很早以前放出的程序
相对块复制选择集
后来加入了副本随目标块旋转、镜像的功能
但一直没有时间针对210组码为(0 0 -1)的情况进行处理
今天有点空
把程序完善了一下
直接放上lsp和dcl文件供下载
————好像还不能直接上传附件
两个命令
AS 为指定图块组,添加关联选择集
ASR AS扩展,副本随目标图块旋转、镜像
文件需放到CAD支持目录下
或者自己手动修改程序路径
差什么函数说一下
;;;另存为【~~~adds```为指定的图块添加关联选择集.lsp】
 - ;;选择一个参照块和一个要关联复制的选择集。指定目标块组后,逐一按相对位置进行复制
- (defun c:as() (load "~~~adds```为指定图块组添加关联选择集.lsp") (setq rofollowblk "0") (c:adds))
- (defun c:asR() (load "~~~adds```为指定图块组添加关联选择集.lsp") (setq rofollowblk "1") (c:adds))
- (defun c:adds()
- (adds_load)
- (adds_err)
- (princ "\n为指定图块组,添加关联选择集【对话框启动...】")(princ)
- (setvar "cmdecho" 0)
- (setq blk NIL blkss NIL addss NIL)
- (setq adds_dcl (load_dialog "~~~adds.dcl"))
- (adds_startdcl)
- (adds_no_err)
- (princ)
- (defun adds_startdcl()
- (new_dialog "adds" adds_dcl "")
- (addsmode)
- (action_tile "rofollowblk" "(setq rofollowblk $value)(addsmode)")
- (action_tile "blksscosame" "(setq blksscosame $value)")
- (action_tile "sel_addss" "(done_dialog 2)")
- (action_tile "sel_blk" "(done_dialog 3)")
- (setq oke (start_dialog))
- (cond
- ((= oke 0)(adds_clear))
- ((= oke 2)(adds_sel_addss))
- ((= oke 3)(adds_sel_blk))
- ((= oke 8)(adds_dont_ro))
- ((= oke 9)(adds_do_ro))
- (defun addsmode()
- (if (= "0" rofollowblk)
- (progn
- (set_tile "rofollowblk" "0")
- (action_tile "sel_blkss" "(done_dialog 8)")
- (progn
- (set_tile "rofollowblk" "1")
- (action_tile "sel_blkss" "(done_dialog 9)")
- (if (/= "1" blksscosame) (setq blksscosame "0"))
- (set_tile "blksscosame" blksscosame)
- (addsettite)
- (defun addsettite()
- (if addss
- (if blk
- (progn
- (mode_tile "sel_addss" 1)
- (mode_tile "sel_blk" 1)
- (mode_tile "sel_blkss" 0)
- (mode_tile "sel_blkss" 2)
- (mode_tile "sel_blkss" 3)
- (progn
- (mode_tile "sel_blkss" 1)
- (mode_tile "sel_blk" 0)
- (mode_tile "sel_blk" 2)
- (mode_tile "sel_blk" 3)
- (progn
- (mode_tile "sel_addss" 0)
- (mode_tile "sel_addss" 2)
- (mode_tile "sel_addss" 3)
- (defun adds_clear()
- (if blk (redraw blk 4))
- (if addss (ssdraw addss 4))
- (defun adds_sel_addss()
- (princ "\n选择要关联添加的选择集...")
- (setq addss (ssget))
- (ssdraw addss 3)
- (adds_startdcl)
- (defun adds_sel_blk()
- (princ "\n指定参照图块...")
- (if (setq blk (ssget ":e:s" '((0 . "insert"))))
- (progn
- (setq blk (ssname blk 0))
- (setq blkinspo (trueINSPO blk))
- (setq blkco (dxf blk 62))
- (setq the_blk50 (dxf 50 blk))
- (if (= -1 (last (dxf 210 blk))) (setq the_blk50 (- PI the_blk50))) ;;获取图块的修正角度
- (setq blkname (dxf 2 blk))
- (redraw blk 3)
- (adds_startdcl)
- (defun adds_dont_ro()
- (princ "\n指定目标图块组...")
