查看: 1879|回复: 9
[讨论] 各位高手求助看下这个程序如何修改!!!(如何让标注的界址点号从西北角开始顺时...
发表于 2018-4-2 16:56:34 | 显示全部楼层 |阅读模式
(defun err(msg)
   (princ msg);"*cancel*")
   (restore)
(defun init()
   (command "_.undo" "be")
   (setq dimzin (getvar "dimzin"))
   (setvar "dimzin" 1)
   (setq os (getvar "osmode"))
   (setvar "osmode" 0)
   (setvar "cmdecho" 0)
   (setq errtmp *error*)
   (setq *error* err)
(defun restore()
   (setq *error* errtmp)
   (setvar "dimzin" dimzin)
   (setvar "osmode" os)
   (command "_.undo" "e")
(defun xl-sort (lst fun / nlst)
   (foreach n lst (setq nlst (xl-isort n nlst fun))))
(defun xl-isort (item lst fun / k nlst)
   (setq k T
         nlst (apply 'append (mapcar '(lambda (x)
                                        (if (and K ((eval fun) item x)) (progn (setq k nil) (list item x)) (list x))
                                        ) lst))
   (if k (append lst (list item)) nlst)
(defun setcolor(sname color / sinf)
   (setq sinf (entget sname))
   (if (assoc 62 sinf)
     (setq sinf (subst (cons 62 color) (assoc 62 sinf) sinf))
     (setq sinf (append sinf (list (cons 62 color))))
   (entmod sinf)
(defun MakeText(pt Height Ang str / dxf)
   (setq dxf '((0 . "TEXT") (100 . "AcDbEntity") (67 . 0) (410 . "Model")(8 . "JZP")(100 . "AcDbText")))
   (setq dxf (append dxf (list (cons 10 pt) (cons 40 height) (cons 50 Ang) (cons 1 str))))
   (setq dxf (append dxf '((41 . 0.8) (51 . 0.0) (71 . 0) (72 . 0)
                           (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 0))))
   (entmake dxf)
(defun MakeText2(pt Height Ang str / dxf)
   (setq dxf '((0 . "TEXT") (100 . "AcDbEntity") (67 . 0) (410 . "Model")(8 . "JZP")(100 . "AcDbText")(10 0.0 0.0 0.0)))
   (setq dxf (append dxf (list (cons 11 pt) (cons 40 height) (cons 50 Ang) (cons 1 str))))
   (setq dxf (append dxf '((41 . 0.8) (51 . 0.0) (71 . 0) (72 . 1)
                           (210 0.0 0.0 1.0) (100 . "AcDbText") (73 . 2))))
   (entmake dxf)
(defun MakeText3(pt Height Ang str / dxf)
   (setq dxf (append dxf (list (cons 11 pt) (cons 40 height) (cons 50 Ang) (cons 1 (strcat "J" str)))))
   (entmake dxf)
(defun OpPts(pts pt h scal / pti ptn ptc ang len params pts2 i)
   (setq pts_tmp nil)
   (if (equal (distance (car pts) (last pts)) 0 0.00000000001) (setq pts (cdr pts)))
   (setq pts2 (xl-sort pts '(lambda(e1 e2) (< (abs (- (angle pt e1) (/ pi 4))) (abs (- (angle pt e2) (/ pi 4)))))))
(setq i 1)
  (mapcar '(lambda(e)
              (MakeText3 (polar e (angle pt e) h) h 0.0 (itoa i))
              (setq i (1+ i))
            ) pts)
   (mapcar '(lambda(e)
              (MakeText2 (polar (cadr e) (+ (/ pi 2) (car e)) (* 0.75 h))
                h
                (if (and (> (car e) (/ pi 2.0)) (< (car e) (* pi 1.5)))
                         (- (car e) pi)
                  (car e)
                (rtos (last e) 2 2)))
           params)
(defun GetVer(ent / pts ents)
   (while (/= (cdr (assoc 0 (setq ents (entget (setq ent (entnext ent)))))) "SEQEND")
     (setq pts (append pts (list (cdr (assoc 10 ents)))))
   pts
(defun GETPL (ED / ENTS PTS)
   (setq ENTS (entget ED))
   (while (setq ENTS (member (assoc 10 ENTS) ENTS))
     (setq PTS (append PTS (list (cdar ENTS))))
     (setq ENTS (CDR ENTS))
   PTS
(defun Order(pts / n pt ang angn angi angAll pt pti)
   (setq n (length pts))
   (setq pt (list (/ (apply '+ (mapcar 'car pts)) n)
                  (/ (apply '+ (mapcar 'cadr pts)) n)))
   (setq ang (angle pt (car pts)))
   (setq angAll 0)
   (foreach pti (append (cdr pts) (list(car pts)))
     (setq angn (angle pt pti))
     (setq angi (- angn ang))
     (cond
       ((> angi pi) (setq angi (- angi (* pi 2))))
       ((< angi (- pi)) (setq angi (+ angi (* pi 2))))
     (setq angAll (+ angAll angi))
     (setq ang angn)
   (cond
     ((equal angAll 0 1) (list pt nil))
     ((> angAll 0) (list pt nil))
     ((< angAll 0) (list pt t))
(defun DoubleM(ent / ents pt pts l h x y h2)
   (setq ents (entget ent))
   (if (= (cdr (assoc 0 ents)) "TEXT")
       (setq pt (cdr (assoc 10 ents)))
       (setq pts (textbox ents))
       (setq l (caadr pts))
       (setq h (cdr (assoc 40 ents)))
       (setq x (+ l (* h 0.4)))
       (setq y (* h 0.7))
       (setq h2 (* h 0.5))
       (MakeText (list (+ (car pt) x) (+ (cadr pt) y)) h2 0 "2")
(defun c:zdt( / pts pt pti ptn ptc ang params)
   (init)
   (setq Scale (getstring "\n请输入比例尺<1:200>:"))
   (if (= Scale "")
       (setq blc "1:200")
       (setq nScale 1)(setq h 0.45)
       (setq nScale (/ (atof scale) 200))
       (setq blc (strcat "1:" scale))
       (setq h (* 0.60 (/ (atof scale) 200) ))
   (setq ent (car  (entsel "\n请选择图形...")))
