查看: 1741|回复: 2
[基础] DBX 修改块名报错 (已解决)
发表于 2017-12-28 09:15:45 | 显示全部楼层 |阅读模式
    public void DrawingPretreatment()//String fileFullName, String curNumber)
            String fileFullName = @"E:\001.dwg";
            String curNumber = "1";
            string progid = "ObjectDBX.AxDbDocument.16";
            AxDbDocument objDbx = (AxDbDocument)acadApp.GetInterfaceObject(progid);
            objDbx.Open(fileFullName, null);
            foreach (AcadEntity entity in objDbx.ModelSpace)
                switch (entity.EntityName)
                    case "AcDbBlockReference":
                        AcadBlockReference blkRef;
                        blkRef = (AcadBlockReference)entity;
                        try
                            blkRef.Name = blkRef.Name + curNumber;//这里出错
                        catch (Autodesk.AutoCAD.Runtime.Exception ex)
                            throw new System.Exception(ex.Message);
                        break;
                    case "AcDbOrdinateDimension":
                        break;
            objDbx.SaveAs(fileFullName, null);
            objDbx = null;
AutoCAD 2005  & vs2008
 楼主| 发表于 2018-1-2 20:10:42 | 显示全部楼层
神啊,救救我吧!
 楼主| 发表于 2018-1-9 09:55:29 | 显示全部楼层
换成.net 模式解决。
                                tempDb.ReadDwgFile(curFileName, System.IO.FileShare.ReadWrite, true, null);
                                using (Transaction curTrans = tempDb.TransactionManager.StartTransaction())
                                    BlockTable curBt = (BlockTable)curTrans.GetObject(tempDb.BlockTableId, OpenMode.ForRead);
                                    int i = 1;
                                    foreach (ObjectId acObjId in curBt)
                                        BlockTableRecord br = curTrans.GetObject(acObjId, OpenMode.ForWrite) as BlockTableRecord;
                                        if (br.Name.StartsWith("_OPEN") || br.Name.StartsWith("DimnDraft"))
                                            br.Name = spStr[0].Remove(0, 3) + "-" + i.ToString();
                                            i++;
                                    // 以写模式打开块表记录ModelSpace(模型空间)
                                    BlockTableRecord acBlkTblRec;
                                    acBlkTblRec = curTrans.GetObject(curBt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                                    foreach (ObjectId acObjId in acBlkTblRec)
                                        Entity cc = curTrans.GetObject(acObjId, OpenMode.ForWrite) as Entity;
                                        if (cc.GetType().Name == "OrdinateDimension")
                                            OrdinateDimension od = cc as OrdinateDimension;
                                            od.DimensionText = "";
                                            //od.UpgradeOpen();
                                        if (cc.GetType().Name == "RotatedDimension")
                                            RotatedDimension rd = cc as RotatedDimension;
                                            rd.DimensionText = "";
                                            //rd.UpgradeOpen();
                                    curTrans.Commit();
GMT+8, 2025-12-27 04:15 , Processed in 0.160638 second(s), 22 queries , Gzip On.