- (if (= blksscosame "1")
- (setq blkss (ssget (list '(0 . "insert") (cons 2 blkname)(cons 62 blkco))))
- (setq blkss (ssget (list '(0 . "insert") (cons 2 blkname))))
- (if (and blkss addss)
- (progn
- (setq blkss (ssdel blk (ssadd blk blkss)))
- (foreach x (ss2list blkss)
- (setq xinspo (trueINSPO x))
- (command "copy" addss "" "non" blkinspo "non" xinspo)
- (adds_startdcl)
- (defun adds_do_ro()
- (redraw blk 3)
- ;;重写代码【代码貌似ok】
- (if blkss
- (progn
- (setq blkss (ssdel blk (ssadd blk blkss))) ;;滤除参照块
- (if (= -1 (last (dxf 210 blk))) (blk-1to1 blk)) ;;如果参照块本身210是00-1,改为001
- (setq addssmidpo (getmidpo (ssbox addss))) ;;目标选择集的中心点
- (setq nipt (MAT:TransNested addssmidpo (list blk) 0 2)) ;;该中心点对应于参照块定义的坐标【nipt】
- (setq mirr_x_yn NIL mirr_y_yn NIL) ;;设定允许翻转初始值
- (setq nopt (btrans nipt x)) ;;获取nipt对应x的实际坐标
- ;;如果x本身210是00-1,改为001。同时设定副本需两次镜像
- (if (= -1 (last (dxf 210 x)))
- (progn (blk-1to1 x) (setq mirr_x_yn T mirr_y_yn T))
- ;;计算副本的旋转角
- (setq curr_blk50 (dxf 50 x))
- (setq cha50 (- curr_blk50 the_blk50))
- (setq ro50 (* (/ cha50 PI) 180.0))
- ;;;根据当前块的xy,再进行单次mirr的设定
- (if (> 0 (dxf 41 x))
- (setq mirr_x_yn (null mirr_x_yn))
- (if (> 0 (dxf 42 x))
- (setq mirr_y_yn (null mirr_y_yn))
- ;;复制副本并进行最终的旋转镜像处理
- (setq thelast (entlast))
- (command "copy" addss "" "non" addssmidpo "non" nopt)
- (setq newss (entbackss thelast))
- (command "rotate" newss "" "non" nopt ro50)
- (if mirr_x_yn
- (command "mirror" newss "" "non" nopt "non" (polar nopt (+ curr_blk50 d_090) 1000) "y")
- (if mirr_y_yn
- (command "mirror" newss "" "non" nopt "non" (polar nopt curr_blk50 1000) "y")
- (adds_clear)
- (adds_startdcl)
- (defun adds_err()
- (command "undo" "g")
- (setq adds_olderr *error* )
- (defun *error*(msg)
- (redraw)
- (command "undo" "e")
- (setq *error* adds_olderr)
- (princ)
- (defun adds_no_err()
- (redraw)
- (princ)
- (princ)
- (defun adds_load()
- (load "~~~adds```为指定图块组添加关联选择集.lsp")
- (setq thetiplist '( "AS 为指定图块组,添加关联选择集"
- "ASR AS扩展,选择集副本随目标图块旋转、镜像"
- (setq *ent2obj* vlax-Ename->Vla-Object
- d_090 (* PI 0.5)
- d_180 PI
- d_360 (* PI 2)
- (princ)
- ;999`````````````````````````````````````````````````````````````````````````````公共函数
- ;999公共函数
- ;;blk-1to1 将已确定210为00-1的图块更改为001
- (defun blk-1to1( b / pooo )
- (if (= -1 (caddr (dxf 210 b)))
- (progn
- (setq pooo (trueinspo b))
- (entmodsome b (list
