查看: 888|回复: 6
[提问] 哪位大神帮看看问题出在哪
发表于 2017-11-8 20:32:06 | 显示全部楼层 |阅读模式
想做个批量封闭区域文字输出到TXT的程序,每个封闭区域内有编号,面积(亩),户主姓名等.要求每个封闭区域内的文字输出到txt为一行
单个封闭区域程序没大问题
(defun c:tt  (/ en ent ptl ss)
        (vl-load-com)
  (setq file1 (getfiled "文件保存在" "d:/" "TXT" 1))
  (setq file2 (open file1 "W"))
  (if (setq ent (entsel))
      (setq en (car ent))
      (setq ptl (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget en))))
      (setq ss (ssget "wp" ptl '((0 . "*text"))))
                        (setq n (sslength ss))
      (setq i 0)
                        (setq ss2 " ")
                 (while (< i n)
                        (setq ss1 (cdr(assoc 1 (entget(ssname ss i)))))
      (setq ss2  (strcat ss1 "," ss2))
                        (setq i (1+ i))
                        (write-line ss2 file2)
        (close file2)
可是改成批量就出错了
        (vl-load-com)
  (setq file2 (open file1 "a"))
  (if (setq ent (ssget '((0 . "*POLYLINE"))))
                        (setq n1 (sslength ent))
                        (setq i1 0)
                        (while  (< i1 n1)
      (setq en (ssname ent i1))
      (setq i 0)
                        (setq ss2 " ")
                 (while (< i n)
                        (setq i (1+ i))
                        (setq i1 (1+ i1))
        (close file2)
哪位大神帮看看帮修改下,谢谢
上dwg诊断  发表于 2017-11-8 20:43
发表于 2017-11-8 20:57:58 | 显示全部楼层
未经测试
 楼主| 发表于 2017-11-8 22:55:27 | 显示全部楼层
谢谢大师,测试在框选范围内都是封闭区域数据导出正常,要是有其它未封闭多段线就乱了,看来还要加个判断是否闭合的语句
 楼主| 发表于 2017-11-8 23:33:55 | 显示全部楼层
    (while (setq s1 (ssname ss (setq i (1+ i))))
                        (if (vlax-curve-isClosed s1)
      (write-line (GetTx s1) fn)))测试通过,谢谢大师
发表于 2017-11-9 09:07:17 | 显示全部楼层
      (write-li ...
(if (equal (vlax-curve-getStartPoint s1)
           (vlax-curve-getEndPoint s1)
发表于 2017-11-10 09:09:11 | 显示全部楼层
回帖是一种美德!感谢楼主的无私分享 谢谢
参与人数 1明经币 -3 收起 理由
xyp1964 -3
GMT+8, 2025-5-19 23:59 , Processed in 0.268048 second(s), 27 queries , Gzip On.
