查看: 662|回复: 3
[提问] 有很多文字,有些文字带有123,如何输入tt,使带123的文字隐藏不显示
发表于 2018-8-7 10:36:00 | 显示全部楼层 |阅读模式
发表于 2018-8-7 11:40:18 | 显示全部楼层
把符合条件的文字放到单独层,然后把该图层隐藏?
发表于 2018-8-7 12:34:35 | 显示全部楼层
(redraw [ename [mode]])
mode
An integer value that controls the visibility and highlighting of the entity. The mode can be one of the following values:
1 Show entity
2 Hide entity (blank it out)
(vlax-put-property (vlax-ename->vla-object ee) 'visible :vlax-false)
;; 还原
(vlax-put-property (vlax-ename->vla-object ee) 'visible :vlax-true)
(vla-put-visible (vlax-ename->vla-object ee) :vlax-false)
修改 dxf 组码 60 为 1
发表于 2018-8-10 19:39:53 | 显示全部楼层
把符合条件的颜色改为与背景色一样可以不?
GMT+8, 2025-5-19 07:36 , Processed in 0.168019 second(s), 26 queries , Gzip On.
