查看: 651|回复: 1
[源码] 请问l这个源码汉化为什么不对啊,请指教
发表于 2017-12-19 15:22:58 | 显示全部楼层 |阅读模式
请问l这个源码汉化为什么不对啊,请指教
 楼主| 发表于 2017-12-19 20:06:55 | 显示全部楼层
;;--------------------=={ TabSort.lsp }==---------------------;;
(defun c:TabSort
   ;; --={  Local Functions  }=--
   *error*
   _addtab
   _archsort
   _copytab
   _deletetabs
   _endundo
   _findreplacetab
   _getlayouts
   _getsavepath
   _list->value
   _listdown
   _listtobottom
   _listtotop
   _listup
   _makelist
   _numsort
   _removeitems
   _removenth
   _renametab
   _reverseitems
   _splitstr
   _startundo
   _tabprefixsuffix
   _tabsort
   _tabsorthelp
   _value->list
   _writedcl
   ;; --={  Local Variables  }=--
   acdoc
   aclay
   aclays
   dch
   dclfname
   dclst
   dcltitle
   express
   found
   fstr
   i
   idx
   l
   lst
   name
   ofile
   pref
   ptr
   reslst
   rstr
   savepath
   suff
   ;; --={  Global Variables  }=--
   ;  *prefdef*  -  Setting to Apply a Prefix/Suffix to All Tabs
   ;  *SortTyp*  -  Sort Type Settings
   ;  *SortOrd*  -  Sort Order Settings
;;                       Local Functions                      ;;
  (defun *error* ( msg )
    (if acdoc (_EndUndo acdoc))
    (if (and dch (< 0 dch)) (unload_dialog dch))
    (if (and ofile (eq 'FILE (type ofile))) (setq ofile (close ofile)))
    (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
        (princ (strcat "\n** Error: " msg " **")))
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (defun _value->list ( val ) (read (strcat "(" val ")")))
  (defun _list->value ( lst ) (vl-string-trim "()" (vl-princ-to-string lst)))
  (defun _GetLayouts ( layouts / lst )
    (vlax-for l layouts
      (if (not (eq "MODEL" (strcase (vla-get-Name l))))
        (setq lst (cons l lst))
    (vl-sort lst '(lambda ( a b ) (< (vla-get-TabOrder a) (vla-get-TabOrder b))))
  (defun _MakeList ( key lst )
    (start_list key) (mapcar 'add_list lst) (end_list)
  (defun _GetSavePath ( / tmp )
    (cond
      ( (setq tmp (getvar 'ROAMABLEROOTPREFIX))
        (strcat (vl-string-right-trim "\\" (vl-string-translate "/" "\\" tmp)) "\\Support")
      ( (setq tmp (findfile "ACAD.pat"))
        (vl-string-right-trim "\\" (vl-string-translate "/" "\\" (vl-filename-directory tmp)))
  (defun _WriteDCL ( fname / ofile )
    (cond
        (findfile fname)
      ( (setq ofile (open fname "w"))
        (foreach line
            "//---------------------=={ TabSort.dcl }==--------------------//"
            "//  Dialog Definition file for use in conjunction with        //"
            "//  TabSort.lsp                                               //"
            "//  Author: Lee Mac, Copyright ?2011 - www.lee-mac.com       //"
            "dcl_settings : default_dcl_settings { audit_level = 1; }"
            "//                   SubAssembly Definitions                  //"
            "button13 : button   { width = 13; alignment = centered; fixed_width = true; }"
            "button16 : button   { width = 16; alignment = centered; fixed_width = true; }"
            "    eBox : edit_box { alignment = centered; fixed_width = true; allow_accept = true; is_tab_stop = true; }"
            "    fBox : edit_box { alignment = left; fixed_width = true; is_tab_stop = true; }"
            "   title : text     { alignment = centered; is_bold = true; fixed_width = false;}"
            "     txt : text     { alignment = centered; fixed_width = false; }"
            "    ltxt : text     { alignment = left;     fixed_width = false; }"
            "//                        Main Dialog                         //"
            "tabsort : dialog { key = \"dcltitle\";"
            "  : image_button { key = \"help\"; label = \"&help\"; color = -15; height = 0.1; width = 0.1; fixed_width = true; }"
            "  spacer;"
            "  : row {"
            "    : button13 { key = \"mtop\"; label = \"置顶\"      ; mnemonic = \"T\"; }"
            "    : button13 { key = \"up\"  ; label = \"向上\"       ; mnemonic = \"U\"; }"
            "    : button13 { key = \"down\"; label = \"向下\"     ; mnemonic = \"D\"; }"
            "    : button13 { key = \"mbot\"; label = \"置下\"   ; mnemonic = \"B\"; }"
            "  : list_box { key = \"tabs\"; width = 20; fixed_width = false; alignment = centered;  multiple_select = true; }"
            "  : row {"
            "    : button13 { key = \"sort\"; label = \"Sort...\"  ; mnemonic = \"S\"; }"
            "    : button13 { key = \"rev\" ; label = \"Reverse\"  ; mnemonic = \"R\"; }"
            "    : button13 { key = \"p_s\" ; label = \"Pref/Suff\"; mnemonic = \"P\"; }"
            "    : button13 { key = \"cur\" ; label = \"Current\"  ; mnemonic = \"n\"; }"
            "  spacer;"
