查看: 1676|回复: 4
运行错误: no function definition: CMDLA0
发表于 2017-10-21 16:51:00 | 显示全部楼层 |阅读模式
错误: no function definition: CMDLA0 这段哪里有问题,求高手帮忙修改下 最好是指定一个字符,册这个字符前面的字和这个字符后面的字
(defun c:scqhz ()                        ;erase-pre-suf
  (CMDLA0)
  (if (null mode)
    (setq mode "1")
  (setq        mode (UKWORD 7 "1 2" "\n文本删除 : 1-前缀/2-后缀" mode)
        ss   (ssget '((0 . "TEXT")))
        i    -1
  (while (setq s1 (ssname ss (setq i (1+ i))))
    (setq ent (entget s1)
          tx  (dxf 1 ent)
          len (strlen tx)
    (cond ((= mode "1") (main1))
          ((= mode "2") (main2))
  (CMDLA1)
(defun main1 ()
  (if (= len 2)
      (setq tx1 (substr tx 1 1))
      (if (<= (ASCII tx1) 160)
          (setq tx1 (substr tx 2))
          (sub_upd s1 1 tx1)
  (if (> len 2)
        (setq tx1 (substr tx 3))
      (sub_upd s1 1 tx1)
(defun main2 ()
  (if (= len 2)
      (setq tx1 (substr tx len 1))
          (setq tx1 (substr tx 1 (- len 1)))
          (sub_upd s1 1 tx1)
  (if (> len 2)
        (setq tx1 (substr tx 1 (- len 2)))
      (sub_upd s1 1 tx1)
(pxyp "scqhz  (删除前后缀)")
(princ)[/FONT]
发表于 2017-10-21 21:05:23 | 显示全部楼层
(CMDLA0) / (CMDLA1)  / sub_upd
乃自定义函数,请搜寻后补上
发表于 2017-10-22 21:46:53 | 显示全部楼层
貌似有点难
发表于 2017-10-22 22:32:07 来自手机 | 显示全部楼层
似乎是院长的代码
 楼主| 发表于 2017-10-25 12:37:07 | 显示全部楼层
乃自定义函数,请搜寻后补上
帮我改一下发楼下,我不会改
GMT+8, 2025-5-24 08:05 , Processed in 0.168669 second(s), 28 queries , Gzip On.