- (cons 210 '(0 0 1))
- (cons 50 (- d_360 (dxf b 50)))
- (cons 41 (- (dxf b 41)))
- (cons 10 pooo)
- ;999公共函数
- ;;按指定的模式重画一个选择集的全部物体<改模式时,需要先反绘。1-2 3-4.(1->4=1->2->4)> 【支持模型多视口,支持布局中视口】
- ;; 1:显示 2:消隐 3:高亮 4:低亮
- (defun ssredraw( ss mode )
- (ssdraw ss mode)
- (defun ssdraw( ss mode / i ent vp )
- (if (= (strcase (getvar "ctab")) "MODEL")
- (if (member mode '(1 2 3 4))
- (foreach vp (reverse (vports))
- (setvar "cvport" (car vp))
- (cond
- ((= (type ss) 'PICKSET)
- (foreach ent (ss2list ss)
- (redraw ent mode)
- ((= (type ss) 'list)
- (foreach ent ss
- (redraw ent mode)
- ((= (type ss) 'ename)
- (redraw ss mode)
- (cond
- (redraw ent mode)
- (foreach ent ss
- (redraw ent mode)
- (redraw ss mode)
- (princ)
- ;999公共函数
- ;;y:gettrueINSPO 获取一个块的实际块心 (trans blk'dxf10 blk 1)
- ;;举例
- ;;(trueINSPO blockent)
- (defun trueINSPO( blkent / pt po )
- (setq pt (dxf 10 blkent))
- (if (setq po (trans pt blkent 1))
- po
- pt
- ;999公共函数
- ;;dxf 获取图元某个dxf组码(内参不限种类顺序::: n ent [entget ent] )
- (defun dxf( n ent / temp tmp )
- (if (/= (type n) 'int)
- (setq temp ent
- ent n
- n temp
- (if (= (type ent) 'ENAME)
- (setq temp (entget ent))
- (setq temp ent)
- (if (= n 62)
- (if (setq tmp (assoc n temp)) (cdr tmp) 256)
- (cdr (assoc n temp))
- ;999公共函数
- ;;求点对中点
- (defun getmidpo( pts / P1 P2 X Y )
- (setq p1 (car pts) p2 (cadr pts))
- (if (= (length p1) (length p2))
- nil
- (setq p1 (list (car p1) (cadr p1))
- p2 (list (car p2) (cadr p2))
- (mapcar '(lambda (X Y) (/ (+ X Y) 2.0)) P1 P2)
- ;999公共函数
- ;;选择集的最小(正交)包围框 ————选择集包含二次样条曲线时,包围框可能不准,暂时没解决的办法
- (defun ssbox( ss / ll ur aa bb )
- (if (= (type ss) 'PICKSET)
- (setq ss (ss2list ss))
- (foreach x ss
- (vla-getboundingbox (*ent2obj* x) 'll 'ur)
- (setq aa (cons (vlax-safearray->list ll) aa)
- bb (cons (vlax-safearray->list ur) bb)
- (mapcar '(lambda(a b) (apply 'mapcar (cons a b)))
- '(min max)
- (list aa bb)
- ;999公共函数
- ;;选择集转为图元列表
- (defun ss2list ( ss / n i elist )
- (cond
- ((null ss) NIL)
- ((and (= (type ss) 'Pickset) (null (sslength ss)))
- NIL
- ((= (type ss) 'Pickset)
- (setq n (sslength ss)
- i n
- elist '()
- (repeat n
- (setq i (1- i))
- ;;如果没有这个if,那么选择集中被删除的图元,也会被加入到列表之中————但是极其偶尔也有可能,图元不存在但是能entget(遇到过一次,原因不明,或许是CAD的BUG)
- (if (entget (ssname ss i))
- (setq elist (cons (ssname ss i) elist))
- elist
- (list ss)
- (vl-remove-if-not ''((x) (and (= (type x) 'ename) (entget x))) ss)
