查看: 10079|回复: 30
[源码] 单行文本动态拉伸
发表于 2017-10-19 19:29:05 | 显示全部楼层 |阅读模式
;;; 单行文本动态拉伸 by:langjs
(defun C:qq (/ box data ent gr h hb hh loop p ss w wb)
(defun emod (h w ent) (entmod (subst (cons h w) (assoc h ent) ent ) ) )
(if (setq ss (ssget ":E:S" '((0 . "TEXT"))))
(setq ent (entget (ssname ss 0)) p (cdr (assoc 10 ent)) h (cdr (assoc 40 ent))
  w (cdr (assoc 41 ent)) box (textbox (cdr ent)) hb (/ h (cadr (cadr box)))
  wb (/ (car (cadr box)) (* h w)) loop t )
(princ "\n指定拉伸点:")
(while loop
(setq gr (grread t 15 0) data (cadr gr))
(cond
  ((= (car gr) 3) (setq loop nil) )
  ((= (car gr) 5) (setq hh (* hb (abs (- (cadr data) (cadr p)))) ent (emod 40 hh ent))
  (emod 41 (/ (abs (- (car data) (car p))) (* hh wb)) ent))
  ((member (car gr) '(11 25)) (setq loop nil ent (emod 40 h ent)) (emod 41 w ent)
文字如果是垂直写的,拉伸不了,如何改写?  发表于 2018-5-5 17:08
love1030312 + 1 赞一个!
发表于 2019-11-14 11:32:24 | 显示全部楼层
请问怎样修改能固定字高,仅仅拉伸宽度?
发表于 2023-6-18 06:19:23 | 显示全部楼层
戏男 发表于 2023-6-17 19:28
不能框选文字,只能单独处理一个文字
圈選 多組文字
無法同步縮放
只能 一個文字縮放完 在換下一個文字
  1. ;;; -----------------------------------
  2. ;;; 多组单行文本动态拉伸 by:langjs
  3. ;;
  4. ;;; -----------------------------------
  5. (defun C:qq2 (/ box data ent gr h hb hh loop p ss w wb)
  6. ;---------------------------------------
  7.   (defun emod (v w ent)
  8.     (entmod (subst (cons v w) (assoc v ent) ent))
  9.   )
  10. ;---------------------------------------
  11. (defun get-tt(ent)
  12.   (setq p         (cdr (assoc 10 ent))
  13.             h         (cdr (assoc 40 ent))
  14.             w         (cdr (assoc 41 ent))
  15.             box         (textbox (cdr ent))
  16.             hb         (/ h (cadr (cadr box)))
  17.             wb         (/ (car (cadr box)) (* h w))
  18.             loop t
  19.   );end_setq
  20. )
  21. ;----------------------------------------
  22.
  23.   (if (setq ss (ssget '((0 . "TEXT"))))
  24.     (progn
  25.
  26.           (princ "\n指定拉伸点:")
  27.                   (foreach ex lst
  28.                     (setq ent(entget ex))
  29.                              (get-tt ent)
  30.       (while loop
  31.                  (setq gr   (grread t 15 0)
  32.                        data (cadr gr)
  33.                  );end_setq
  34.
  35.
  36.                                         (cond
  37.                                                    ((= (car gr) 3)(setq loop nil))
  38.                                                  ((= (car gr) 5)
  39.                                          (setq hh(* hb (abs (- (cadr data) (cadr p)))))
  40.                                  (if (<= hh 0)(setq hh 0.1)) ;预防分母为0
  41.                                  (setq ent (emod 40 hh ent))
  42.                                  (emod 41 (/ (abs (- (car data) (car p))) (* hh wb)) ent)
  43.                              )
  44.                              ((member (car gr) '(11 25))
  45.                                       (setq loop nil ent (emod 40 h ent))
  46.                                       (emod 41 w ent)
  47.                              )
  48.             );end_cond
  49.
