查看: 984|回复: 1
[提问] vl-file-delete删除只读文件代码的使用方法
发表于 2017-12-25 10:23:45 | 显示全部楼层 |阅读模式
就是先把文件改为只读取,这个代码国外论坛找的,但是怎么用?没看明白....例如我想把文件只读属性去掉。
  1. (defun SetRO (/ afile fso ofile ro)
  2.    (cond
  3.      ((and (setq aFile (getfiled "" "" "" 4))
  4.            (setq fso (vlax-create-object "Scripting.FilesystemObject"))
  5.            (setq oFile (vlax-invoke fso 'GetFile aFile))
  6.       )
  7.       (vlax-put-property oFile 'Attributes (setq ro (- 1 (logand 1 (vlax-get-property oFile 'Attributes)))))
  8.       (princ (strcat "File set to " (nth ro '("Read-write" "Read-only"))))
  9.       (vlax-release-object oFile)
  10.       (vlax-release-object fso)
  11.      )
  12.    )
  13.    (princ)
  14. )
发表于 2021-8-17 11:53:41 | 显示全部楼层
  • (defun av:att-RO-f ()
  •   (and
  •     (findfile file)
  •     (setq fso (vlax-create-object "Scripting.FilesystemObject"))
  •     (setq oFile (vlax-invoke fso 'GetFile File));易报错(发生意外),原因尚不清楚
  • ;查询文件的读写属性,0为可读写,1为只读,返回参数为ATT。
  • (defun av:get-att-RO (file / att);需要引用属性参数时,ATT参数外置即可
  •   (av:att-RO-f)
  •   (setq att (logand 1 (vlax-get-property oFile 'Attributes)))
  • ;文件属性读写修改,value=0为可写,1为只读,2为改变读写属性
  • (defun av:put-att-RO (file value)
  •   (cond
  •     ((av:att-RO-f)
  •       (if (= value 2)(setq value (- 1 (logand 1 (vlax-get-property oFile 'Attributes)))))
  •       (vlax-put-property oFile 'Attributes value)
  •       (princ (strcat "\n文件" file "属性已设为:" (nth value '("可读写!" "只读!"))))
  •       (vlax-release-object oFile)
  •       (vlax-release-object fso)
如果只想改为可读写
(av:put-att-RO file 0)
GMT+8, 2025-5-16 16:37 , Processed in 0.162079 second(s), 26 queries , Gzip On.
