查看: 1169|回复: 2
[源码] 改字体为当前样式
发表于 2018-6-2 17:13:57 | 显示全部楼层 |阅读模式
(defun c:ztt (/ acaddocument acadobject currtextstyle e hi n obj ss)
    (setvar "cmdecho" 0)
    (setq ss (ssget '((0 . "TEXT"))))
    (setq AcadObject  (vlax-get-acad-object)
          AcadDocument (vla-get-ActiveDocument AcadObject)
    (setq currTextStyle(vla-get-ActiveTextStyle AcadDocument))
    (princ "当前的文字样式是: ")(princ (vla-get-name currTextStyle))
    ;;; 将文字样式设定为新的文字样式
    (setq hi (vla-get-Height currtextstyle))
  (setq n 0)
  (repeat (sslength ss)
    (setq e (ssname ss n))
        (setq obj (vlax-ename->vla-object e))
        (vla-put-StyleName obj (vla-get-name currTextStyle))
        (vla-put-Height obj hi)
        (vla-Update obj)
        (setq n (1+ n))
    (setvar "cmdecho" 1)
);defun_end
发表于 2018-6-4 07:40:32 | 显示全部楼层
谢谢! Gray-wolf 分享程序!!!!
发表于 2018-6-2 19:03:09 来自手机 | 显示全部楼层
这个论坛上已有
GMT+8, 2025-9-30 05:35 , Processed in 0.188525 second(s), 32 queries , Gzip On.
