查看: 1758|回复: 1
dcl控件如何显示变量
发表于 2004-3-10 19:29:00 | 显示全部楼层 |阅读模式
再对话框设计dcl程序中写         value=abc; 其中abc 为lisp程序的全局变量 ,value并不能显示abc的值,而是显示字母abc,请问如何让控件的值显示某一变量。
发表于 2004-3-10 19:41:00 | 显示全部楼层
value = "string";
Specifies the initial value of a tile. Possible value is a quoted string. The meaning of a tile's value varies depending on the kind of tile. The value of a tile can change at runtime through user input or set_tile calls.
The value attribute of a tile is not considered when the dialog box is laid out. After the layout is finished and the dialog box has been displayed, new_dialog uses the value attributes to initialize each tile in the dialog box. A tile's value attribute has no effect on the size or spacing of tiles in the dialog box.
只能运行时通过Set_tile来设定,如
(set_tile "keyname" (rtos abc))
GMT+8, 2025-5-14 03:29 , Processed in 0.178503 second(s), 25 queries , Gzip On.
