查看: 4817|回复: 24
[提问] 求把一串文字中的空格替换为逗号,把乘号x替换为*
发表于 2018-7-9 09:29:38 | 显示全部楼层 |阅读模式
如有字符      你好 我好x他好  替换后为  你好,我好*他好
发表于 2018-7-9 16:09:42 | 显示全部楼层
(defun c:ss( / ss osmode i name ent size size_new size_all bak_cecolor)
   (setvar "cmdecho" 0)
   ;(setq osmode (getvar "osmode"))
   (setq i 0)
   (princ "\n選擇尺寸")
   (if(setq ss(ssget '((0 . "DIMENSION"))))
       (setq bak_dimzin(getvar 'dimzin))
       (setvar 'dimzin 8)
       (while (setq name (ssname ss 0))
         (setq i (1+ i))
         (setq ent (entget name))
         (setq size (cdr (assoc 42 ent)))
         (if (= i 1)
           (setq num_all size)
           (setq num_all (+ num_all size))
         (setq size_new (rtos(* size 0.001) 2 3))
         (if (= i 1)
           (setq size_all size_new)
           (setq size_all (strcat size_all "+" size_new ))
         (setq ss(ssdel name ss))
       (setq bak_cecolor(getvar 'cecolor))
       (set-clip-string size_all)  ;複製到剪貼簿 (不含括號)
       (setvar 'cecolor "1")
       (setq size_all(strcat "(" size_all ")"))
       (vl-cmdf "_.text" "j" "mc" (getpoint "\n文本放置點") "250" "0" size_all)
       (and bak_cecolor (setvar 'cecolor bak_cecolor))
       (and bak_dimzin (setvar 'dimzin bak_dimzin))
   ;(setvar "osmode" osmode)
   (setvar "cmdecho" 1)
;;剪貼簿函數
(defun set-clip-string (str / html result)
  (and
    (= (type str) 'str)
    (setq html (vlax-create-object "htmlfile"))
    (setq result (vlax-invoke (vlax-get (vlax-get html 'parentwindow)
                                        'clipboarddata
                              ) 'setdata "Text" str
    (vlax-release-object html)
USER2128 + 1 赞一个!
 楼主| 发表于 2018-7-9 15:58:11 | 显示全部楼层
bluefcc1 发表于 2018-7-9 15:50
不好意思!我沒有QQ
大侠看下这段程序最后生成的文字如何复制到粘贴板
  (setq i 0)
  (princ "\n选择尺寸")
      (setvar 'dimzin 8)
        (setq i (1+ i))
        (if (= i 1)
          (setq num_all size)
        (if (= i 1)
      (vl-cmdf "_.text" "j" "mc" (getpoint "\n文本放置点") "250" "0" size_all)
发表于 2018-7-9 10:45:37 | 显示全部楼层
(defun c:tt ( / e22 e2 sn1 sn2 sn3 i)
    (setq e22nil)
    (while(or (= e22 nil) (/= (cdr (assoc '0 (entget (car e22)))) "TEXT"))
              (setq e22 (entsel "\n点选文字:"))
      (setqe2 (entget (car e22)))
      (setqsn1 (cdr (assoc '1  e2)))
      (alert(strcat "\n文字替换前:"sn1))
      (setq i1)
      (setqsn3 "")
      (repeat(strlen sn1)
              (cond
                  ((= (substr sn1 i 1) " ")  (setq sn2 ","))
                  ((= (substr sn1 i 1) "x") (setq sn2 "*"))
                  (t (setq sn2 (substr sn1 i 1)))
             );end cond
         (setq sn3 (strcat sn3 sn2))
         (setq i (+ i 1))
      (entmod(setq e2 (subst (cons 1 sn3) (assoc 1 e2) e2))) ;直接更新
      (alert (strcat "\n文字替换后:"sn3))
 楼主| 发表于 2018-7-9 11:35:10 | 显示全部楼层
bluefcc1 发表于 2018-7-9 10:45
(defun c:tt ( / e22 e2 sn1 sn2 sn3 i)    (setq e22nil)       (while(or (= e22 nil) (/= (cdr (assoc ' ...
大哥能不能把最后形成的文字弄到粘贴板,以便我可以复制
 楼主| 发表于 2018-7-9 11:37:29 | 显示全部楼层
大哥怎么用不起来 ,是不是哪里错了,直接 警告! 程序已经退出!
发表于 2018-7-9 11:46:27 | 显示全部楼层
((= (substr sn1 i 1)"x") (setq sn2 "*"))
"x"是小写的X,不是╳。
我这边CAD无法识别
我把图面里的文字 改成 "我好 你好x他好"
 楼主| 发表于 2018-7-9 13:11:23 | 显示全部楼层
bluefcc1 发表于 2018-7-9 11:46
((= (substr sn1 i 1)"x") (setq sn2 "*"))"x"是小写的X,不是╳。╳ 我这边CAD无法识别我把图面里的文 ...
主要是程序拖入cad就提示警告 程序已退出 不能用 是哪里错了
 楼主| 发表于 2018-7-9 13:13:32 | 显示全部楼层
是程序本身哪里错了吗
发表于 2018-7-9 14:09:18 | 显示全部楼层
測試沒問題。
发表于 2018-7-9 14:17:02 | 显示全部楼层
 楼主| 发表于 2018-7-9 14:32:52 | 显示全部楼层
可以了大侠,两个有啥不同呀,非常感谢
GMT+8, 2025-5-19 06:55 , Processed in 0.169656 second(s), 30 queries , Gzip On.
