查看: 2684|回复: 14
[提问] 我想一段代码里面加入上次输入的默认值,请高手指教
发表于 2018-8-26 22:39:17 | 显示全部楼层 |阅读模式
  1. (defun c:dbx( / newdbdist newdbdist1 cen )
  2.          (setvar "cmdecho" 0) ;指令执行过程不响应
  3.      (PRINC "\n画六边形工具)(PRINC)
  4.    (while T
  5.       (if  (and newdbdist1 (/= newdbdist1 ""))
  6.      (progn
  7.       (setq newdbdist (/ (getreal (strcat "\n 请输入对边尺寸默认值:<" newdbdist1 ">")) 2))
为什么不能正常显示默认值,代码哪里有问题呢,我是初学者,请高手指点,万分感谢!
发表于 2018-8-28 08:57:34 | 显示全部楼层
不就是给定中心点、对边画六边形吗?
(defun c:6b (/ newdbdist cen)
        (princ "\n功能:指定中心点、对边画六边形。")
        (if (not newdbdist1)
                        (setq newdbdist1 10.0)
        (while (setq cen (getpoint "\n请指定六边形的中心点<退出>: "))
                (if  (not (setq newdbdist (getdist (strcat "\n请输入六边形的对边距离<" (rtos newdbdist1) ">: "))))
                                (setq newdbdist newdbdist1)
                                (setq newdbdist1 newdbdist)
                (command "_polygon" "6" "non" cen "c" (/ newdbdist 2.0))
        (setvar "cmdecho" 1)
Look_back + 1 赞一个!
 楼主| 发表于 2018-8-27 19:44:48 | 显示全部楼层
(defun c:6b ( / newdbdist newdbdist1 cen )
     (PRINC "\n画六边形工具")(PRINC)
     ;(setq newdbdist1 9 )
         (while T
            (setq newdbdist (getreal (strcat "\n请输入对边尺寸默认值<" (rtos (* newdbdist1 2)) ">: ")))
      (if (= newdbdist nil)
                (setq newdbdist (/ (getreal "\n 请输入对边尺寸:") 2))
           (setq cen (GETPOINT "\n-->请指定中心 : "))
           (COMMAND "_polygon" "6" cen "c" newdbdist "")
 楼主| 发表于 2018-8-26 22:44:17 | 显示全部楼层
为什么代码显示不完整呢
 楼主| 发表于 2018-8-26 22:45:44 | 显示全部楼层
  4.    (while T
  6.      (progn
发表于 2018-8-26 22:50:15 | 显示全部楼层
默认值请搜寻
Uint
ureal
ustr
udist
等自定义函数
发表于 2018-8-27 08:45:27 | 显示全部楼层
(defun c:dbx( / newdbdist cen)
        (princ "\n画六边形工具")
                (setq newdbdist1 20.0)
        (if  (not (setq newdbdist (getreal (strcat "\n请输入对边尺寸默认值<" (rtos newdbdist1) ">: "))))
        (setq newdbdist (/ newdbdist 2.0))
发表于 2018-8-27 15:44:41 | 显示全部楼层
"\n画六边形工具
引号要成对
"\n画六边形工具"
 楼主| 发表于 2018-8-27 19:41:45 | 显示全部楼层
        (princ "\n画六边形工具") ...
我把您的这段代码替换掉居然就OK了,感谢! (setq newdbdist (getreal (strcat "\n请输入对边尺寸默认值<" (rtos newdbdist1) ">: "))),这个(rtos newdbdist1) 我想让这个默认值放大2倍呢。
 楼主| 发表于 2018-8-27 21:50:34 | 显示全部楼层
这段代码还有缺陷,就是六边形对边尺寸问题,输入的是对边,但参数需要除2,怎么处理呢。
发表于 2018-8-27 22:19:55 | 显示全部楼层
  1. (defun c:6b ( / newdbdist cen zfc)
  3.      (while (setq cen (GETPOINT "\n-->请指定中心<回车结束程序>: "))
  4.          (setq zfc (strcat "\n请输入对边尺寸<默认值 " (rtos (getvar "USERR1")) ">: "))
  5.          (if (= (setq newdbdist (getreal zfc)) nil)
  6.              (setq newdbdist (getvar "USERR1"))
  7.          )
  8.          (setvar "USERR1" newdbdist)
  9.          (COMMAND "_polygon" "6" cen "c" (* 0.5 newdbdist) "")
  10.       )
  11.       (setvar "cmdecho" 1)
  12.       (princ)
  13. )
GMT+8, 2025-5-19 07:18 , Processed in 0.153466 second(s), 28 queries , Gzip On.
