查看: 787|回复: 2
[提问] 求助,请大神帮忙改一下文字齐线的小程序
发表于 2017-12-17 15:11:13 | 显示全部楼层 |阅读模式
在一个求助帖http://bbs.mjtd.com/forum.php?mod=viewthread&tid=99624&highlight=%CE%C4%D7%D6%2B%CF%DF里看到x_s_s_1这位大神写的一个文字齐线的程序,后来夏生生改过,觉得很好用,但只支持直线,不支持PL线,所以请哪位大神帮忙改进一下,使之能支持PL线,谢谢。另外请教怎么改成左对齐?
;;;拷贝文字随线角度 by x_s_s_1@163.com
(defun c:ctb (/ ent enl pt1 pt2 mid_pt ang)
  (defun emk_t (layer pt1 pt2 text ang n72 n73 h w sty /)
    (entmake (list '(0 . "text")
     '(100 . "AcDbEntity")
     (cons 8 layer)
     '(100 . "AcDbText")
     (cons 10 pt1)
     (cons 1 text)
     (cons 40 h)
     (cons 41 w)
     (cons 7 sty)
     (cons 72 n72)
     (cons 11 pt2)
     (cons 50 ang)
     (cons 73 n73)
  (while
  (setq ent (car (entsel "\n选择文字:")))
  (if (= "TEXT" (cdr (assoc 0 (entget ent))))
      (while (setq enl (car (entsel "\n选择对齐线:")))
(if (= "LINE" (cdr (assoc 0 (entget enl))))
     (setq pt1  (cdr (assoc 10 (entget enl)))
    pt2  (cdr (assoc 11 (entget enl)))
    mid_pt (mapcar '(lambda (x y) (/ (+ x y) 2)) pt2 pt1)
    ang  (angle pt1 pt2)
     (if (and (> ang (* 0.5 pi)) (<= ang (* pi 1.5)))
       (setq ang (- ang pi))
     (emk_t (cdr (assoc 8 (entget ent)))
     '(0 0 0)
     (polar mid_pt (+ ang (* 0.5 pi)) 100)
     (cdr (assoc 1 (entget ent)))
     ang
     1
     0
     (cdr (assoc 40 (entget ent)))
     (cdr (assoc 41 (entget ent)))
     (cdr (assoc 7 (entget ent)))
发表于 2019-5-19 15:22:52 | 显示全部楼层
大神们,都忙
发表于 2019-5-21 09:20:44 | 显示全部楼层
  1. (defun c:tt ()
  2.   ;; tt(拷贝文字随线角度)
  3.   (if (and (setq s1 (car (entsel "\n选择文字: ")))
  4.            (xyp-Etype s1 "TEXT")
  5.       )
  6.     (progn
  7.       (redraw s1 3)
  8.       (while (and (setq e (entsel "\n选择对齐线: "))
  9.                   (setq s2 (car e))
  10.                   (xyp-curve-check s2)
  11.                   (setq p0 (vlax-curve-getclosestpointto s2 (cadr e)))
  12.                   (setq rad (xyp-Rad2Real (xyp-Get-AngleAtPoint s2 p0) 1))
  13.              )
  14.         ;;(xyp-Cross p0 300 0)
  15.         (xyp-CopyMove s1 (xyp-9pt s1 5) p0)
  16.         (xyp-SubUpd (entlast) 50 rad)
  17.       )
  18.       (redraw s1 4)
  19.     )
  20.   )
  21.   (princ)
  22. )
GMT+8, 2025-5-18 23:02 , Processed in 0.180506 second(s), 26 queries , Gzip On.
