查看: 880|回复: 2
求助,怎么用VBA改标注
发表于 2018-2-1 12:33:41 | 显示全部楼层 |阅读模式
想用VBA把 图1 改成 图2,但现在只会把 图1 改成 图3 。怎么修改备注的文字观察方向?
  1. Sub 尺寸标注单个更改()
  2. Dim x As AcadObject
  3. Dim pt3(2) As Double, pt1(2) As Double, pt2(2) As Double
  4. pt1(0) = 0: pt1(1) = 0
  5. pt2(0) = 0: pt2(1) = 500
  6. pt3(0) = (pt1(0) + pt2(0)) / 2 + 120
  7. pt3(1) = pt1(1): pt3(2) = 0
  8. Set x = ThisDrawing.ModelSpace.AddDimAligned(pt1, pt2, pt3)
  9.     x.Color = acYellow
  10.     x.ArrowheadSize = 15
  11.     x.TextHeight = 30
  12.     x.TextSuffix = " 放外面"
  13.     x.TextRotation = 4.712389
  14.     x.VerticalTextPosition = acOutside
  15.     x.TextOutsideAlign = True
  16. End Sub
发表于 2018-2-1 14:11:45 | 显示全部楼层
试试 DimTxtDirection
 楼主| 发表于 2018-2-2 08:50:15 | 显示全部楼层
谢谢了,果然可以!!!:D
GMT+8, 2025-5-23 15:43 , Processed in 0.167025 second(s), 25 queries , Gzip On.