   (setq pts (getpl ent))
   (if (cadr (setq pt (Order (reverse pts))))
     (setq pts (reverse pts))
   (setq pt (car pt))
   (setq xc (* 0.0 nscale))
  (command "_.pedit" ent "w" xc "")
   (setcolor ent 1)
   (OpPts pts pt h nscale)
   (princ "\n\nEnd!")
   (restore)
发表于 2018-4-2 20:22:56 | 显示全部楼层
  1. (defun c:zdt (/ pts wnp dil dis)
  2.   (setq        pts
  3.          (mapcar 'cdr
  4.                  (vl-remove-if
  5.                    (function (lambda (x) (/= (car x) 10)))
  6.                    (entget (car (entsel)))
  7.                  )
  8.          )
  9.   )
  10.   (or
  11.     (< (apply
  12.          '+
  13.          (mapcar
  14.            (function
  15.              (lambda (pt1 pt2)
  16.                (- (* (car pt1) (cadr pt2)) (* (cadr pt1) (car pt2)))
  17.              )
  18.            )
  19.            (cons (last pts) pts)
  20.            pts
  21.          )
  22.        )
  23.        0
  24.     )
  25.     (setq pts (reverse pts))
  26.   )
  27.   (setq wnp (list (apply 'min (mapcar 'car pts)) (apply 'max (mapcar 'cadr pts))))
  28.   (setq diL (mapcar (function (lambda (pt) (distance pt wnp))) pts))
  29.   (setq dis (vl-position (apply 'min diL) diL))
  30.   (or (= dis 0)
  31.       (repeat dis
  32.         (setq pts (append (cdr pts) (list (car pts))))
  33.       )
  34.   )
  35.   (setq dis 0)
  36.   (setq dil (append pts (list (car pts))))
  37.   (foreach pt pts
  38.     (entmakex
  39.       (list
  40.         '(0 . "TEXT")
  41.         '(100 . "AcDbEntity")
  42.         '(67 . 0)
  43.         '(8 . "0")
  44.         '(410 . "Model")
  45.         '(100 . "AcDbText")
  46.         '(10 0.0 0.0 0.0)
  47.         (cons 11 (polar pt (+ (angle pt (cadr dil)) (* pi 0.5)) 8))
  48.         (cons 40 5.0)
  49.         (cons 1 (strcat "J" (itoa (setq dis (1+ dis)))))
  50.         '(41 . 0.8)
  51.         '(51 . 0.0)
  52.         '(71 . 0)
  53.         '(72 . 1)
  54.         '(210 0.0 0.0 1.0)
  55.         '(100 . "AcDbText")
  56.         '(73 . 2)
  57.       )
  58.     )
  59.     (setq dil (cdr dil))
  60.   )
  61.   (princ)
  62. )
 楼主| 发表于 2018-4-3 22:26:30 | 显示全部楼层
高手感谢您的帮助,谢谢
发表于 2018-4-4 16:55:05 | 显示全部楼层
看着很不错的样子啊,学习学习。。。
发表于 2018-4-4 16:59:08 | 显示全部楼层
lhngxy 发表于 2018-4-3 22:26
高手感谢您的帮助,谢谢
会有字体编号重复
 楼主| 发表于 2018-4-4 17:43:52 | 显示全部楼层
7#
应该是你的闭合线有重复节点把?
发表于 2018-10-28 08:31:47 | 显示全部楼层
看着很不错的样子啊,学习学习。。。
GMT+8, 2025-5-19 03:12 , Processed in 0.181620 second(s), 26 queries , Gzip On.
