查看: 3588|回复: 10
[源码] 求助:经典输出面积与周长源码,langjs写的
发表于 2018-4-24 22:16:01 | 显示全部楼层 |阅读模式
既然发消息给我那就编一个。使用时不保证100%正确。
;;; 框选封闭区域面积到excel    by:langjs
(defun c:qq (/ d ent f i lst m2 obj pt ss txt x y)
(setq TextHeight (getdist "\n输入标注文字高度:")
Textbh (getstring "\n输入编号前缀:"))
  (defun maketext (txt pt)             ; 生成文字子函数
    (entmake (list '(0 . "TEXT") (cons 62 1) (cons 10 pt) (cons 40 TextHeight) (cons 1 txt) '(41 . 0.8)))
  (setvar "cmdecho" 0)
  (vl-load-com)
  (setq ss (ssget) ent (entlast))
  (command ".region" ss "")
  (setq ss (ssadd)  lst nil)
  (while (setq ent (entnext ent))
    (if (= (cdr (assoc 0 (entget ent))) "REGION")
      (setq obj (vlax-ename->vla-object ent) pt (vlax-safearray->list (vlax-variant-value (vla-get-centroid obj)))
            m2 (rtos (vla-get-area obj) 2 2) d (rtos (vla-get-perimeter obj) 2 2) lst (cons (list pt m2 d) lst)
  )                (setq txt (vla-get-perimeter obj))
  (command ".undo" "")
  (setq lst (vl-sort lst (function (lambda (x y)(< (car (car x)) (car (car y)))))))
  (setq lst (vl-sort lst (function (lambda (x y)(> (cadr (car x)) (cadr (car y)))))))
  (setq f (getfiled "指定输出文件路径" "" "xls" 1) f (open f "a"))
  (write-line "编号\t周长(mm)\t面积(mm2)" f)
  (setq i 1)
  (foreach x lst
    (setq pt (car x) m2 (cadr x) d (caddr x))
    (maketext (strcat Textbh (itoa i)) (list (car pt) (+ (cadr pt) (* 1.2 TextHeight))))
    (maketext (strcat "L=" d "mm") pt)
    (maketext (strcat "S=" m2 "mm2") (list (car pt) (- (cadr pt) (* 1.2 TextHeight))))
    (write-line (strcat (strcat Textbh (itoa i)) "\t" d "\t" m2) f)
    (setq i (1+ i))
  (close f)
红色的那句是我自已加的,程序可以通过,但是不知道为什么提示那句表达式:错误: 参数类型错误: streamp nil,想了好久,本人实在木瓜脑壳想不出来,只能求助大师,如果要那句话定义,不知道如何写???
本帖被以下淘专辑推荐:
  • · 学习|主题: 95, 订阅: 9
发表于 2018-4-24 22:30:38 | 显示全部楼层
  1. ;; 功能: 输出封闭多边形边长及面积 到 EXCEL 文件
  2. ;; 编写: yxp   2017-3-31   QQ:9034598
  3. ;; (vla-get-area (vlax-ename->vla-object (car (entsel "\n选择多段线: "))))
  4. (vl-load-com)
  5. (defun c:mjs ( / ent ob S L A d H xy xzz old)
  6.   (setq old (getvar "osmode") ent (entlast))
  7.   (mapcar '(lambda(x)(setvar x 0))(list "cmdecho" "osmode" "delobj"))
  8.   (vl-cmdf "_region" (ssget ":L") "")
  9.   ;(vla-AddRegion )
  10.   (while (setq ent (entnext ent))
  11.     (setq ob (vlax-ename->vla-object ent)
  12.       L (vla-get-perimeter ob)
  13.       A (vla-get-Area ob)
  14.       H (/ (sqrt A) 12.0)
  15.       S (cdr (assoc 5 (entget ent))) ;; (itoa (if n (setq n (1+ n))(setq n 1)))
  16.       d (cons (list S L A) d)
  17.       xy (vlax-safearray->list (vlax-variant-value (vla-get-centroid ob)))
  18.       xy (polar xy 0 (* -4.0 H))
  19.       xzz (cons (list (list S (list (car xy)(+ (cadr xy) (* 1.5 H))) H)
  20.         (list (strcat "S= " (rtos L 2)) xy H)
  21.         (list (strcat "C= " (rtos A 2))(list (car xy)(- (cadr xy)(* 1.5 H))) H)) xzz))
  22.     (entdel ent)
  23.   )
  24.   (foreach x xzz (foreach y x (apply 'MxTxt y)))
  25.   (if d (SaveExcel (cons '("编号" "周长" "面积") (reverse d))))
  26.   (setvar "osmode" old)
  27.   (princ)
  28. )
  29. (defun SaveExcel( Lit / a r c d)
  30.   (if (null *appxls*) (princ "\n程序首次运行需要打开 excel 程序,请耐心等候..."))
