查看: 2027|回复: 4
[提问] sssetfirst 筛选提取同心圆的大圆和小圆
发表于 2018-1-26 11:39:14 | 显示全部楼层 |阅读模式
1明经币
;;后半部分太复杂,看不太明白,这段程序是删除同心圆大圆,想用sssetfirst函数改成筛选出同心圆大圆和小圆。或者用command "chprop"  “LA” “1”     将同心圆放入某层。
(defun c:cdx ( / CNT DATA EN HDL HHH IDX II RRR SS)
  (if (setq ii -1
            ss (ssget '((0 . "CIRCLE,ARC")))
    (repeat (sslength ss)
      (setq en        (ssname ss (setq ii (1+ ii)))
            hdl        (cdr (assoc 5 (entget en)));;;句柄
            cnt        (cdr (assoc 10 (entget en)));;圆心坐标
            rrr        (cdr (assoc 40 (entget en)));;半径
            idx        (strcat (rtos (car cnt) 2 2) "#" (rtos (cadr cnt) 2 2));;;X#Y
      (if (null (setq hhh (cdr (assoc idx data))))
        (setq data (cons (cons idx hdl) data))
        (if (> (cdr (assoc 40 (entget (handent hhh))))
               rrr
          (setq       hhh  (entdel (handent hhh))
                data (subst (cons idx hdl) (assoc idx data) data)
          (entdel en)
谢谢各位。
 楼主| 发表于 2018-1-26 20:21:26 | 显示全部楼层
(defun c:tt ();这是llsheng_73的程序,可以提取同心圆,就是没有对圆心rtos偏差,怎么改呢,刚学习几天还不会改
  (setq ss (ssget '((0 . "circle"))))
  (if ss
      (setq m (sslength ss)
            n 0
      (while (< n m)
        (setq e        (ssname ss n)
              n        (1+ n)
              l        n
              p        (assoc 10 (entget e)) ;;用rtos设置容差
              P        (vl-princ-to-string (list (nth 1 p) (nth 2 p)))
              a         nil
        (while (< l m)
          (setq        f  (ssname ss l)
                l  (1+ l)
                p1 (assoc 10 (entget f)) ;;用rtos设置容差
                P1 (vl-princ-to-string (list (nth 1 p1) (nth 2 p1)))
          (if (= p p1)
              (ssdel f ss)
              ;(entdel f)
              (command "layer" "m" 1 "" "change" f "" "p" "la" 1 "")
              (setq l (1- l)
                    m (1- m)
                    a t
        (if a
            (ssdel e ss)
           ;(entdel e)
            (command "layer" "m" 1 "" "change" e "" "p" "la" 1 "")
            (setq n (1- n)
                  m (1- m)
 楼主| 发表于 2018-1-27 23:38:34 | 显示全部楼层
;已解决。
(defun c:tt ()
  (setq ss (ssget '((0 . "circle,arc"))))
  (if ss
            n 0
      (while (< n m)
              n        (1+ n)
              l        n
              a         nil
        (while (< l m)
                l  (1+ l)
          (if (equal P P1 2) ;(< (distance P P1) 2)
              (ssdel f ss)
              ;(entdel f)
              (setq l (1- l)
                    m (1- m)
                    a t
        (if a
            (ssdel e ss)
           ;(entdel e)
            (setq n (1- n)
                  m (1- m)
发表于 2020-3-13 15:01:14 | 显示全部楼层
shopping200 发表于 2018-1-27 23:38
;已解决。
(defun c:tt ()
测试好像发现问题:对于圆心测量坐标值Y增加不起作用,Y值减小起作用,同样同心圆的一个圆将其X值减小则不起作用,X值增大可以实现程序的功能。应该改为对圆心点的距离容差吧?怎么改呢?
发表于 2021-1-9 16:44:10 | 显示全部楼层
哪位大神帮忙看看哪里不对啊 我要批量把外圆改成蓝色 内圆改成红色
(defun c:tt1 ()
  (if ss
            n 0
      (while (< n m)
              n        (1+ n)
              l        n
              r        (cdr (assoc 40 (entget e)))
              a         nil
        (while (< l m)
                l  (1+ l)
                rr  (cdr (assoc 40 (entget f)))
          (if (equal P P1 20)
              (ssdel f ss)
              (if (> r rr )
              (command "change" f "" "p" "c" 40 "")))
              (if (< r rr )
              (command "change" f "" "p" "c" 5 "")))
              (setq l (1- l)
                    m (1- m)
                    a t
        (if a
            (ssdel e ss)
              (if (> r rr )
              (command "change" e "" "p" "c" 5 "")))
              (if (< r rr )
              (command "change" e "" "p" "c" 40 "")))
            (setq n (1- n)
                  m (1- m)
GMT+8, 2025-5-17 09:31 , Processed in 0.162815 second(s), 23 queries , Gzip On.
