查看: 5661|回复: 15
[源码] 批改图框页码,选择集排序疑问
发表于 2018-7-19 20:53:05 | 显示全部楼层 |阅读模式
各位好,附件为LXZ老师批改图框页码的源码,对于做幕墙施工画加工图来说作用很大,
但排序一直是个问题,只能麻烦些一排一排改,不然顺序会错乱。
试过拿各种排序源码去修改,奈何水平不足,一直达不到想要的效果,
所以只能发帖请教各位老师,希望有时间能指点下,谢谢!!
  1. ;;;;批量改图框页码
  2. ;byLXXZZ
  3. ;http://bbs.mjtd.com/thread-89140-1-1.html
  4. ;更改属性块标记tag所对应的值string
  5. (defun xz-att (ent tag string / liST0 liST1 num blkref)
  6.   (vl-load-com)
  7.   (if (= (vla-Get-ObjectName (setq blkref (vlax-Ename->vla-Object ent))) "AcDbBlockReference")
  8.     (if (vla-Get-HasAttributes blkref)
  9.       (progn (setq liST0 (vlax-safearray->list  (vlax-variant-value (vla-GetAttributes blkref))))
  10.        (setq liST1 (mapcar 'vla-Get-TagString  liST0))
  11.              (setq num (vl-position tag list1))
  12.              (vla-put-TextString (nth num liST0) string)
  13.   )
  14.     ); endif
  15.   ); endif
  16.   (prin1)
  17. ); enddefun
  18. ;(setq  ent  (car (entsel)))   例子
  19. ;(xz-att ent "页码" 30)   例子
  20. ;***********
  21. (defun c:YM (/ EP1 EG1 EG2 blktag EP1st blkname str GETK prefix sttr
  22.        index0 index sslist XZ_sortlist len0 len sslist_ptl index0)
  23.   (vl-load-com)
  24.   (if (progn
  25.      (setq EP1 (entsel "\n点取属性块中,页码的位置:"))
  26.         (setq EG1 (cdr (assoc 0 (entget (car EP1)))))
  27.            (if (/= EG1 "INSERT")
  28.        (progn(princ "\n必须选择属性块.")(exit)(princ))
  29.              (progn (setq EG2 (car (nentselp (cadr EP1))))
  30.                    (if (= (cdr (assoc 0 (entget EG2))) "ATTRIB")
  31.                  (setq blktag (cdr (assoc 2 (entget EG2)))) ;标记
  32.        )
  33.              (setq EP1st (entget (car EP1)))
  34.              (setq blkname (assoc 2 EP1st))
  35.          )
  36.          )
  37.          )
  38.         (princ (strcat "  块名为:" (cdr blkname) "   标记为:" blktag "\n"))
  39.          (progn(princ "  必须选择属性块!")(exit))
  40.          )
  41.
  42.   ;开始选择页码块并修改
  43.   (setq prefix (getstring "请输入前缀:"))
  44.   (if (=  str0  nil) (setq str0 1)) (initget 6)
  45.   (setq str (getint (strcat "请输入一个起始整数<" (rtos str0 2 0) ">:")))
  46.   (if (= str  nil)(setq str  str0))
  47.
  48.   (initget "H V S ")(setq GETK (getkword "排序方式:\n [横向优先(H)/竖向优先(V)/选择优先(S)]: <H> "))
  49.   (princ ">>选择批量修改页码的对象...")
