查看: 4463|回复: 13
[提问] 如何获取界址线的界址线位置等扩展属性
发表于 2018-3-15 11:00:31 | 显示全部楼层 |阅读模式
在做地籍的时候,需要对界址线的属性如界址线位置,界址线类别等的赋值,请问用LSP如何获取界址线的这些扩展属性呢?请大神们不吝赐教。
就是如下图的这个属性。
发表于 2018-3-20 06:27:55 | 显示全部楼层
(defun c:tt (/ en)
  (if (setq en (car (entsel)))
      (while (and
               (setq en (entnext en))
               (/= (cdr (assoc 0 (entget en))) "SEQEND")
        (princ (assoc -3 (entget en '("*"))))
发表于 2018-3-16 11:32:57 | 显示全部楼层
;获取扩展数据
(defun zg-GetxData (obj / xtypeOut xdataOut)
        (if (= (type obj) 'ENAME)
                (setq obj (vlax-ename->vla-object obj))
        (if (= (type obj) 'VLA-OBJECT)
                        (vla-GetXData obj "" 'xtypeOut 'xdataOut)
                        (if xdataOut
                                (mapcar 'vlax-variant-value (vlax-safearray->list xdataOut))
(zg-GetxData (vlax-ename->vla-object (car (entsel))))
选择对象:
("SOUTH" "300000" "006021JC00126" "张强" "072" "QHDM" "130223" "SJZGBM" ""
"FRDBXM" "张强" "FRDBZMS" "130223195601287818" "FRDBDH" "13933336078" "DLRXM" ""
"DLRSFZ" "" "DLRDH" "" "TXDZ" "滦县榛子镇南平庄村安5排60号" "TDZL" "滦县榛子镇南平庄村" "DONGZHI"
"富民路" "NANZHI" "平安街" "XIZHI" "" "BEIZHI" "昌达街" "QSLYZM" "土地证" "PZTDYT" "住宅"
"TDSYZ" "" "SBJZWQS" "" "YBDJH" "006021JC00126" "TDZH" "滦集建(99)第165074号" "SHRQ"
"" "DJRQ" "" "ZZRQ" "" "DWXZ" "09 个人" "QSXZ" "40 集体土地使用权" "SYQLX" "22 拨用宅基地"
"TDDJ" "" "MPH" "" "TUFU" "4407.25-484.50" "JZMJ" 129.263 "BDDJ" 0.0 "SBDJ" 0.0)
发表于 2018-3-16 11:32:07 | 显示全部楼层
(setq entdata (assoc -3 (entget (car (entsel)) '("*"))))
选择对象:
(-3
        ("SOUTH" (1000 . "300000") (1000 . "006021JC00126") (1000 . "张强") (1000 . "072"))
        ("QHDM" (1000 . "130223"))
        ("SJZGBM" (1000 . ""))
        ("FRDBXM" (1000 . "张强"))
        ("FRDBZMS" (1000 . "130223195601287818"))
        ("FRDBDH" (1000 . "13933336078"))
        ("DLRXM" (1000 . ""))
        ("DLRSFZ" (1000 . ""))
        ("DLRDH" (1000 . ""))
        ("TXDZ" (1000 . "滦县榛子镇南平庄村安5排60号"))
        ("TDZL" (1000 . "滦县榛子镇南平庄村"))
        ("DONGZHI" (1000 . "富民路"))
        ("NANZHI" (1000 . "平安街"))
        ("XIZHI" (1000 . ""))
        ("BEIZHI" (1000 . "昌达街"))
        ("QSLYZM" (1000 . "土地证"))
        ("PZTDYT" (1000 . "住宅"))
        ("TDSYZ" (1000 . ""))
        ("SBJZWQS" (1000 . ""))
        ("YBDJH" (1000 . "006021JC00126"))
        ("TDZH" (1000 . "滦集建(99)第165074号"))
        ("SHRQ" (1000 . ""))
        ("DJRQ" (1000 . ""))
        ("ZZRQ" (1000 . ""))
        ("DWXZ" (1000 . "09 个人"))
        ("QSXZ" (1000 . "40 集体土地使用权"))
        ("SYQLX" (1000 . "22 拨用宅基地"))
        ("TDDJ" (1000 . ""))
        ("MPH" (1000 . ""))
        ("TUFU" (1000 . "4407.25-484.50"))
        ("JZMJ" (1040 . 129.263))
        ("BDDJ" (1040 . 0.0))
        ("SBDJ" (1040 . 0.0))
(assoc -3 (entget (car (entsel)) '("SOUTH")))
(-3 ("SOUTH" (1000 . "300000") (1000 . "006021JC00126") (1000 . "张强") (1000 . "072")))
(assoc -3 (entget (car (entsel)) '("FRDBXM")))
(-3 ("FRDBXM" (1000 . "张强")))
 楼主| 发表于 2018-3-15 11:27:18 | 显示全部楼层
看来做这个的人不多啊
 楼主| 发表于 2018-3-16 10:49:40 | 显示全部楼层
今天有人吗,能给解答一下吗
 楼主| 发表于 2018-3-19 18:08:08 | 显示全部楼层
感谢namezg,宗地的属性我可以获取,但是我想获取的是界址线的属性,就是我附图的几个属性。
 楼主| 发表于 2018-3-19 18:09:14 | 显示全部楼层
namezg 发表于 2018-3-16 11:32
;获取扩展数据
希望您可以帮我看能否把每一段的界址线的属性提取出来,我又重新上传了一个附件,完善一下界址线的属性。
 楼主| 发表于 2018-3-20 08:44:11 | 显示全部楼层
q3_2006 发表于 2018-3-20 06:27
(defun c:tt (/ en)
大神,请受我一拜!!!:P
发表于 2018-3-20 09:07:12 | 显示全部楼层
命令: appload 已成功加载 jjj.fas。
命令:
命令:
命令: jjj
选择对象: (注:选取界址线)
本宗地编号: 130223006021JC00131  起点号: J4634 → 止点号: J4635 图上边长: 14.029
本宗地编号: 130223006021JC00131  起点号: J4635 → 止点号: J4636 图上边长: 8.039
本宗地编号: 130223006021JC00131  起点号: J4636 → 止点号: J4637 图上边长: 2.704
本宗地编号: 130223006021JC00131  起点号: J4637 → 止点号: J4638 图上边长: 6.261
本宗地编号: 130223006021JC00131  起点号: J4638 → 止点号: J4639 图上边长: 1.259
本宗地编号: 130223006021JC00131  起点号: J4639 → 止点号: J4640 图上边长: 2.841
本宗地编号: 130223006021JC00131  起点号: J4640 → 止点号: J4641 图上边长: 14.065
本宗地编号: 130223006021JC00131  起点号: J4641 → 止点号: J4642 图上边长: 4.100
本宗地编号: 130223006021JC00131  起点号: J4642 → 止点号: J4643 图上边长: 8.883
本宗地编号: 130223006021JC00131  起点号: J4643 → 止点号: J4634 图上边长: 8.039
选择对象:
GMT+8, 2025-5-19 07:21 , Processed in 0.203614 second(s), 28 queries , Gzip On.
