查看: 1450|回复: 2
[源码] 文本包围框
发表于 2018-6-4 00:30:33 | 显示全部楼层 |阅读模式
(defun c:tt (/ box1 box2 dis i pt pt1 pt2 pt3 pt4 pts s1 ss_txt txt)
        (setvar "cmdecho" 0)
        ;边框是否放大
        (if (= eh_bgoff_dis_g nil)
                (setq eh_bgoff_dis_g 0)
        (princ "\n如需放大外包框请输入偏移距离<")(princ eh_bgoff_dis_g)(princ ">:")
        (setq dis (getdist))
        (if (= dis nil)
                (setq dis eh_bgoff_dis_g)
                (setq eh_bgoff_dis_g dis)
        (setq ss_txt (ssget '((0 . "TEXT,MTEXT"))))
        (setq i -1)
        (while (setq s1 (ssname ss_txt (setq i (1+ i))))
                (if (EH-Get-EntTypeCompare s1 "TEXT")
                                (setq txt (EH-Get-EntDxf s1 '(40 1 10 41)))
                                (setq pt (caddr txt))
                                (setq pts (textbox (list (cons 40 (car txt)) (cons 1 (cadr txt))(cons 41 (nth 3 txt)))))
                                (setq pt1 (EH-Vector-Add pt (car pts)))
                                (setq pt3 (EH-Vector-Add pt (cadr pts)))
                                (setq pt2 (list (car pt1)(cadr pt3)))
                                (setq pt4 (list (car pt3)(cadr pt1)))
                (if (EH-Get-EntTypeCompare s1 "MTEXT")
                                (setq pt1 (EH-Get-EntDxf s1 '(10 42 43)))
                                (setq box1 (cadr  pt1))
                                (setq box2 (caddr pt1))
                                (setq pt2 (car pt1))
                                (setq pt1 (list (car pt2) (- (cadr pt2) box2)))
                                (setq pt3 (list (+ (car pt2) box1) (cadr pt2)))
                                (setq pt4 (list (+ (car pt2) box1) (- (cadr pt2) box2)))
                (if (= dis 0)
                        nil
                        (setq
                                pt1 (list (- (car pt1) dis) (+ (cadr pt1) dis))
                                pt2 (list (- (car pt2) dis) (- (cadr pt2) dis))
                                pt3 (list (+ (car pt3) dis) (- (cadr pt3) dis))
                                pt4 (list (+ (car pt4) dis) (+ (cadr pt4) dis))
                        );setq
                (if pt4
                        (entmake
                                (list '(0 . "LWPOLYLINE")
                                        '(100 . "AcDbEntity")
                                        '(100 . "AcDbPolyline")
                                        '(8 . "中Z-13----标注")
                                        '(90 . 4)
                                        '(70 . 1)
                                        (cons 10 pt1)
                                        (cons 10 pt2)
                                        (cons 10 pt3)
                                        (cons 10 pt4)
        (setvar "cmdecho" 1)
) ;defun_end
发表于 2018-6-4 03:55:27 来自手机 | 显示全部楼层
沙发顶楼主一个
发表于 2018-6-4 07:53:14 | 显示全部楼层
缺少自定义函数:EH-Get-EntDxf、EH-Get-EntTypeCompare、EH-Vector-Add
GMT+8, 2025-9-30 05:42 , Processed in 0.168732 second(s), 25 queries , Gzip On.