  50.   (setq ss (ssget  (cons blkname slist)))
  51.   (setq index0 0 index (sslength ss) sslist '())
  52.   (repeat index
  53.     (setq sslist (cons (ssname ss index0) sslist))
  54.     (setq index0 (1+ index0))
  55.   )
  56.   ;开始构建图元点位表
  57.   (setq index0 0  sslist_ptl '() tmp_pt '())
  58.   (repeat index
  59.     (setq tmp_pt (cons (nth index0 sslist) (cons (cdr(assoc 10 (entget (nth index0 sslist)))) tmp_pt)))
  60.     (setq sslist_ptl (cons tmp_pt sslist_ptl))
  61.     (setq tmp_pt '())
  62.     (setq index0 (1+ index0))
  63.   )
  64.   ;开始排序
  65.   (cond
  66.   ;从左到右从上到下
  67.   ((or (= GETK "H")(= GETK nil))
  68.     (setq XZ_sortlist (vl-sort
  69.       (vl-sort sslist_ptl '(lambda (s1 s2) (> (cadadr s1) (cadadr s2))))
  70.       '(lambda (s3 s4) (if(equal (cadadr s3) (cadadr s4) 0.6)(< (caadr s3) (caadr s4))))))
  71.   )
  72.   ;从上到下从左到右
  73.   ((= GETK "V")
  74.     (setq XZ_sortlist (vl-sort
  75.       (vl-sort sslist_ptl '(lambda (s1 s2) (< (caadr s1) (caadr s2))))
  76.       '(lambda (s3 s4) (if(equal (caadr s3) (caadr s4) 0.6)(> (cadadr s3) (cadadr s4))))))
  77.    )
  78.    ;选择顺序
  79.   ((= GETK "S")
  80.     (setq XZ_sortlist  sslist_ptl))
  81.    );cond
  82.   ;开始修改页码
  83.     (setq len0 0 len (length XZ_sortlist))
  84.     (repeat len
  85.      (if (setq ent0 (car (nth len0 XZ_sortlist)))
  86.    (progn
  87.      (cond
  88.        ((/= prefix "")
  89.      (if (=(strlen (rtos str))1)
  90.        (setq sttr (strcat prefix "0" (rtos str 2 0)))
  91.        (setq sttr (strcat prefix (rtos str 2 0)))
  92.      ))
  93.        ((= prefix "")(setq sttr  (rtos str 2 0)))
  94.      );cond
  95.      (xz-att ent0 blktag sttr)
  96.      (princ (strcat " >>已修改至页:" (rtos str 2 0) "、"))
  97.      (setq len0 (1+ len0) str (1+ str))
  98.      (setq str0  str)
  99.    )
  100.       )
  101.   );repeat
  102.   (prin1)
  103. )
发表于 2020-1-15 09:25:51 | 显示全部楼层
这应该是你要的。
  1. (princ "\n★功能:批量改图框页码,请输入 ym 命令。原著:by 李晓卓;修改:xvjiex\n")
  2. (if (null vlax-dump-object) (vl-load-com) )
  3. (defun xz-att (ent tag string / liST0 liST1 num blkref)
  4.   (vl-load-com)
  5.   (if (= (vla-Get-ObjectName (setq blkref (vlax-Ename->vla-Object ent))) "AcDbBlockReference")
  6.     (if (vla-Get-HasAttributes blkref)
  7.       (progn (setq liST0 (vlax-safearray->list  (vlax-variant-value (vla-GetAttributes blkref))))
  8.        (setq liST1 (mapcar 'vla-Get-TagString  liST0))
  9.              (setq num (vl-position tag list1))
  10.              (vla-put-TextString (nth num liST0) string)
  11.   )
  12.     ); endif
  13.   ); endif
  14.   (prin1)
  15. ); enddefun
  16. ;(setq  ent  (car (entsel)))   例子
  17. ;(xz-att ent "页码" 30)   例子
  18. ;***********
  19. (defun c:YM (/ EP1 EG1 EG2 blktag EP1st blkname str GETK prefix sttr
  20.        index0 index sslist XZ_sortlist len0 len sslist_ptl )
  21.   (vl-load-com)
  22.   (if (progn
  23.      (setq EP1 (entsel "\n点取属性块中,页码的位置:"))
  24.         (setq EG1 (cdr (assoc 0 (entget (car EP1)))))
  25.            (if (/= EG1 "INSERT")
  26.        (progn(princ "\n必须选择属性块.")(exit)(princ))
  27.              (progn (setq EG2 (car (nentselp (cadr EP1))))
  28.                    (if (= (cdr (assoc 0 (entget EG2))) "ATTRIB")
  29.                  (setq blktag (cdr (assoc 2 (entget EG2)))) ;标记
  30.        )
  31.              (setq EP1st (entget (car EP1)))
  32.              (setq blkname (assoc 2 EP1st))
  33.          )
  34.          )
  35.          )
  36.         (princ (strcat "  块名为:" (cdr blkname) "   标记为:" blktag "\n"))
  37.          (progn(princ "  必须选择属性块!")(exit))
  38.          )
  39.
  40.   ;开始选择页码块并修改
  41.   (setq prefix (getstring "请输入前缀:"))
  42.   (if (=  str0  nil) (setq str0 1)) (initget 6)
  43.   (setq str (getint (strcat "请输入一个起始整数<" (rtos str0 2 0) ">:")))
  44.   (if (= str  nil)(setq str  str0))
  45.
  46.   (initget "H V S ")(setq GETK (getkword "排序方式:\n [横向优先(H)/竖向优先(V)/选择优先(S)]: <H> "))
  47.   (princ ">>选择批量修改页码的对象...")
