查看: 2287|回复: 5
[资源] 求大神指点!有角度就没发用。参照旋转
发表于 2018-1-25 14:21:48 | 显示全部楼层 |阅读模式
(defun c:RR()
     (setvar "cmdecho" 0)
         (princ "\n选择对象 :")
         (SETQ OBJ ( SSGET))
          (setq a(getpoint "\n确定基点: "))
         (command "rotate" OBJ "" a "r" pause "")
发表于 2018-1-25 15:26:40 | 显示全部楼层
(defun c:RR ()
  (princ "\n选择对象 :")
  (SETQ OBJ (SSGET))
  (setq a (getpoint "\n确定基点: "))
  (command "rotate" OBJ "" a "r")
  (while (= (logand (getvar "CmdActive") 1) 1)
    (command pause)
 楼主| 发表于 2018-1-26 11:46:49 | 显示全部楼层
Andyhon 发表于 2018-1-25 15:26
(defun c:RR ()
  (princ "\n选择对象 :")
要重复按两两次起点!可以搞成按一次起点吗?
发表于 2018-1-26 11:59:11 | 显示全部楼层
试试合不合用===>
(command "rotate" OBJ "" a "r" a)
 楼主| 发表于 2018-1-26 12:15:56 | 显示全部楼层
Andyhon 发表于 2018-1-26 11:59
试试合不合用===>
可以了!谢谢!!
发表于 2018-1-26 16:46:11 | 显示全部楼层
(defun c:AF(/ ss p1 ang1 ang2 ang)
(setq ss(ssget))
(setq p1(getpoint "指定基点:"))
(setq ang1(getangle p1"源点:"))
(setq ang2(getangle p1"目标点:"))
(setq ang(/(* 180.0(- ang2 ang1))pi))
(command "rotate" ss "" p1 ang)
GMT+8, 2025-5-19 19:56 , Processed in 0.146732 second(s), 25 queries , Gzip On.