  31.   (setq *appxls* (vlax-get-or-create-object "excel.application"))
  32.   (setq a (vl-catch-all-error-p (vl-catch-all-apply 'vlax-get-property (list *appxls* "sheets"))))
  33.   (vlax-invoke-method (vlax-get-property *appxls*  (if a "workbooks" "sheets")) "add")
  34.   (setq newite (vlax-get-property (vlax-get-property *appxls* "sheets") "item" 1)
  35.     xlscells (vlax-get-property newite "cells")
  36.     r 0 c 0)
  37.   (vla-put-visible *appxls* 1)
  38.   (repeat (length Lit)
  39.     (setq d (nth r Lit) r (1+ r))
  40.     (repeat (length d)
  41.       (vlax-put-property xlscells "item" r (1+ c)
  42.         (vl-princ-to-string (nth c d)))
  43.       (setq c (1+ c))
  44.     )(setq c 0)
  45.   )
  46.   (vlax-release-object xlscells)
  47.   (vlax-release-object newite)
  48.   (vlax-release-object *appxls*)
  49. )
  50. (defun MxTxt(s p H)(entmake (list '(0 . "TEXT")(cons 1 s)(cons 10 p)(cons 40 H))))
  51. (princ "\n文件加载成功,请输入 mjs 命令")
  52. (princ)
 楼主| 发表于 2018-4-24 22:42:51 | 显示全部楼层
谢谢回复, 我想知道上面那句(setq txt (vla-get-perimeter obj)),不对的话,我改用了
(setq str "d")
  (atof str)     就是想取"d"这个字符串来转成实数进行加减,可是还是不可以,不知道如何才行呢 ??
发表于 2018-4-24 22:48:22 | 显示全部楼层
(setq str "d") ...
(atof "d")  返回 0.0  有什么意义?
 楼主| 发表于 2018-4-24 22:52:10 | 显示全部楼层
,在这个程式里,选取图形后,那个d输出的是周长数值,我就是想提取这个数值进行四则运算
发表于 2018-4-24 23:01:15 | 显示全部楼层
四则运算可以用字符串 strcat 组成表达式,比如 "(+ 5 5)" ,数字可以是变量,然后用下面函数求值。
(eval (read "(+ 5 5)"))
 楼主| 发表于 2018-4-24 23:31:48 | 显示全部楼层
不明白,举个例子
(setq   cc 20   vv  100   )
(setq xx  (/ ( (eval (read "+d")) (* cc (* vv )) ) 1) );;;这样表达可以吗
发表于 2018-4-24 23:47:46 | 显示全部楼层
不语勿语 发表于 2018-4-24 23:31
不明白,举个例子
(setq xx  (/ ( (eval (read "+d")) (* cc (* vv )) )  ...
汗,搞了半天你对 lisp 一窍不通啊,你那表达式,语法都不对。
(* vv ) 少个乘数,能这么写吗?
多看看基础语法。
我又试了一下, (* vv ) 返回 vv
 楼主| 发表于 2018-4-24 23:58:14 | 显示全部楼层
少写了
(setq xx  (/ ( *(eval (read "+d+")) (* cc (* vv )) ) 1) )
 楼主| 发表于 2018-4-24 23:59:06 | 显示全部楼层
不懂呀,呵呵,能说明白点不
GMT+8, 2025-10-25 03:48 , Processed in 0.154933 second(s), 27 queries , Gzip On.
