查看: 625|回复: 2
[提问] CAD
发表于 2018-8-14 18:25:23 | 显示全部楼层 |阅读模式
CAD中大量的多行文字,怎么只提取括号中的数据
  • 关闭
发表于 2018-8-15 11:01:33 | 显示全部楼层
(setq str "3.40(5.18)")
(car (read (substr str (1+ (vl-string-search "(" str)))));5.18
(read (substr str (+ (vl-string-search "(" str) 2)));5.18
(setq n (vl-string-search "(" str))
(substr str (+ n 2) (- (strlen str) n 2));"5.18"
(vl-string-trim ")" (substr str (+ (vl-string-search "(" str) 2)));"5.18"
(vl-string-trim "()" (substr str (1+ (vl-string-search "(" str))))
(vl-string-right-trim ")" (substr str (+ (vl-string-search "(" str) 2)));"5.18"
(vl-list->string (reverse (cdr (reverse (cdr (member (ascii "(") (vl-string->list str)))))));"5.18"
(apply 'strcat (reverse (cdr (reverse (cdr (member "(" (mapcar 'chr (vl-string->list str))))))));"5.18"
回复 支持 2 反对 0
发表于 2018-8-14 20:08:35 | 显示全部楼层
(car (read (substr str (1+ (vl-string-position (ascii "(") str)))))
GMT+8, 2025-5-19 07:02 , Processed in 0.168973 second(s), 27 queries , Gzip On.