- ( T NIL )
- ;999公共函数
- (defun entbackss ( ent / backss)
- (if (and ent (*ent2obj* ent))
- (progn
- (setq backss (ssadd))
- (while (setq ent (entnext ent))
- (if (not (member (cdr (assoc 0 (entget ent))) '("ATTRIB" "VERTEX" "SEQEND")))
- (setq backss (ssadd ent backss))
- (if (zerop (sslength backss))
- (setq backss NIL)
- backss
- ;999公共函数
- ;;修改一个图元的多个数据 ——————不是所有的图元都适用此方式 ——————此函数尚未考虑组码不存在时的情况:比如62
- (defun entmodsome( ent dxfdatalist )
- (entmod (append (list (cons -1 ent)) dxfdatalist))
- ;999999999999999999999999999999999````````````````````````````以下是高飞鸟大侠的矩阵变换函数``````````很牛B的函数,但我感觉有BUG,求出的点Z坐标实际应该为0,但计算结果不为0。
- ; ————这或许也不是BUG,而是二进制计算导致的误差
- ; ————图块z坐标原来为0的好办,直接设为0即可消除误差。但是原来就不为0时,这个误差就不好处理了
- ;;; 块参照的变换矩阵和逆矩阵 ;;
- ;;; 功能: 某点在块内坐标系统和世界或者用户坐标系统的转换 ;;
- ;;; 参数: pt 要变换的点。 ;;
- ;;; rlst 用 nentselp或者nentsel得到的表的最后一项 ;; 就是图块主图元为元素的单表 (last (nentsel)) = (list (car (entsel))) = (<图元名: 75873f48>)
- ;;; from 坐标系:0,WCS; 1,当前UCS; 2,块参照坐标系RCS ;;
- ;;; to 坐标系:0,WCS; 1,当前UCS; 2,块参照坐标系RCS ;;
- ;;; MAT:TransNested (gile) ;;
- ;;; Translates a point coordinates from WCS or UCS to RCS ;;
- ;;; -coordinates system of a ;;
- ;;; reference (xref or block) whatever its nested level- ;;
- ;;; Arguments ;;
- ;;; pt : the point to translate ;;
- ;;; rlst : the parents entities list from the deepest nested ;;
- ;;; to the one inserted in current space -same as ;;
- ;;; (last (nentsel)) or (last (nentselp)) ;;
- ;;; from to : as with trans function: 0.WCS, 1.UCS, 2.RCS ;;
- ;999应用范例
- ;999::::已知图框块定义中,图签右上角点坐标,求该点位在世界坐标系中的坐标
- (setq po (MAT:TransNested '(-180 49) (list (car (entsel))) 2 0))
- ;;相对块定义的一点坐标,对应WCS中的坐标
- (defun btrans( pt blk )
- (MAT:TransNested pt (list blk) 2 0)
- (defun MAT:TransNested (pt rlst from to / GEOM)
- (and (= 1 from) (setq pt (trans pt 1 0)))
- (and (= 2 to) (setq rlst (reverse rlst)))
- (and (or (= 2 from) (= 2 to))
- (while rlst
- (setq geom (if (= 2 to)
- (MAT:RevRefGeom (car rlst))
- (MAT:RefGeom (car rlst))
- rlst (cdr rlst)
- pt (mapcar '+ (MAT:mxv (car geom) pt) (cadr geom))
- (if (= 1 to)
- (trans pt 0 1)
- pt
- ;;已知WCS中的坐标,求相对于块定义中的点坐标
- (defun transb( pt blk )
- (MAT:TransNested pt (list blk) 0 2)
- ;;; 功能:图块的变换矩阵 ;;
- ;;; 输入:块参照的图元名 ;;
- ;;; 输出:块参照的变换矩阵 ;;
- ;;; MAT:RefGeom (gile) ;;
- ;;; Returns a list which first item is a 3x3 transformation ;;
