: 13
[提问] 悬赏20个明经币求高手出手:关于字符串修改类的子函数
发表于 2017-10-19 12:53:49 | 显示全部楼层 |阅读模式
20明经币
字符串内容类似于:“墙12架13管144埋122” 转化为:字符串表((“墙” "12")("架 “ ” 13”)("管 “ ” 144”)("埋 “ ” 122”))
悬赏20个明经币求关于字符串转为字符串表的子函数,望高手出手!!!!
最佳答案
查看完整内容
(defun by:DIV( str / a ) (Div_list_by_2 (BY:DivStrByCEN str)) ) (defun Div_list_by_2 (lst / new_lst ) (while lst (setq new_lst (append new_lst (list (list (car lst) (cadr lst)))) lst (cddr lst) ) );end while lst new_lst ) (defun BY:DivStrByCEN (str / &str1;合并后的同类子串 c n1 resultList $oldtype $type ) (setq result ...
发表于 2017-10-19 12:53:50 | 显示全部楼层
  (while lst
          lst (cddr lst)
    );end while lst
  new_lst
  (setq resultList '())
  (while (/= str "")
    (setq c (substr str 1 1)
          n1 (ascii c)
    ;读取一个字串符,并得到ascii码
    (cond
      ((and (< n1 128)                              ;英文的ascii码都小于128
            (or (< (ascii c) 48) (>  (ascii c) 57));非数字
       (setq $type "英文")
       (if (/= $oldtype $type)
           (if &str1 (setq resultList (append resultList (list &str1))))     ;上一种字符串加入表
           (setq &str1 c)
         ;else合并
           (setq &str1 (strcat &str1 c))
       );end if
       (setq $oldtype "英文"
             str (substr str 2)                ;字符串前减1
       );end 英文
      ((and (> (ascii c) 47)
            (<  (ascii c) 58))                ;数字
       (setq $type "数字")
           (setq &str1 c)
         ;else合并
       );end if
       (setq $oldtype "数字"
       );end 数字
      ((> n1 127)                                      ;中文
       (setq $type "中文")
           (setq &str1 (substr str 1 2));中文取两位
         ;else合并
           (setq &str1 (strcat &str1 (substr str 1 2)));中文取两位
       );end if
       (setq $oldtype "中文"
             str (substr str 3)                ;字符串前减2
      );end cond
    );while
  (setq resultList (append resultList (list &str1)))     ;上一种字符串加入表
  ;返回
  resultList
);end defun
发表于 2017-10-19 14:01:39 来自手机 | 显示全部楼层
手机版显示有问题
发表于 2017-10-19 14:56:07 | 显示全部楼层
把表情改为:即可,提资时自动转换为表情了。
发表于 2017-10-19 15:41:47 | 显示全部楼层
  1. (defun StrType(a / b c d e);;字符串分离全角、符号、字母、数字,已知BUG:连续小数点与数字相连不能精确分离数字和小数点
  2.   (setq b(vl-string->list a))
  3.   (while b
  4.     (setq a(car b)b(cdr b)c(last d))
  5.     (if(or(not d)
  6.           (and(< 0 a 32)(< 0 c 32));;非打印字符
  7.           (or(= 46 a)(= 46 c)(and(< 47 a 58)(< 47 c 58)));数字和小数点
  8.           (vl-every'(lambda(x)(vl-some'(lambda(y)(<(car y)x(cadr y)))'((31 48)(57 65)(90 98)(122 129))))(list a c));其它字符包括小数点
  9.           (vl-every'(lambda(x)(vl-some'(lambda(y)(<(car y)x(cadr y)))'((64 91)(96 123))))(list a c));;字母
  10.           (and(> a 128)(> c 128)));;全角字符
  11.       (if(> a 128)(setq d(vl-list*(car b)a d)b(cdr b))(setq d(cons a d)))
  12.       (setq e(cons(reverse d)e)d(if(> a 128)(list(car b)a)(List a))b(if(> a 128)(cdr b)b))))
  13.   (mapcar'vl-list->string(reverse(cons(reverse d)e))))
;;(StrType"墙12架13管144埋122")->("墙" "12" "架" "13" "管" "144" "埋" "122")
 楼主| 发表于 2017-10-19 16:33:39 | 显示全部楼层
谢谢73哥,你这个转换的我有了,我要的是((“墙” "12")("架 “ ” 13”)("管 “ ” 144”)("埋 “ ” 122”)),里面也是表,表里有子表。类型与多维表。
 楼主| 发表于 2017-10-19 16:39:18 | 显示全部楼层
xinxirong 发表于 2017-10-19 12:53
(defun byIV( str / a )
  (Div_list_by_2 (BYivStrByCEN str))
谢谢大神,完美解决!
发表于 2017-10-19 17:33:57 | 显示全部楼层
水吉空 发表于 2017-10-19 16:33
谢谢73哥,你这个转换的我有了,我要的是((“墙” "12")("架 “ ” 13”)("管 “ ” 144”)("埋 “  ...
(SETQ A(StrType"墙12架13管144埋122"))
_$ (Mapcar'list(vl-remove-if'distof a)(vl-remove-if-not'distof a))
(("墙" "12") ("架" "13") ("管" "144") ("埋" "122"))
(defun divlst(lst n / a b)
    (while lst(setq b nil)
      (repeat(min(length lst)n)(setq b(cons(car lst) b)lst(cdr lst)))
      (setq a(cons b a)))
    (mapcar'reverse(reverse a)))
DIVLST
_$ (divlst(StrType"墙12架13管144埋122")2)
发表于 2017-10-19 17:36:18 | 显示全部楼层
  1. (defun ccc()
  2.   (setq lst (xxexp "[\\d,\\.]+|[^\\d,\\.]+" "墙12架13管144埋122" ""))
  3.   (mapcar '(lambda(a b)(list a b)) (reverse(cdr(reverse lst)))(cdr lst))
  4.   )
xxexp请在本站搜索一刀屠文正则表达式,可能还有更简单的办法,暂时未想到
 楼主| 发表于 2017-10-19 19:39:17 | 显示全部楼层
_$ (Mapcar'lis ...
谢谢73哥。。。。。。。。。。。。。。。。。。
GMT+8, 2025-10-24 04:11 , Processed in 0.151660 second(s), 25 queries , Gzip On.
