查看: 878|回复: 1
随机生成不规则多边形
发表于 2017-12-7 10:22:41 | 显示全部楼层 |阅读模式
Sub polygon()
Dim myselect(1 To 20) As AcadEntity '定义选择集数组
Dim num As Integer
Dim pnt As Variant
Dim lpnt As Variant
num = 10 '正多边形边数
Dim fpnt(0 To 2) As Double '起点坐标
Dim leng As Double
Dim i As Long
For i = 1 To 20 '循环20次
fpnt(0) = 100 * Rnd: fpnt(1) = 100 * Rnd: fpnt(2) = 0 '起点随机坐标
leng = 10 * Rnd '边长随机长度
ReDim lpnt(0 To num * 2 - 1) As Double '下面是画正多边形
pnt = fpnt
lpnt(0) = pnt(0)
lpnt(1) = pnt(1)
Dim st As Integer
For st = 1 To num - 1
     pnt = ThisDrawing.Utility.PolarPoint(pnt, (3.14159265 * 2 / num) * (st - 1), leng)
     lpnt(st * 2) = pnt(0)
     lpnt(st * 2 + 1) = pnt(1)
Next st
Dim pgon As AcadLWPolyline
Set pgon = ThisDrawing.ModelSpace.AddLightWeightPolyline(lpnt)
pgon.Closed = True
Next i
ThisDrawing.Regen (True)
End Sub
上面是随机画正多边形的源码,先请教一下怎么修改,才能画出不规则多边形?在线等~~~~~
 楼主| 发表于 2017-12-7 12:50:47 | 显示全部楼层
只要能画出不规则多边形就可以了,比如周长是100cm,边数任意,求编写思路~~~
GMT+8, 2025-7-16 07:06 , Processed in 0.163671 second(s), 23 queries , Gzip On.