- ;;; matrix(rotation,scales normal) and second item the object ;;
- ;;; insertion point in its parent(xref, bloc or space) ;;
- ;;; Argument : an ename ;;
- (defun MAT:RefGeom ( ename / elst ang norm mat )
- (setq elst (entget ename)
- ang (cdr (assoc 50 elst))
- norm (cdr (assoc 210 elst))
- (list
- (setq mat (MAT:mxm
- (mapcar ''((v) (trans v 0 norm T))
- '((1.0 0.0 0.0) (0.0 1.0 0.0) (0.0 0.0 1.0))
- (MAT:mxm
- (list (list (cos ang) (- (sin ang)) 0.0)
- (list (sin ang) (cos ang) 0.0)
- '(0.0 0.0 1.0)
- (list (list (cdr (assoc 41 elst)) 0.0 0.0)
- (list 0.0 (cdr (assoc 42 elst)) 0.0)
- (list 0.0 0.0 (cdr (assoc 43 elst)))
- (mapcar '-
- (trans (cdr (assoc 10 elst)) norm 0)
- (MAT:mxv mat (cdr (assoc 10 (tblsearch "BLOCK" (cdr (assoc 2 elst))))))
- ;;; 功能:图块的变换矩阵的逆矩阵 ;;
- ;;; MAT:RevRefGeom (gile) ;;
- ;;; MAT:RefGeom inverse function ;;
- ;;; 输入:块参照的图元名 ;;
- ;;; 输出:块参照的变换矩阵的逆矩阵 ;;
- (defun MAT:RevRefGeom ( ename / entData ang norm mat )
- (setq entData (entget ename)
- ang (- (cdr (assoc 50 entData)))
- norm (cdr (assoc 210 entData))
- (list
- (list (list (/ 1 (cdr (assoc 41 entData))) 0.0 0.0)
- (list 0.0 (/ 1 (cdr (assoc 42 entData))) 0.0)
- (list 0.0 0.0 (/ 1 (cdr (assoc 43 entData))))
- (MAT:mxm
- '(0.0 0.0 1.0)
- (mapcar ''((v) (trans v norm 0 T))
- (mapcar '-
- (cdr (assoc 10 (tblsearch "BLOCK" (cdr (assoc 2 entData)))))
- (MAT:mxv mat (trans (cdr (assoc 10 entData)) norm 0))
- ;;; 矩阵相乘 ;;
- ;;; MAT:mxm Multiply two matrices -Vladimir Nesterovsky- ;;
- (defun MAT:mxm( m q )
- (mapcar ''((r) (MAT:mxv (MAT:trp q) r)) m)
- ;;; 向量或点的矩阵变换(向量乘矩阵) ;;
- ;;; Matrix x Vector - Vladimir Nesterovsky ;;
- ;;; Args: m - nxn matrix, v - vector in R^n ;;
- (defun MAT:mxv( m v )
- (mapcar ''((r) (apply '+ (mapcar '* r v))) m)
- ;;; 矩阵转置 ;;
- ;;; MAT:trp Transpose a matrix -Doug Wilson- ;;
- ;;; 输入:矩阵 ;;
- ;;; 输出:转置后的矩阵 ;;
- (defun MAT:trp( m )
- (apply 'mapcar (cons 'list m))
- ;;; 平齐实体的变换矩阵 -by highflybird ;;
- ;;; 输入:Ent - 实体名 ;;
- ;;; 输出:平齐这个实体的变换矩阵和它的逆矩阵 ;;
- (defun Mat:EntityMatrix (Ent / z dxf Cen obj an m1 mat Inv org)
- (setq dxf (entget ent))
- (if (setq Cen (cdr (assoc 10 dxf))) ;Insertpoint,center or startpoint,etc.
- (if (null (caddr Cen))
- (setq Cen (append Cen '(0.0)))
- (setq Cen '(0 0 0))
- (setq obj (vlax-ename->vla-object Ent))
- (if (and (vlax-property-available-p obj 'elevation) ;If it has elevation value.