  48.   (setq ss (ssget  (cons blkname slist)))
  49.   (setq index0 0 index (sslength ss) sslist '())
  50.   (repeat index
  51.     (setq sslist (cons (ssname ss index0) sslist))
  52.     (setq index0 (1+ index0))
  53.   )
  54.   ;开始构建图元点位表
  55.   (setq index0 0  sslist_ptl '() tmp_pt '())
  56.   (repeat index
  57.     ;(setq e_obj (vlax-ename->vla-object (entget (nth index0 sslist))))
  58.     (setq e_obj (vlax-ename->vla-object  (nth index0 sslist)))
  59.     (vla-getboundingbox e_obj 'minpt 'maxpt)
  60.     (setq tmp_pt (cons (nth index0 sslist) (cons (vlax-safearray->list  minpt) tmp_pt)))
  61.     (setq sslist_ptl (cons tmp_pt sslist_ptl))
  62.     (setq tmp_pt '())
  63.     (setq index0 (1+ index0))
  64.   )
  65.   ;开始排序
  66.   (cond
  67.   ;从左到右从上到下
  68.   ((or (= GETK "H")(= GETK nil))
  69.     (setq XZ_sortlist (vl-sort
  70.       (vl-sort sslist_ptl '(lambda (s1 s2) (> (cadadr s1) (cadadr s2))))
  71.       '(lambda (s3 s4) (if(equal (cadadr s3) (cadadr s4) 0.6)(< (caadr s3) (caadr s4))))))
  72.   )
  73.   ;从上到下从左到右
  74.   ((= GETK "V")
  75.     (setq XZ_sortlist (vl-sort
  76.       (vl-sort sslist_ptl '(lambda (s1 s2) (< (caadr s1) (caadr s2))))
  77.       '(lambda (s3 s4) (if(equal (caadr s3) (caadr s4) 0.6)(> (cadadr s3) (cadadr s4))))))
  78.    )
  79.    ;选择顺序
  80.   ((= GETK "S")
  81.     (setq XZ_sortlist  sslist_ptl))
  82.    );cond
  83.   ;开始修改页码
  84.     (setq len0 0 len (length XZ_sortlist))
  85.     (repeat len
  86.      (if (setq ent0 (car (nth len0 XZ_sortlist)))
  87.    (progn
  88.      (cond
  89.        ((/= prefix "")
  90.      (if (=(strlen (rtos str))1)
  91.        (setq sttr (strcat prefix "0" (rtos str 2 0) "页"))
  92.        (setq sttr (strcat prefix (rtos str 2 0) "页"))
  93.      ))
  94.        ((= prefix "")(setq sttr  (strcat (rtos str 2 0) "页")))
  95.      );cond
  96.      (xz-att ent0 blktag sttr)
  97.      (princ (strcat " >>已修改至页:" (rtos str 2 0) "、"))
  98.      (setq len0 (1+ len0) str (1+ str))
  99.      (setq str0  str)
  100.    )
  101.       )
  102.   );repeat
  103.   (prin1)
  104. )
非常感谢,是我想要的排序,谢谢!!  发表于 2020-1-15 11:16
 楼主| 发表于 2018-7-20 08:47:57 | 显示全部楼层
死神去了 发表于 2018-7-20 08:13
这个使用上完全没问题,排序是按照块的基点位置上下左右为判断依据的。。。
楼主的图框基点在横线位置就不 ...
是的,但公司的图框基本都在块的左下角,一旋转就难搞了,
属性块后期改基点又会把块里的属性移位,所以很烦~~!
发表于 2018-7-20 08:13:43 | 显示全部楼层
楼主的图框基点在横线位置就不会出错的
发表于 2018-7-20 11:35:49 | 显示全部楼层
用getboundingbox获取块图框的包围框,取左下角点进行排序试一下,应该可以。
发表于 2018-8-11 19:48:24 | 显示全部楼层
看帖回帖是美德
发表于 2018-9-15 12:38:09 | 显示全部楼层
把这个改成
(setq tmp-pt (cons (nth index0 sslist) (cons (vlax-safearray->list  minpoint) tmp-pt)))
发表于 2018-9-15 22:37:28 | 显示全部楼层
研究了半天,终于把选择优先放到前边了。有点笨了。
发表于 2018-9-17 11:25:44 | 显示全部楼层
楼上的,把改后的东西传上来啊
发表于 2019-7-9 10:25:24 | 显示全部楼层
顶起来   希望更多人解决
发表于 2019-9-25 10:55:42 | 显示全部楼层
改页码?怎么没有后缀 页
GMT+8, 2025-12-8 05:54 , Processed in 0.203531 second(s), 34 queries , Gzip On.