            "  : row { fixed_width = false;"
            "    : button13 { key = \"add\"   ; label = \"添加\"    ; mnemonic = \"A\"; }"
            "    : button13 { key = \"del\"   ; label = \"删除\" ; mnemonic = \"e\"; }"
            "    : button13 { key = \"copy\"  ; label = \"复制\"   ; mnemonic = \"C\"; }"
            "    : button13 { key = \"fnr\"   ; label = \"查找\"   ; mnemonic = \"F\"; }"
            "  : text { label = \"双击重命名布局,输入H查找帮助\" ; alignment = centered; }"
            "  : row  { fixed_width = true ; alignment = centered;"
            "    : button13 { key = \"accept\"; label = \"Done\"   ; mnemonic = \"o\"; is_default = true; is_cancel = true; }"
            "    : button13 { key = \"res\"   ; label = \"Reset\"  ; mnemonic = \"s\"; }               "
            "//                        Rename Dialog                       //"
            "rename : dialog { label = \"重命名\"; spacer;"
            "  : eBox { key = \"name\"; edit_width = 20; edit_limit = 255; label = \"新布局名称:\"; }"
            "  : errtile { } "
            "  spacer; ok_cancel;"
            "//                    Delete Warning Dialog                   //"
            "delwarn : dialog { label = \"Warning\"; spacer;"
            "  : text { alignment = centered; label = \"The Selected Tab(s) will be Permanently Deleted\"; }"
            "  : text { alignment = centered; label = \"Proceed?\"; }"
            "//                    Prefix/Suffix Dialog                    //"
            "prefsuff : dialog { label = \"Add Prefix/Suffix\"; spacer;"
            "  : row {"
            "    : column {"
            "      : text { alignment = centered; label = \"Prefix\"; }"
            "      : eBox { key = \"pref\"; edit_width = 15; edit_limit = 255; }"
            "    : column {"
            "      : spacer { alignment = centered; width = 10; }"
            "      : text   { alignment = centered; label = \"< Tab Name >\"; }"
            "    : column {"
            "      : text { alignment = centered; label = \"Suffix\"; }"
            "      : eBox { key = \"suff\"; edit_width = 15; edit_limit = 255; }"
            "  spacer;"
            "  : row { spacer;"
            "    : toggle { key = \"all\"; label = \"Apply to all Tabs\"; mnemonic = \"A\"; alignment = right; is_tab_stop = true; }"
            "  : errtile { } ok_cancel;"
            "//                        Find Dialog                         //"
            "find : dialog { label = \"Find and Replace\"; spacer;"
            "  : row {"
            "    : column { fixed_height = true;"
            "      : text { key = \"fw\"  ; label = \"Find What:\"           ; }"
            "      : fBox { key = \"fstr\"; edit_width = 30; mnemonic = \"W\"; }"
            "      : text { key = \"rw\"  ; label = \"Replace With:\"        ; }"
            "      : fBox { key = \"rstr\"; edit_width = 30; mnemonic = \"R\"; }"
            "    : spacer { width = 4; }"
            "      : spacer   { height = 0.2   ; }"
            "      : button16 { key = \"fnd\"  ; label = \"Find\"       ; mnemonic = \"F\"; }"
            "      : button16 { key = \"rep\"  ; label = \"Replace\"    ; mnemonic = \"p\"; }"
            "      : button16 { key = \"repa\" ; label = \"Replace All\"; mnemonic = \"A\"; }"
            "  spacer;"
            "  : text { key = \"ftxt\"; alignment = left; label = \"String not Found!\"; value = \"\"; }"
            "  spacer;"
            "  : button13 { key = \"accept\";    label = \"Done\"    ; mnemonic = \"o\"; is_default = true; is_cancel = true  ; }"
            "//                        Sort Dialog                         //"
            "sort : dialog { label = \"Sort\"; spacer;"
            "  : boxed_column { label = \"Sort Type\";"
            "    : popup_list { key = \"typ\"; alignment = centered; }"
            "    spacer;"
            "    : radio_row { children_alignment = centered;"
            "      : radio_button { key = \"asc\"; label = \"Ascending\" ; }"
            "      : radio_button { key = \"des\"; label = \"Descending\"; }"
            "    spacer;"
            "  spacer;"
            "  : row { fixed_width = false; alignment = centered;"
            "    : button13 { key = \"accept\"; label = \"Sort\"  ; mnemonic = \"S\"; is_default = true; }"
            "    : button13 { key = \"cancel\"; label = \"Cancel\"; mnemonic = \"C\"; is_cancel  = true; }"
            "//                        Help Dialog                         //"
            "help : dialog { key = \"htitle\";"
            "  spacer; : title { label = \"  ---------------------=={ TabSort.lsp }==---------------------  \" ; }"
