查看: 1468|回复: 4
[源码] 长度测算,单位修改!
发表于 2017-12-14 23:53:07 | 显示全部楼层 |阅读模式
如下是测算长度一段代码,测量的结算是以毫米为单位进行统计,如果想总计以米为单位,小数点保留3位,应该怎么修改?
谢谢!
;;==============连续测距=================
(defun c:lengthgauge (/ pt pts dist1 dist2 p1 N)
  (setq pt (getpoint "\n 请指定开始点: "))
  (setq p1 (getpoint pt "\n 请指定下一点: "))
  (SETQ DIST1 (DISTANCE P1 Pt))
  (PRINC (strcat "\n 本段长度为" (rtos dist1 2 2)))
  (grdraw pt p1 1 1)
  (if        p1
         (PROGN
                (setq pts (cons p1 (list pt)))
                (SETQ DIST1 (DISTANCE (car pts) (last pts)))
                (PRINC (strcat "  累计长度为" (rtos dist1 2 2)))
                (setq M 0)
                (while
                  (if        pt
                         (progn (initget 128 "F")
                                          (setq pt (getpoint
        p1
        "\n 下一点[下一点(NEXT)/重新开始点(F)]<NEXT>: "
        ) ;_ 结束getpoint
                                                          ) ;_ 结束setq
                                          ) ;_ 结束progn
                         ) ;_ 结束if
                        (if (= pt "F")
                          (progn        (setq p1 (getpoint "\n 请指定重新开始点: "))
                                                (setq pt (getpoint p1 "\n 请指定下一点: "))
                                                (grdraw pt p1 1 1)
                                                (if p1
                                                  (PROGN (setq pts (cons p1 (list pt))))
                                                  ) ;_ 结束if
                                                ) ;_ 结束progn
                          ) ;_ 结束if
                        (setq pts (cons pt pts))
                        (if (>= (length pts) 2)
                          (grdraw pt p1 1 1)
                          ) ;_ 结束if
                        (SETQ DIST2 (DISTANCE p1 pt))
                        (PRINC (strcat "\n 本段长度为" (rtos dist2 2 2)))
                        (SETQ DIST1 (+ (DISTANCE P1 Pt) dist1))
                        (setq p1 pt)
                        (SETQ M (1+ M))
                        ) ;_ 结束while
                ) ;_ 结束PROGN
         ) ;_ 结束if
  (princ (strcat "\n>>>>>共测量了" (rtos (+ M 1) 2 0) "条线,总长度= " (rtos dist1 2 2)"mm"))
  (if        (zerop dist1)
         (princ "   零长度尺寸,请重新测量!")
         ) ;_ 结束if
  ) ;_ 结束defun
 楼主| 发表于 2017-12-15 13:40:22 来自手机 | 显示全部楼层
这个有朋友能帮忙修改一下吗?
发表于 2017-12-15 14:20:52 | 显示全部楼层
发表于 2017-12-15 14:28:04 | 显示全部楼层
(princ (strcat "\n>>>>>共测量了" (rtos (+ M 1) 2 0) "条线,总长度= " (rtos (/ dist1 1000) 2 2)"m"))
 楼主| 发表于 2017-12-15 17:13:37 | 显示全部楼层
谢谢楼上,是可以了!
GMT+8, 2025-5-19 19:43 , Processed in 0.201181 second(s), 27 queries , Gzip On.
