查看: 1201|回复: 1
[提问] 记忆拉伸 怎么改指定距离拉伸 比如0.15
发表于 2018-6-2 12:05:14 | 显示全部楼层 |阅读模式
(defun c:ss (/ s_dis)
  (command ".STRETCH" (ssget) "")
  (command (setq BasicPoint (getpoint "\n指定基点:")))
  (if (= nil s_dis_all)
      (setq s_dis_all (getreal "\n输入拉伸距离:"))
      (command s_dis_all)
      (setq
s_dis (getreal
  (strcat "\n输入拉伸距离<" (rtos s_dis_all 2 4) ">:")
      (if (= nil s_dis)
(setq s_dis s_dis_all)
      (command s_dis)
      (setq s_dis_all s_dis)
(defun c:ss1 ( )
(command ".STRETCH" (ssget) "" (SETQ AA (getpoint "\n指定基点:"))
(SETQ A2 (GETPOINT AA "\n指点方向")) (POLAR AA (ANGLE AA A2) 1) "")
(progn)
还是出错
发表于 2024-3-2 08:56:38 | 显示全部楼层
不错,谢谢分享,要是能带预览功能就好了
GMT+8, 2025-8-22 04:52 , Processed in 0.161782 second(s), 25 queries , Gzip On.