            "  spacer; : title { label = \"Designed and Created by Lee Mac 2011\" ; }"
            "  spacer; : ltxt  { label = \"   Program Controls:\" ; }"
            "  spacer;"
            "  : row { fixed_width = true; alignment = centered;"
            "    : column {"
            "       : txt { label = \"[\"     ; }"
            "       : txt { label = \"-->\"   ; }"
            "    : column {"
            "       : txt { label = \"置顶\"          ; }"
            "       : txt { label = \"向上\"           ; }"
            "       : txt { label = \"向下\"         ; }"
            "       : txt { label = \"Bottom\"       ; }"
            "       : txt { label = \"Sort\"         ; }"
            "       : txt { label = \"Alphabetical\" ; }"
            "       : txt { label = \"Numerical\"    ; }"
            "       : txt { label = \"Architectural\"; }"
            "       : txt { label = \"Reverse\"      ; }"
            "       : txt { label = \"Pref/Suff\"    ; }"
            "       : txt { label = \"Add\"          ; }"
            "       : txt { label = \"Delete\"       ; }"
            "       : txt { label = \"Copy\"         ; }"
            "       : txt { label = \"Current\"      ; }"
            "       : txt { label = \"Find\"         ; }"
            "       : txt { label = \"确认\"         ; }"
            "       : txt { label = \"重置\"        ; }"
            "    : column {"
            "       : txt { label = \"]\"     ; }"
            "       : txt { label = \"<--\"   ; }"
            "    spacer;"
            "    : column {"
            "      : ltxt { label = \"Move selected Tabs to the top of the list.\"             ; }"
            "      : ltxt { label = \"Move selected Tabs up one notch in the list.\"           ; }"
            "      : ltxt { label = \"Move selected Tabs down one notch in the list.\"         ; }"
            "      : ltxt { label = \"Move selected Tabs to the bottom of the list.\"          ; }"
            "      : ltxt { label = \"Opens the Sort Dialog.\"                                 ; }"
            "      : ltxt { label = \"Sort the Tabs Alphabetically.\"                          ; }"
            "      : ltxt { label = \"Sort the Tabs Numerically.\"                             ; }"
            "      : ltxt { label = \"Sort the Tabs using an Architectural sorting method.\"   ; }"
            "      : ltxt { label = \"Reverse the Tab Order.\"                                 ; }"
            "      : ltxt { label = \"Opens the Prefix/Suffix Dialog.\"                        ; }"
            "      : ltxt { label = \"Adds a new layout Tab using the next available name.\"   ; }"
            "      : ltxt { label = \"Deletes the selected Tabs.\"                             ; }"
            "      : ltxt { label = \"Copies the selected Tabs.\"                              ; }"
            "      : ltxt { label = \"Makes the selected Tab the Current Tab.\"                ; }"
            "      : ltxt { label = \"Opens the Find and Replace Dialog.\"                     ; }"
            "      : ltxt { label = \"Finished sorting Tabs, will implement sorting.\"         ; }"
            "      : ltxt { label = \"Will reset Tab names and order - not deleted/added Tabs\"; }"
            "  spacer_1;"
            "  : title { label = \"-------------------------------------------------------------\" ; }"
            "  spacer_1; ok_only;"
            "//                        End of File                         //"
          (write-line line ofile)
        (while (not (findfile fname))) fname
  (defun _RemoveNth ( n l )
    (if (and l (< 0 n))
      (cons (car l) (_RemoveNth (1- n) (cdr l)))
      (cdr l)
  (defun _RenameTab ( dchand n lst / name )
    (cond
        (not (new_dialog "rename" dchand))
        (cond
          (Express
            (acet-ui-message "Error Loading Rename Dialog" "Warning" 16)
          (t
            (princ "\n** Error Loading Rename Dialog **")
        lst
      (t
        (set_tile  "name" (setq name (nth n lst)))
        (mode_tile "name" 2)
        (action_tile "name" "(setq name $value)")
        (action_tile "accept"
          (vl-prin1-to-string
            (quote
              (progn (set_tile "error" "")
                (cond
                    (eq "" name)
                    (set_tile "error" "Please Enter a Tab Name")
                    (wcmatch (strcase name) "*[<>\\/\\\":;`?`*|`,=]*")
                    (set_tile "error" "Invalid Symbol in Tab Name")
                    (vl-position (strcase name) (mapcar 'strcase (_RemoveNth n lst)))
                    (set_tile "error" (strcat name " already exists!"))
