查看: 850|回复: 2
[提问] 偏移
发表于 2017-11-7 11:54:10 | 显示全部楼层 |阅读模式
使用偏移命令,偏移后的线段自动变为红色,然后Y删除原线段,N保留原线段,可以做到?
发表于 2017-11-7 13:04:44 | 显示全部楼层
...可以做到?
sure!
 楼主| 发表于 2017-11-27 14:40:00 | 显示全部楼层
晓东找到一个:
(DEFUN C:OC() (vl-cmdf "_.undo" "_group")
               (mapcar 'princ (list "Current offset dist= " (getvar "OFFSETDIST")" "))
               (setq di (getstring "\输入偏移距离:"))
               (setq o (ssget))
               (setq po (getpoint "\nSide to offset"))
               (setq LAY (getvar "CLAYER"))
               (if (/= di nil)
               (COMMAND "OFFSET" di o po "")
               (COMMAND "CHPROP" "L" "" "LA" lay "LT" "bylayer" "C" "bylayer" ""))
               (if (= di nil)
               (COMMAND "OFFSET" "" o po "")
               (vl-cmdf "_.undo" "_end")(princ))
GMT+8, 2025-5-20 02:10 , Processed in 0.156936 second(s), 24 queries , Gzip On.
