查看: 1138|回复: 2
[提问] 请教关于倒角标注的改进
发表于 2018-4-17 14:46:13 | 显示全部楼层 |阅读模式
5明经币
下面是根据Z大的程序改的,可以实现非45°倒角标注。
现在有一个小问题,在标45°线的时候,还要右键确认一下,能否把右键确认这一步去掉呢?在此先谢过了
;倒角标注
(defun c:13()
(setvar "cmdecho" 0)
(princ "\n请选择一条直线:")
(setq ss (ssget":e:s" '((0 . "line"))))
(if (= ss nil)
(progn (setq hou "禁止倒角")(pdbz))
(setvar 'osmode 0)  ;关闭捕捉
(setq dl (entget (ssname ss 0))
      p1 (cdr (assoc 10 dl))
      p2 (cdr (assoc 11 dl))
       x (abs (- (car p1) (car p2)))
       y (abs (- (cadr p1) (cadr p2))))
(if (equal x y 1e-4)
(princ (rtos x 2 3))
(setq tt (getstring tt)
tt (if (= tt "") (rtos x 2 3) tt)
tt (strcat tt "*45%%D")
p4 (polar p1 (angle p1 p2) (* (distance p1 p2) 0.5)))
(setq ang (/ pi 4))
(if (setq p3 (getpoint p4 "\n请确定文字位置:"))
(command "leader" p4 p3 "" "" "" tt "") ) )
(command "dimlinear" p1 p2 "\\" "dimlinear" p1 p2)
(setvar 'osmode 1)  ;打开捕捉
(princ))
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
;倒角标注 (defun c:13() (setvar "cmdecho" 0) (princ "\n请选择一条直线:") (setq ss (ssget":e:s" '((0 . "line")))) (if (= ss nil) (progn (setq hou "禁止倒角")(pdbz)) (progn (setvar 'osmode 0) ;关闭捕捉 (setq dl (entget (ssname ss 0)) p1 (cdr (assoc 10 dl)) p2 (cdr (assoc 11 dl)) x (abs (- (car p1) (car p2))) y (abs (- (cadr p1) (cadr p2)))) (if (e ...
发表于 2018-4-17 14:46:14 | 显示全部楼层
;倒角标注
(defun c:13()
(if (= ss nil)
  (setq tt (strcat (rtos x 2 3) "*45%%D")
(setq ang (/ pi 4))
(princ))
 楼主| 发表于 2018-4-17 16:10:37 | 显示全部楼层
bssurvey 发表于 2018-4-17 14:46
;倒角标注
(defun c:13()
非常好用,谢谢
GMT+8, 2025-5-19 17:30 , Processed in 0.185094 second(s), 26 queries , Gzip On.