                  ( (done_dialog 1) )
        (if (= 1 (start_dialog))
          (cond
              (eq name (nth n lst))
              lst
              (vl-catch-all-error-p
                (vl-catch-all-apply 'vla-put-Name (list (vla-item aclay (nth n lst)) name))
              (cond
                (Express
                  (acet-ui-message "Error Renaming Tab" "Warning" 16)
                (t
                  (alert "\n** Error Renaming Tab **")
              lst
            ( (subst name (nth n lst) lst) )
          lst
  (defun _ListUp ( ind lst ) ; (Gile)
    (cond
      ( (or (null ind) (null lst))
        lst
      ( (= 0  (car ind))
        (cons (car  lst) (_ListUp (cdr (mapcar '1- ind)) (cdr lst)))
      ( (= 1  (car ind))
        (cons (cadr lst) (_ListUp (cdr (mapcar '1- ind)) (cons (car lst) (cddr lst))))
      ( t
        (cons (car  lst) (_ListUp (mapcar '1- ind) (cdr lst)))
  (defun _ListDown ( idx lst )
    (reverse
      (_ListUp
        (reverse
          (mapcar '(lambda ( x ) (- (1- (length lst)) x)) idx)
        (reverse lst)
  (defun _RemoveItems ( idx lst / i )
    (setq i -1)
    (vl-remove-if '(lambda ( x ) (member (setq i (1+ i)) idx)) lst)
  (defun _ListToTop ( idx lst )
    (append (mapcar '(lambda ( i ) (nth i lst)) idx) (_RemoveItems idx lst))
  (defun _ListToBottom ( idx lst )
    (append (_RemoveItems idx lst) (mapcar '(lambda ( i ) (nth i lst)) idx))
  (defun _ReverseItems ( idx lst )
      (lambda ( i l )
        (mapcar
          (function
            (lambda ( x )
              (if (member (setq i (1+ i)) idx)
                (setq x (nth (car l) lst)
                      l (cdr l)
          lst
      -1 (reverse (vl-sort idx '<))
  (defun _TabSort ( dchand lst )
    (or *SortTyp* (setq *SortTyp*   "0"))
    (or *SortOrd* (setq *SortOrd* "asc"))
    (cond
        (not (new_dialog "sort" dchand))
        (cond
          (Express
            (acet-ui-message "Error Loading Sort Dialog" "Warning" 16)
          (t
            (princ "\n** Error Loading Sort Dialog **")
        lst
      (t
        (_MakeList "typ" '("Alphabetical" "Numerical" "Architectural"))
        (set_tile "typ" *SortTyp*)
        (set_tile *SortOrd*   "1")
        (action_tile "typ" "(setq *SortTyp* $value)")
        (action_tile "asc" "(setq *SortOrd*   $key)")
        (action_tile "des" "(setq *SortOrd*   $key)")
        (if (zerop (start_dialog)) lst
            (cond
              ( (eq "0" *SortTyp*)
                (setq lst (acad_strlsort lst))
              ( (eq "1" *SortTyp*)
                (setq lst (_NumSort lst))
              ( (eq "2" *SortTyp*)
                (setq lst (_ArchSort lst))
            (if (eq "asc" *SortOrd*)
              lst
              (reverse lst)
  (defun _SplitStr ( str / lst test rslt num tmp ) ; (Gile)
    (setq lst  (vl-string->list str)
          test (chr (car lst))
    (if (< 47 (car lst) 58)
      (setq num T)
    (while (setq lst (cdr lst))
      (if num
        (cond
          ( (= 46 (car lst))
            (if
              (and
                (cadr lst)
                (setq tmp (strcat "0." (chr (cadr lst))))
                (numberp (read tmp))
              (setq rslt (cons (read test) rslt)
                    test tmp
                    lst  (cdr lst)
                    test "."