- (wcmatch (vla-get-objectname obj) "*Polyline") ;It's a "AcDb2dPolyline" or "AcDbPolyline" object
- (setq z (vla-get-elevation obj)
- Cen (list (car Cen) (cadr Cen) (+ (caddr Cen) z)) ;add elevation value
- (if (vlax-property-available-p obj 'rotation) ;if it has a rotaion angle
- (setq an (vla-get-rotation obj))
- (setq an 0)
- (MAT:Trans1 0 Ent Cen an) ;return two matrices, the first is WCS->OCS,the second is OCS->WCS
- ;;; 通用变换矩阵 by highflybird ;;
- ;;; 输入:from - 原坐标系, ;;
- ;;; to - 目的坐标系, ;;
- ;;; Org - 目的坐标系的原点相对原坐标系的位置 ;;
- ;;; Ang - 相对于原坐标系的旋转角度 ;;
- ;;; 输出:两个矩阵,一个是从原坐标系变换到目的坐标系的变换矩阵;;
- ;;; 一个是从目的坐标系变换到原坐标系的变换矩阵 ;;
- (defun MAT:Trans1 (from to Org Ang / Mat Rot Inv Cen)
- (setq Mat (mapcar ''((v) (trans v from to T))
- '((1. 0. 0.) (0. 1. 0.) (0. 0. 1.))
- (if (not (equal ang 0 1e-14))
- (setq Rot (list (list (cos ang) (- (sin ang)) 0.)
- (list (sin ang) (cos ang) 0.)
- (list 0. 0. 1.)
- mat (MAT:mxm mat Rot)
- (setq Cen (trans Org to from))
- (setq Inv (mat:trp mat))
- (list
- (Mat:DispToMatrix Inv (mat:mxv Inv (mapcar '- Cen))) ;from->to (trans pt from to)
- (Mat:DispToMatrix mat Cen) ;to->from (trans pt to from)
- ;;; Append displacement vector to a matrix -Highflybird- ;;
- ;;; 把位移矢量添加到矩阵中 ;;
- ;;; 输入:mat -- 矩阵(3x3),disp -- 位移矢量 ;;
- ;;; 输出:一个4X4的变换CAD的标准变换矩阵 ;;
- (defun Mat:DispToMatrix (mat disp)
- (append
- (mapcar 'append mat (mapcar 'list disp))
- '((0. 0. 0. 1.))
- (princ)
;;;另存为【~~~adds.dcl】
 - spacer_x : spacer {
- height = 0.4;
- width = 0.4;
- horizontal_margin = none;
- vertical_margin = none;
- adds : dialog {
- label = "为指定图块组复制关联选择集";
- : boxed_column {
- children_alignment = centered; width= 36; fixed_width = true;
- //spacer_1;
- : button {label= "指定关联选择集"; key= "sel_addss"; width= 24; fixed_width = true; height = 2.5;}
- spacer_1;
- //: row {
- : button {label= "指定参照图块"; key= "sel_blk"; width= 24; fixed_width = true; height = 2.5;}
- // : toggle {key = "sameco";label = "指定颜色";}
- spacer_1;
- : button {label= "指定目标图块组"; key= "sel_blkss"; width= 24; fixed_width = true; height = 2.5;}
- spacer_1;
- : boxed_column {
- spacer_x;
- : row {
- spacer_1;spacer_1;spacer_1;
- : toggle {key = "rofollowblk"; label = "随目标图块旋转、镜像";}
- spacer_1;
- spacer_x;
- : row {
- : toggle {key = "blksscosame"; label = "目标组与参照图块同色";}
- spacer_1;
- spacer_x;
- spacer_1;
- : row {
- spacer_0;
- : button {label = "取消"; key = "cancel"; is_cancel = true; width = 6; fixed_width=true; height = 1; }
- spacer_0;
- spacer_1;
