查看: 922|回复: 4
[讨论] 输出到指定路径
发表于 2018-5-21 21:17:33 | 显示全部楼层 |阅读模式
论谈上的的,很好用,只是每次都要选择路径,输入文件名。如何加一语名,选择范围后,使其输出到指定的路径,固定的文件名。比如F:\1.DXF
请高手们帮忙修改一下。
;;快速输出dxf
(DEFUN C:EXP( / GRP PATH NAME)
(PRINC "\Hellow^…^朋友")
(SETVAR "CMDECHO" 0)
(SETVAR "osmode" 0)
(PRINC "\n DXF快速输出!!!");
(SETQ pt1 (getpoint"请选择左上角:"))
(PRINC "")
(SETQ k 1)
(SETQ pt2 (getpoint"请选择右下角:"))
(COMMAND "SCALE" "w" pt1 pt2 "" pt1 k)
(SETQ PATH (GETVAR "DWGPREFIX")) ;获取FILEPATH
(SETQ NAME (GETFILED "DXF档案输出快选" PATH "DXF" 15))
(SETVAR "FILEDIA" 0)
(COMMAND "_DXFOUT" NAME "V" "R12" "O" "W" PT1 PT2  "" "")
(COMMAND "SCALE" "w" pt1 pt2 "" pt1 1)
(SETVAR "FILEDIA" 1)
(SETVAR "CMDECHO" 1)
(SETVAR "osmode" 3)
(PRINC "\n 文件已输出")
(PRINC)
发表于 2018-5-22 02:44:26 | 显示全部楼层
(SETVAR "osmode" 0)
(PRINC "")
(SETQ k 1)
;;(SETQ PATH (GETVAR "DWGPREFIX")) ;获取FILEPATH
;;(SETQ NAME (GETFILED "DXF档案输出快选" PATH "DXF" 15))
(COMMAND "_DXFOUT" "F:\\1.DXF" "V" "R12" "O" "W" PT1 PT2  "" "")
(SETVAR "osmode" 3)
(PRINC "\n 文件已输出")
(PRINC)
xiao88gang + 1 很给力!
 楼主| 发表于 2018-5-22 13:08:55 | 显示全部楼层
谢谢您,辛苦了,很完美。
发表于 2018-5-22 13:10:10 | 显示全部楼层
谢谢您,辛苦了,很完美。
发表于 2019-2-27 14:02:53 | 显示全部楼层
如果是连续保存呢?比如F:\1.DXF  2.DXF  3.DXF
GMT+8, 2025-6-30 06:25 , Processed in 0.165823 second(s), 29 queries , Gzip On.