                    num nil
          ( (< 47 (car lst) 58)
            (setq test (strcat test (chr (car lst))))
          ( t
                  num  nil
          (setq rslt (cons test rslt)
                num  T
    (if num
      (setq rslt (cons (read test) rslt))
      (setq rslt (cons test rslt))
    (reverse rslt)
  (defun _ArchSort ( lst / comparable ) ; (Gile)
    (defun comparable ( e1 e2 )
      (or
        (and (numberp e1) (numberp e2))
        (= 'STR (type e1) (type e2))
        (not e1)
        (not e2)
    (mapcar '(lambda ( x ) (nth x lst))
      (vl-sort-i (mapcar '_SplitStr lst)
        (function
          (lambda ( x1 x2 / n1 n2 comp )
            (while
              (and
                (setq comp
                  (comparable (setq n1 (car x1)) (setq n2 (car x2)))
                (= n1 n2)
              (setq x1 (cdr x1) x2 (cdr x2))
            (if comp (< n1 n2) (numberp n1))
  (defun _NumSort ( lst )
      (vl-sort-i (mapcar '(lambda ( x ) (vl-remove-if-not 'numberp (_SplitStr x))) lst)
        (function
          (lambda ( a b )
            (while (and a b (= (car a) (car b)))
              (setq a (cdr a)
                    b (cdr b)
            (if (or a b) (< (car a) (car b)) t)
  (defun _DeleteTabs ( dchand idx lst / x )
    (cond
      (Express
        (setq x
          (acet-ui-message "The Selected Tab(s) Will be Permanently Deleted.\n\nProceed?" "Delete Tab(s)?" 52)
      ( (not (new_dialog "delwarn" dchand))
        (princ "\n** Error Loading Delete Dialog **")
      (t
        (action_tile "accept" "(setq x 6) (done_dialog)")
        (start_dialog)
    (if (= 6 x)
      (if
          (vl-catch-all-apply
           '(lambda nil
              (foreach i idx (vla-delete (vla-item aclay (nth i lst))))
        (cond
          (Express
            (acet-ui-message "Error Deleting Tab(s)" "Warning" 16)
          (t
            (alert "\n** Error Deleting Tab(s) **")
        (setq lst (_RemoveItems idx lst))
    lst
  (defun _TabPrefixSuffix ( dchand idx lst / pref suff item tmp i )
    (or *prefdef* (setq *prefdef* 0))
    (cond
      ( (not (new_dialog "prefsuff" dchand))
        (cond
          (Express
            (acet-ui-message "Error Loading Prefix/Suffix Dialog" "Warning" 16)
          (t
            (princ "\n** Error Loading Prefix/Suffix Dialog **")
        lst
      (t
        (set_tile "all" (itoa *prefdef*))
          (vl-prin1-to-string
            (quote
                (cond
                    (and
                      (not (eq "" (setq pref (get_tile "pref"))))
                      (wcmatch (strcase pref) "*[<>\\/\\\":;`?`*|`,=]*")
                    (set_tile "error" "Invalid Symbol in Prefix")
                    (mode_tile "pref" 2)
                    (and
                      (not (eq "" (setq suff (get_tile "suff"))))
                      (wcmatch (strcase suff) "*[<>\\/\\\":;`?`*|`,=]*")
                    (set_tile "error" "Invalid Symbol in Suffix")
                    (mode_tile "suff" 2)
                    (and (zerop *prefdef*) (setq tmp (mapcar 'strcase (_RemoveItems idx lst)))
                      (vl-some
                        (function
                          (lambda ( x )
                            (vl-position (strcase (strcat pref x suff)) tmp)
                        (mapcar '(lambda ( x ) (nth x lst)) idx)
                    (set_tile "error" "Amendment would create Duplicate tab")
                  ( (done_dialog 1) )
        (action_tile "all" "(setq *prefdef* (atoi $value))")
          (cond
              (zerop *prefdef*)
              (setq i -1)
              (setq lst
                (mapcar
                  (function
                    (lambda ( x )
                          (vla-put-name (vla-item aclay x) (strcat pref x suff))
                  lst
              t
              (setq lst
                (mapcar