  50.       );end_while
  51.            );end_foreach
  52.     );end_progn
  53.   );end_if
  54.   (princ)
  55. );end_defun_qq
发表于 2018-4-25 10:16:09 | 显示全部楼层
程序修改下:增加改后变色,增加垂直书写判断合理调节。
  2. ;;; 单行文本动态拉伸 by:langjs
  3. ;;; -----修改:白领坛主------------------------------
  4. (defun c:qq (/ box data ent gr h hb hh loop p ss w wb ang)
  5.   (defun emod (h w ent)
  6.     (entmod (subst
  7.               (cons h w)
  8.               (assoc h ent)
  9.               ent
  10.             )
  11.     )
  12.   )
  13.   (if (setq ss (ssget ":E:S" '((0 . "TEXT"))))
  14.     (progn
  15.       (setq ent (entget (ssname ss 0))
  16.         p (cdr (assoc 10 ent))
  17.         h (cdr (assoc 40 ent))
  18.         w (cdr (assoc 41 ent))
  19.         ang (cdr (assoc 50 ent))
  20.         box (textbox (cdr ent))
  21.         hb (/ (cadr (cadr box)) h)
  22.         wb (/ (car (cadr box)) (* h w))
  23.         loop t
  24.       )
  25.       (princ "\n指定拉伸点:")
  26.       (while loop
  27.         (setq gr (grread t 15 0)
  28.           data (cadr gr)
  29.         )
  30.         (cond
  31.           ((= (car gr) 3)
  32.             (setq loop nil)
  33.           )
  34.           ((= (car gr) 5)
  35.             (if (/= 1 (sin ang))
  36.               (progn
  37.                 (setq hh (* hb (abs (- (cadr data) (cadr p))))
  38.                   ent (emod 40 hh ent)
  39.                 )
  40.                 (emod 41 (/ (abs (- (car data) (car p))) (* hh wb)) ent)
  41.               )
  42.             )
  43.             (if (= 1 (sin ang))
  44.               (progn
  45.                 (setq hh (/ (* hb (abs (- (cadr data) (cadr p)))) 2)
  46.                   ent (emod 40 hh ent)
  47.                 )
  48.                 (emod 41 (/ (abs (- (cadr data) (cadr p))) (* hh wb)) ent)
  49.               )
  50.             )
  51.           )
  52.           ((member (car gr) '(11 25))
  53.             (setq loop nil
  54.               ent (emod 40 h ent)
  55.             )
  56.             (emod 41 w ent)
  57.           )
  58.         )
  59.       )
  60.     )
  61.   )
  62.   (setq oldlup (getvar "LUPREC"))
  63.   (setvar "LUPREC" 0)           ; 精度到各位,以便后续取得标准颜色号
  64.   (command "CHANGE" (ssname ss 0) "" "P" "C" (rtos (1+ (rem (getvar "CPUTICKS")
  65.                                                          8
  66.                                                        )
  67.                                                    )
  68.                                              ) ""
  69.   )
  70.   (setvar "LUPREC" oldlup)         ; 恢复数值小数位数
  71.   (princ)
  72. )
发表于 2017-10-20 09:14:08 | 显示全部楼层
大师的思路和技巧是值得学习的!
发表于 2017-10-20 12:14:18 | 显示全部楼层
进来好好学习,感谢大师分享源码
发表于 2017-10-20 12:27:06 | 显示全部楼层
这个有用,支持支持
发表于 2017-10-21 09:06:45 | 显示全部楼层
回帖是一种美德!感谢楼主的无私分享 谢谢
发表于 2017-10-21 10:48:31 | 显示全部楼层
版本的作品,必须顶
发表于 2017-10-24 19:25:00 | 显示全部楼层
谢谢大师的分享。。
发表于 2017-10-25 10:26:22 | 显示全部楼层
感谢大师的分享。。
发表于 2017-10-27 19:17:05 | 显示全部楼层
很好用,以后不用这么麻烦的缩放字体了
发表于 2017-10-31 10:25:52 | 显示全部楼层
不错的楼主,谢谢分享啊。
GMT+8, 2025-5-25 18:57 , Processed in 0.204989 second(s), 29 queries , Gzip On.
