查看: 1228|回复: 1
[源码] 提取txt文件中的数字源码
发表于 2018-4-21 16:13:40 | 显示全部楼层 |阅读模式
发一个程序,用于提取txt文件中的数字。
并按行分组,组成一个列表。
(defun c:tt()
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (setq cf (open "C:\\Users\\zz12344121\\Desktop\\A9R5B09.txt" "r"))
  (setq n 1);预设行值1
  (setq cnlist nil);初始化文本内容序列
  (setq comment (READ-LINE cf))
  (if comment
    (setq cn (cons n comment))
    (setq cnlist (cons cn cnlist))
      (alert "NO COMMENT")
      (exit)
  (while comment
    (setq n (1+ n))
  (setq cnlist (reverse cnlist))
  (close cf)
  ;;获取数据列表后,开始
  ;;;提取字符串中的数据
  (setq zong_numlist nil)
  (setq j 1);第一行
  (repeat (length cnlist)
   (setq i 1);字符串中第一个数
   (setq numlist nil)
          (setq hh (cdr (assoc j cnlist)));第j行字符串
       (if hh
   (while (<= i (strlen hh))
     (setq num (substr hh i 1))
     (setq i (1+ i))
     (if (and (>= (ascii num) 46) (<= (ascii num) 57));数字和乘除
  ;(setq i (1+ i))
  (setq num_next (substr hh i 1))
  (while (and (>= (ascii num_next) 46) (<= (ascii num_next) 57));数字和乘除
    (setq num (strcat num num_next));数据累积
    (setq i (1+ i))
  (setq i (1+ i));下一个字符不为数字,继续加,下次又判断一次
  (setq numlist (cons num numlist))
   (setq numlist (reverse numlist));每行提取完毕
    (if numlist
    (setq zong_numlist (cons numlist zong_numlist))
    (setq j (1+ j))
  (setq zong_numlist (reverse zong_numlist));提取完毕
发表于 2018-4-24 07:11:43 | 显示全部楼层
  1. ;; tt(提取txt文件中的数字)
  2. (defun c:tt ()
  3.   (setq        lst (xyp-Txt2List "d:\\临时.txt")
  4.         lst (mapcar '(lambda (x) (xyp-get-HzEngNum x 3)) lst)
  5.         lst (vl-remove nil lst)
  6.   )
  7.   (princ lst)
  8.   (princ)
  9. )
GMT+8, 2025-10-25 03:48 , Processed in 0.161268 second(s), 26 queries , Gzip On.