                  (function
                    (lambda ( x )
                  lst
    lst
  (defun _AddTab ( lst / tmp i upp )
    (setq tmp "Layout1" i 1 upp (mapcar 'strcase lst))
    (while (member (strcase tmp) upp)
      (setq tmp (strcat "Layout" (itoa (setq i (1+ i)))))
    (vla-add aclay tmp)
    (append lst (list tmp))
  (defun _CopyTab ( idx lst / upp oldname oldlay newname i objlst newlay newblk )
    (setq upp (mapcar 'strcase lst))
    (foreach x idx
      (setq oldname (nth x lst)
            oldlay  (vla-item aclay oldname)
            newname (strcat oldname " (2)")
            i       2
            objlst  nil
      (while (member (strcase newname) upp)
        (setq newname (strcat oldname " (" (itoa (setq i (1+ i))) ")"))
      (setq newlay (vla-add aclay newname)
            newblk (vla-get-block newlay)
            lst    (append lst (list newname))
      (vla-copyfrom newlay oldlay)
      (if
        (vlax-for o (vla-get-block oldlay)
          (setq objlst (cons o objlst))
        (vla-copyobjects acdoc
          (vlax-make-variant
            (vlax-safearray-fill
              (vlax-make-safearray vlax-vbobject (cons 0 (1- (length objlst)))) (reverse objlst)
          newblk
    lst
  (defun _FindReplaceTab ( dchand lst / fstr rstr found tab idx flen i nstr rlen m n )
    (cond
        (not (new_dialog "find" dchand))
        (cond
          (Express
            (acet-ui-message "Error Loading Find and Replace Dialog" "Warning" 16)
          (t
            (princ "\n** Error Loading Find & Replace Dialog **")
        lst
      (t
        (set_tile "ftxt" "")
        (set_tile "fstr" (setq fstr ""))
        (set_tile "rstr" (setq rstr ""))
        (action_tile "fstr" "(set_tile \"ftxt\" \"\") (setq found nil fstr $value)")
        (action_tile "rstr" "(setq rstr $value)")
        (action_tile "fnd"
          (vl-prin1-to-string
            (quote
                (cond
                    found
                    (set_tile "ftxt" (caar found))
                    (setq tab   (cadar  found)
                          idx   (caddar found)
                          found (cdr    found)
                    t
                    (cond
                        (eq fstr "")
                        (set_tile "ftxt" "Please Enter a String to Find.")
                        (setq found nil tab nil idx nil)
                      (t
                        (setq flen (strlen fstr) i 0)
                        (foreach x lst
                          (while (setq i (vl-string-search (strcase fstr) (strcase x) i))
                            (setq found
                              (cons
                                (list
                                  (strcat (substr x 1 i) "[" (substr x (1+ i) flen) "]" (substr x (+ i flen 1)))
                                  i
                                found
                              i (+ i flen)
                        (setq found (reverse found))
                        (cond
                            found
                                  idx   (caddar found)
                                  found (cdr    found)
                            t
                            (set_tile "ftxt" "String not Found.")
                            (setq tab nil idx nil)
        (action_tile "rep"
          (vl-prin1-to-string
            (quote
                (cond
                    (not tab)
                    (wcmatch rstr "*[<>\\/\\\":;`?`*|`,=]*")
                    (set_tile "ftxt" "Invalid Symbol in Replace String.")
                    (member
                      (vl-string-trim " "
                        (strcase
                          (setq nstr
                            (strcat (substr tab 1 idx) rstr (substr tab (+ 1 idx flen)))
                    (set_tile "ftxt" "Replacement would create Duplicate Tab.")
