查看: 3131|回复: 5
多段线节点坐标提取
发表于 2018-5-15 19:19:31 | 显示全部楼层 |阅读模式
(defun c:jdzbtq();;;节点坐标提取
  (vl-load-com)
  (setvar "cmdecho" 0)
  (COMMAND ".UNDO" "BE")
  (setvar "dimzin" 0)
  (princ "\n 选取PLINE多段线...")
  (setq ss (ssget '((0 . "LWPOLYLINE"))))
  (if (/= ss nil)
  (setq fn (getfiled "\n 文件保存为" "d:/多段线节点坐标" "txt" 1))
  (setq ff  (open fn "w"))
  ;;(princ "点号,X坐标,Y坐标" ff)
  ;;(princ "\n" ff)  ;换一行输入
  (setq s1(mapcar'(lambda(x)(cons x (plinexy x)))(sstoes ss)) i 0 pp 0)
  (repeat(length s1)
    (setq ss(nth i s1) h(dxf (car ss) 38) nn 0)
    (repeat (length(cdr ss))
      ;;(setq str(strcat(itoa (+ pp 1))","(itoa (+ i 1))","(rtos(cadr(nth nn(cdr ss)))2 4)","(rtos(car(nth nn(cdr ss)))2 4)","(rtos h 2 3)) nn(+ nn 1)  pp(+ pp 1))
      (setq str(strcat(itoa (+ pp 1))","(rtos(car(nth nn(cdr ss)))2 4)","(rtos(cadr(nth nn(cdr ss))) 2 4)) nn(+ nn 1)  pp(+ pp 1))
      (write-line str ff))
    (setq i(+ i 1))
  (close ff)
  (princ "\n  cass数据格式导出完成!")
  (startapp "notepad.exe" fn)
(defun lst-(l1 l2)(if l2(foreach x l2(setq l1(vl-remove x l1)))l1))
(defun dxf (ent i) (if(= (type ent) 'ename) (setq ent (entget ent)) )  (cdr (assoc i ent)) )
(defun SstoEs(ss / a lst)
  (if ss(progn(setq a -1)(repeat(sslength ss)(setq lst(cons(ssname ss(setq a(1+ a)))lst))))))
(defun plinexy(e / a q m p p1)
    (setq a(vlax-ename->vla-object e)
          q(vlax-safearray->list(vlax-variant-value(vla-get-Coordinates a)))
          m(if(=(vla-get-objectname a)"AcDb3dPolyline")
             '(setq p1(list (car q)(cadr q)(caddr q))q(cdddr q))
             '(setq p1(list (car q)(cadr q))q (cddr q))))
    (while q(eval m) (setq p(if(member p1 p)p(append p(list p1))))))
发表于 2022-4-26 12:56:35 | 显示全部楼层
能在图中增加节点编号功能吗?工作中用的比较多
发表于 2023-2-22 16:53:29 | 显示全部楼层
大佬,能改成以米为单位,保留三位小数吗?
 楼主| 发表于 2024-6-18 14:28:45 | 显示全部楼层
批量多段线坐标标注  节点编号  导出坐标
http://bbs.mjtd.com/forum.php?mo ... amp;fromuid=7322630
(出处: 明经CAD社区)
GMT+8, 2025-5-24 15:47 , Processed in 0.165469 second(s), 23 queries , Gzip On.
