查看: 833|回复: 1
[提问] 如下生成中线的程序,如何修改,使得生成中线后程序不自动停止,可以继续选线生成
发表于 2018-7-10 12:27:15 | 显示全部楼层 |阅读模式
如下生成中线的程序,如何修改,使得生成中线后程序不自动停止,可以继续选线生成中线
(defun c:SCZX( / e1 e2 ent1 ent2  pt1 pt2 ssl)
(setq ssL (ss->LST (ssget '((0 . "LINE")))))
  (while (setq  ent1 (car ssl))
         (setq pt1 (cdr (assoc 10 (entget ent1))))
         (setq pt2 (cdr (assoc 11 (entget ent1))))
         (setq ssl (cdr ssl))
         (setq ent2 (last (vl-sort ssl (function (lambda (e1 e2) (> (distance pt1 (vlax-curve-getClosestPointTo e1 pt1))    (distance pt1 (vlax-curve-getClosestPointTo e2 pt1)) ))))))
         (setq ssl (vl-remove ent2 ssl))
         (center-line  ent1 ent2 )
(defun ss->LST ( ss / i l )
    (if ss
        (repeat (setq i (sslength ss))
            (setq l (cons (ssname ss (setq i (1- i))) l))
(defun center-line (x1 x2 /  m1 m2 pt1 pt2 pt3 pt4)
(setq pt1 (cdr (assoc 10 (entget x1)))
       pt2 (cdr (assoc 11 (entget x1)))
       pt3 (cdr (assoc 10 (entget x2)))
       pt4 (cdr (assoc 11 (entget x2)))
  (if (inters pt1 pt4 pt2 pt3)
    (progn (setq m1 (mapcar (function (lambda ( a b ) (/ (+ a b) 2.0))) pt1 pt3)
                 m2 (mapcar (function (lambda ( a b ) (/ (+ a b) 2.0))) pt2 pt4))
    (progn (setq m1 (mapcar (function (lambda ( a b ) (/ (+ a b) 2.0))) pt1 pt4)
                 m2 (mapcar (function (lambda ( a b ) (/ (+ a b) 2.0))) pt2 pt3))
  (entmakex (list (cons 0 "LINE")  (cons 10 m1)(cons 62 1)(cons 8 "中心线")(cons 11 m2)))
发表于 2018-7-11 09:04:44 | 显示全部楼层
加个while就好
可能不是最好的方法 不过能实现
(defun c:SCZX( / aa e1 e2 ent1 ent2  pt1 pt2 ssl)
  (setq aa (ssget '((0 . "LINE"))))
  (while aa
    (setq ssL (ss->LST aa))
    (princ "\n 继续选择:")
  (print)
GMT+8, 2025-5-19 11:19 , Processed in 0.179736 second(s), 26 queries , Gzip On.