                    t
                    (vla-put-Name (vla-item aclay tab) nstr)
                    (set_tile "ftxt" (strcat (get_tile "ftxt") "  ->  " nstr))
                    (setq lst (subst nstr tab lst))
                    (setq found
                      (mapcar
                        (function
                          (lambda ( x )
                            (if (eq tab (cadr x))
                                (if (< idx (setq i (caddr x)))
                                  (setq i (+ (caddr x) (- (strlen rstr) flen)))
                                (setq i (vl-string-search (strcase fstr) (strcase nstr) i))
                                (list
                                  (strcat (substr nstr 1 i) "[" (substr nstr (1+ i) flen) "]" (substr nstr (+ i flen 1)))
                                  nstr
                                  i
                        found
        (action_tile "repa"
          (vl-prin1-to-string
            (quote
                (cond
                    (eq fstr "")
                    (setq found nil)
                    t
                    (setq n 0
                          flen (strlen fstr)
                          rlen (strlen rstr)
                    (foreach tab lst
                      (setq m n
                            i 0
                            nstr tab
                      (while (setq i (vl-string-search (strcase fstr) (strcase nstr) i))
                        (setq nstr (strcat (substr nstr 1 i) rstr (substr nstr (+ 1 i flen)))
                                 i (+ i rlen)
                                 m (1+ m)
                      (if (not (member (strcase nstr) (mapcar 'strcase lst)))
                          (vla-put-name (vla-item aclay tab) nstr)
                          (setq n   m
                    (set_tile "ftxt"
                      (if (< 0 n)
                        (strcat (itoa n) " Replacements Made.")
                        "String not Found."
        (start_dialog)
    lst
  (defun _TabSortHelp ( dchand title )
    (cond
        (not (new_dialog "help" dchand))
        (cond
          (Express
            (acet-ui-message "Error Loading Help Dialog" "Warning" 16)
          (t
            (princ "\n** Error Loading Help Dialog **")
      (t
        (set_tile "htitle" title)
        (start_dialog)
  (defun _ListDupes ( l )
    (if l
      (if (vl-position (car l) (cdr l))
        (cons (car l) (_ListDupes (vl-remove (car l) (cdr l))))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        aclay (vla-get-layouts acdoc)
  (if (not (vl-file-directory-p (setq SavePath (_GetSavePath))))
      (princ "\n** Save Path not Valid **") (exit)
  (setq dclfname (strcat SavePath "\\LMAC_TabSort_V" TabSortVersion# ".dcl")
        dcltitle (strcat "TabSort V" (vl-string-translate "-" "." TabSortVersion#))
  (setq Express
    (and (vl-position "acetutil.arx" (arx))
      (not
          (vl-catch-all-apply
            (function (lambda nil (acet-sys-shift-down)))
  (cond
      (not (_WriteDCL dclfname))
      (cond
        (Express
          (acet-ui-message "DCL File Could not be Written" "Warning" 16)
        (t
          (princ "\n** DCL File Could not be Written **")
      (< (setq dch (load_dialog dclfname)) 0)
      (cond
        (Express
          (acet-ui-message "DCL File not Found" "Warning" 16)
        (t
          (princ "\n** DCL File not Found **")
      (not (new_dialog "tabsort" dch))
      (cond
        (Express
          (acet-ui-message "Error Loading TabSort Dialog" "Warning" 16)
        (t
          (princ "\n** Error Loading TabSort Dialog **")
    (t
      (_StartUndo acdoc)
      (setq dclst  (mapcar 'vla-get-Name (_GetLayouts aclay))
            resLst dclst
      (set_tile "dcltitle" dcltitle)
      (_MakeList "tabs" dclst)
      (set_tile "tabs"
        (setq ptr
          (if (zerop (getvar 'TILEMODE))
            (itoa (vl-position (getvar 'CTAB) dclst))
            "0"
      (action_tile "tabs"
        (vl-prin1-to-string
          (quote
            (progn (setq ptr $value)
              (if (= 4 $reason)
                  (_MakeList "tabs" (setq dclst (_RenameTab dch (atoi ptr) dclst)))
                  (set_tile "tabs" ptr)
      (action_tile "up"
        (vl-prin1-to-string
          (quote
              (setq
                idx (_value->list ptr)
                old (mapcar '(lambda ( x ) (nth x dclst)) idx)
              (_MakeList "tabs" (setq dclst (_ListUp idx dclst)))
              (set_tile  "tabs"
                (setq ptr
                  (_list->value (mapcar '(lambda ( x ) (vl-position x dclst)) old))
      (action_tile "down"
        (vl-prin1-to-string
          (quote
              (setq
              (_MakeList "tabs" (setq dclst (_ListDown idx dclst)))
              (set_tile  "tabs"
                (setq ptr
      (action_tile "mtop"
        (vl-prin1-to-string
          (quote
              (_MakeList "tabs" (setq dclst (_ListToTop (setq idx (_value->list ptr)) dclst)))
              (setq i -1)
              (set_tile "tabs"
                (setq ptr
                  (_list->value (mapcar '(lambda ( x ) (setq i (1+ i))) idx))
      (action_tile "mbot"
        (vl-prin1-to-string
          (quote
              (_MakeList "tabs" (setq dclst (_ListToBottom (setq idx (_value->list ptr)) dclst)))
              (setq i (length dclst))
              (set_tile "tabs"
                (setq ptr
                  (_list->value (reverse (mapcar '(lambda ( x ) (setq i (1- i))) idx)))
      (action_tile "sort"
        (vl-prin1-to-string
          (quote
              (setq
              (_MakeList "tabs" (setq dclst (_TabSort dch dclst)))
              (set_tile  "tabs"
                (setq ptr
      (action_tile "rev"
        (vl-prin1-to-string
          (quote
              (_MakeList "tabs" (setq dclst (_ReverseItems (_value->list ptr) dclst)))
      (action_tile "del"
        (vl-prin1-to-string
          (quote
              (setq
                tmp dclst
              (setq newres
                (_RemoveItems
                  (mapcar '(lambda ( x ) (1- (vla-get-TabOrder (vla-item aclay x)))) old)
                  resLst
              (_MakeList "tabs"
                (setq dclst
                  (cond
                    ( (_DeleteTabs dch idx dclst) )
                    ( (mapcar 'vla-get-Name (_GetLayouts aclay)) )
              (if (not (equal tmp dclst)) (setq resLst (cond ( newres ) ( dclst ))))
              (set_tile "tabs"
                (setq ptr
                    "0"
      (action_tile "p_s"
        (vl-prin1-to-string
          (quote
              (_MakeList "tabs" (setq dclst (_TabPrefixSuffix dch (_value->list ptr) dclst)))
      (action_tile "res"
        (vl-prin1-to-string
          (quote
              (cond
                  (_ListDupes (mapcar 'strcase resLst))
                  (cond
                    (Express
                      (acet-ui-message "Resetting would create Duplicate Tabs" "Warning" 48)
                    (t
                      (alert "Resetting would create Duplicate Tabs")
                  t
                  (_MakeList "tabs" (setq dclst resLst))
                  (mapcar 'vla-put-Name (_GetLayouts aclay) resLst)
                  (set_tile "tabs"
                    (setq ptr
                        "0"
      (action_tile "add"
        (vl-prin1-to-string
          (quote
              (_MakeList "tabs" (setq dclst (_AddTab dclst)))
              (setq resLst (append resLst (list (last dclst))))
              (set_tile "tabs" (setq ptr (itoa (1- (length dclst)))))
      (action_tile "cur"
        (vl-prin1-to-string
          (quote
              (setvar "CTAB" (nth (setq ptr (car (_value->list ptr))) dclst))
              (set_tile "tabs" (setq ptr (itoa ptr)))
      (action_tile "copy"
        (vl-prin1-to-string
          (quote
              (setq
                tmp dclst
                i   (1- (length dclst))
                j   i
              (_MakeList "tabs" (setq dclst (_CopyTab idx dclst)))
              (setq resLst
                (append resLst
                  (mapcar '(lambda ( x ) (nth (setq i (1+ i)) dclst)) idx)
              (set_tile "tabs"
                (setq ptr
                  (_list->value (mapcar '(lambda ( x ) (setq j (1+ j))) idx))
      (action_tile "fnr"
        (vl-prin1-to-string
          (quote
              (_MakeList "tabs" (setq dclst (_FindReplaceTab dch dclst)))
      (action_tile "help" "(_TabSortHelp dch (strcat dcltitle \" - Help\"))")
      (start_dialog)
      (setq dch (unload_dialog dch))
      (cond
          (equal (setq dclst (mapcar 'strcase dclst))
            (mapcar 'strcase
                (setq aclays (_GetLayouts aclay))
        (t
          (foreach lay aclays
            (vla-put-TabOrder lay
              (1+ (vl-position (strcase (vla-get-Name lay)) dclst))
      (_EndUndo acdoc)
(vl-load-com) (princ)
(princ
  (strcat
    "\n:: TabSort.lsp | Version " (vl-string-translate "-" "." TabSortVersion#) " | ?Lee Mac 2011 www.lee-mac.com ::"
    "\n:: Type \"TabSort\" to Invoke ::"
;;                         End of File                        ;;
GMT+8, 2025-5-19 19:48 , Processed in 0.216566 second(s), 27 queries , Gzip On.
